Camshaft position Sensor ?? - Page 2 - Pontiac Solstice Forum
post #16 of 18 (permalink) Old 06-30-2019, 11:10 PM Thread Starter
90K approx..
Also, codes were P0343 and P0367.
I had also checked spark on #1 - its there, did not check the others. Just strange that #2 & #4 cylinders haevb no pressure & 1 & 3 appear ok.
any new ideas here? Tying to DIY this before taking to a $hop.. I'm very competent at old Small block Chevy mechanical stuff, not that familiar with the modern ECM engines.
thanks
Michael
Michael_P_H is offline
post #17 of 18 (permalink) Old 07-01-2019, 04:30 AM
P0367 is the exhaust equivalent of P0343, so the electrical testing is the same.
The VVT system changes the timing of the valve operation, and not the actual operation, so I think you should still get compression in all four cylinders.
My next steps would be to check the circuits for voltage (Posts 6&8) and then do a cylinder leak-down test to see why there is no compression on 2 and 4.
JohnWR is online now
post #18 of 18 (permalink) Old 07-01-2019, 10:03 AM
IT'S GONNA NEED A MOTOR.....or cylinder head& timing chains...probably cheeper to put a motor in it and probably better too. no compresion is, holes in pistons,valves bent, valves hung open..possiably timing chains broken, jumped timing,it's a mess. I would put a compleate engine in it.rather than trying to fix it unless you have a wadd of$$$ and plenty of tyme.( if it were mine I would then after driving with new motor I would tear appart the old motor and play with it....good luck, dont be skeered of used motor,just try to get a fairly low millage unit.
marksbug is offline
