Might eat my own advice here.... - Pontiac Solstice Forum
 2Likes
post #1 of 19 (permalink) Old 09-07-2019, 01:09 PM Thread Starter
Asking for a friend!
As anti-induction cleaning as I've been...I've been thinking about trying it myself with a cleaner. My question is this gents for those that know. Can I pull the evap solenoid and shoot the valve cleaner down there or is that too close to the valves?? I'd rather do it there then in the cold side pipe...unless that would be a better place. I know I've been a staunch supporter of NOT doing this....but I'm at wits end with this vibration and commanded AFR issue and I'm willing to try anything at this point to get rid of these things before I blow up my car!!
post #2 of 19 (permalink) Old 09-07-2019, 03:03 PM
I was thinken you may have leeky injector....but I havent a clue about direct injectors. I doubt 1 good cleaning will hurt the turbo.you could alwasy takje it off for the cleaning and have a flanged tube made to reconnect to the cat.....probably...not gonna happen..... but I have been looking and I seriously think the gxp ex manifold on a 2.4 will make more power than the base ex manifold on a 2.4, especialy if it had a seperated flange&2 tubes to merge down stream about 9" then a few inches on into the cat yes it would be basicly a be a loop to the converter on a 2.4. ( aka try Y header ), but back to your issue...yes I would have them cleaned before doing anything else. ( I seem to remember you already cleaned the valves witch can also make a over rich issue when there funked up) I would either try a pour in the tank or a injection method.the injection method would probably work faster and be less likely to possiably affect turbo...( in my head anyway) and on the turbo being affected...was that on peoples cars that ran stuff through way too much?? or...?? another issue with cleanings is....it should be done before the oil is changes as it does dirty the oil.witch will adversely affect the turbo's life. never clean after a oil change, always do it a tank before( for the pour in stuff) and probably atleast half a tank for the injected cleaners. it does send some of the built up cleaned off stuff/funk past the rings into the oil. so....yes do it to your friends car and see how it works out!!!
marksbug is offline
post #3 of 19 (permalink) Old 09-07-2019, 04:47 PM
wmf246's Avatar
just a reminder, pouring 'something' in the tank will not reach the valves in a direct injection engine; it's got to go in the intake
Bill
wmf246 is offline
post #4 of 19 (permalink) Old 09-07-2019, 08:24 PM Thread Starter
Originally Posted by wmf246 View Post
just a reminder, poring 'something' in the tank will not reach the valves in a direct injection engine; it's got to go in the intake
Bill
No, I understand that. I've been the biggest vocal person against that here!! I was going to pull the evap solenoid and inject some seafoam into that with the car running. Or where the MAP sensor is at on the IC Piping....whichever people think would be better!
post #5 of 19 (permalink) Old 09-07-2019, 09:19 PM
Good luck
rob the elder is online now
post #6 of 19 (permalink) Old 09-07-2019, 09:36 PM
Saveaux's Avatar
Is this a bad spot?
https://youtu.be/H4CqlmUGQ_s
It's where i did mine.
Saveaux is offline
post #7 of 19 (permalink) Old 09-08-2019, 11:31 AM
znaut's Avatar
You're much better off pulling the intake and cleaning the valves directly. You may also spot a problem in the process.
znaut is offline
post #8 of 19 (permalink) Old 09-08-2019, 12:23 PM
When it comes to it, there is risk in either choice. Let us know what you decide
post #9 of 19 (permalink) Old 09-08-2019, 12:24 PM
I recall some others doing what you propose, but not sure where the threads are. As far as I remember they just pulled one of the small vacuum hoses at the intake manifold, and injected there.
post #10 of 19 (permalink) Old 09-08-2019, 01:02 PM Thread Starter
Originally Posted by Saveaux View Post
Is this a bad spot?
Well...just went out to see if I could do what you sent...and decided just to pull if off to see if it would run...and my car won't even stay running with that tube disconnected!! That's off the wastegate...right? So now you've got me wondering if the wastegate might have something to do with my issues..... Who knows what this issue that I have going is from...I'm grasping at straws.
post #11 of 19 (permalink) Old 09-08-2019, 01:08 PM
To do what you are proposing I would tee into a line and then adapt my new line so that it will maintain vacuum but allow induction of the cleaner.
JohnWR is online now
post #12 of 19 (permalink) Old 09-09-2019, 12:38 PM
I agree with this. It's a hassle opening up the intake, but blasting the backs of the valves with walnut shells would be the safest bet.
JustKelly is offline
post #13 of 19 (permalink) Old 09-09-2019, 02:55 PM
I thought he already blasted with walnuts....... I musta got confuzed with somebody else. I doubt seafoam will do any thing at all. if it's a injector issue injectiong in the intake wiill do squat. but if it's funked up at the valves that is known to cause a over rich situation.and blasting is the solution. Ive tried oh somany different cleeaners to clean the crap off the backs of valves, nothing but blasting would remove it. I was soaking the valves each in different product.none did squat. a running engine over time could possiably, but not a short time. thus blasting with walnuts.and vacuming out at the same tyme. somebody on flebay had some shopvac attachments 3 d printed for doing so.
marksbug is offline
post #14 of 19 (permalink) Old 09-10-2019, 08:44 AM
The most direct path to the valves without removing the manifold is via the port that connects to the brake booster. There is a barbed fitting that threads into the intake manifold body, with a large hose that goes to the booster.
The correct way to clean the valves is to remove the intake manifold. I walnut blasted, but it's a messy process. You can also use chemical or other mechanical means to get rid of the carbon buildup. Going in via the evap solenoid isn't something that I see working very well.
Removing the intake manifold isn't difficult. The first time it took me about an hour. Now it's a 15 minute process. There are a couple of brackets under the manifold that are conveniently painted black. They're difficult to get out of the way.
Things can be made easier by removing not only the manifold-to-head bolts, but the studs, as well. The head of the studs require a female Torx bit to remove. It is NOT a regular hex pattern. Attempting to use a regular socket will strip the heads.
post #15 of 19 (permalink) Old 09-10-2019, 08:47 AM Thread Starter
Is removing the intake very difficult? You have to remember, you're talking to a guy that had issues doing the thermostat!! Lol
raygun likes this.
