Want to buy it and fix it? - Pontiac Solstice Forum
 1Likes
post #1 of 16 (permalink) Old 04-08-2017, 05:19 AM Thread Starter
What's up guys, I have a black GXP with 58k miles in great condition other than overheating. I changed wp, thermostat and now I'm left with head gasket. I'm sure it's that. Will be doing a compression test today. Well I just got offered a job out of state. Not sure if I'll have the time to fix it. Anyone want to buy it cheap and fix it themselves? I'll knock the price down $2k which is the high end price for a shop to fix it. I don't want to sell it but it would be less of a headache than trying to get it fixed and move. I'm in Tampa area.
Myllertime is offline
post #2 of 16 (permalink) Old 04-08-2017, 05:36 AM
What is the actual price you are asking for it? If I understand you correctly you are lowering it $2000 below that.
Hoosier GXP is offline
post #3 of 16 (permalink) Old 04-08-2017, 06:00 AM Thread Starter
Yes the actual price is 10k. I'm actually running it right now. Got the air out. I get no heater on the vents and it's idling at 207-210. Waiting for a friend to help me do a compression test. There's a chance it's a minor fix
post #4 of 16 (permalink) Old 04-08-2017, 06:11 AM Thread Starter
Ran it for about 30 mins. The idle maxed out at 214 but when I touched the gas lightly for about 5 mins it went up to 225 then I shut it down. Pretty sure air is getting back in there from the heads. No oil in the coolant and no milky oil. Leaves me slightly clueless.
post #5 of 16 (permalink) Old 04-08-2017, 03:28 PM
wspohn's Avatar
I have had gaskets allowing water into the chambers but no loss of compression and negative chemical indication when tested that way. It was on my 6 cylinder MG, and in the end I threw up my hands and changed the head gasket as I didn't know what else to do. It fixed it and I've had no trouble since.
Sounds like you might be at about that point.....
1958 MGA Twin Cam (race car)
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #6 of 16 (permalink) Old 04-08-2017, 04:03 PM Thread Starter
Yeah I have similar symptoms. I just did a compression test. Got 185, 175, 175, 180. Also did a fluid pressure test with each spark off 1 at a time and at 15lbs. All of them acted the same. Took about 5 mins to lose .5lb of pressure. Anyone know any indications here? I also did a combustion chemical test in the coolant and it failed.
post #7 of 16 (permalink) Old 04-08-2017, 08:25 PM
You could try putting a check vale in the bled line. You may have a air leak in the surge tank cap.
Here is the vale part number. 20876185
Check out this post.
https://www.solsticeforum.com/forum/f...t-lines-71309/
post #8 of 16 (permalink) Old 04-08-2017, 08:26 PM Thread Starter
I also replaced the tank cap
post #9 of 16 (permalink) Old 04-08-2017, 09:21 PM
gwhunter12's Avatar
Send a message via Yahoo to gwhunter12
I used the check valves and it fixed my heating problem after thermostat didn't. I was running to 231 degrees now at 205.
Just a thought.
gwhunter12 is offline
post #10 of 16 (permalink) Old 04-08-2017, 09:24 PM Thread Starter
Just a thought.
I'll def look into it. Can you send me a link and maybe how to do it. Never heard of it
post #11 of 16 (permalink) Old 04-08-2017, 09:31 PM
gwhunter12's Avatar
Ordered from Amazon. Engine coolant air bleed line valves. You'll need two at $13 ea .
post #12 of 16 (permalink) Old 04-09-2017, 06:07 AM
Sly Bob's Avatar
TSB about the check valves can be found here.
https://www.solsticeforum.com/forum/f...tml#post938806
Born April 30, 2008
Delivered on May 27, 2008
Sly Bob is offline
post #13 of 16 (permalink) Old 04-09-2017, 09:58 AM Thread Starter
Thanks guys. Just ordered two of them. Fingers crossed.
post #14 of 16 (permalink) Old 04-09-2017, 10:22 AM
AKA SolWhat?
DaveOC's Avatar
For what it's worth, I'll post it here.
See below:
File Type: pdf TSB_10-06-02-001-coolingcheckvalves.pdf (259.2 KB, 302 views)
1st 1K - #741
DaveOC is offline
post #15 of 16 (permalink) Old 04-09-2017, 12:05 PM
CRiggleman's Avatar
Myllertime, you might want to check out a tool for filling your cooling system called an airlift. A few of us on the forum have used them and have good luck getting the air out of the system.
One of the threads that discusses the tool can be found here;
https://www.solsticeforum.com/forum/f...2/#post1847554
I've used this tool on a few cars and have no problems with air in the system, plus if you do have a leak somewhere it will be pretty evident by the fact that your system won't hold vacuum. My car will hold about 20 HG of vacuum for as long as I wanted it to and all I had to do to seal the system was to plug the overflow line.
Sting Ya likes this.
CRiggleman is offline
