Quick-Jack 5000 SLX for Solstice Safe? - Pontiac Solstice Forum
 1Likes
  • 1 Post By pyrofreek
post #1 of 14 (permalink) Old 08-01-2019, 08:26 AM Thread Starter
Good day, has anyone considered or actually purchased a Quick-Jack to use with the Solstice? my concern is if you read about the quick jack it notes the lift points have to be in-line with each other. official documentation I have for the Solstice shows the front lift point is in-ward and not in line with the side rear one? Did anyone ever use the quick-jack safely with a Solstice? or crazy idea for our cars? thank you- Charles2010
charles2010 is offline
post #2 of 14 (permalink) Old 08-01-2019, 06:39 PM
I’ve had my for three years and I love it . But it’s the 3500 SLX just the right size but be sure to use rubber blocks that come with it.
Granpa 4 is offline
post #3 of 14 (permalink) Old 08-09-2019, 07:05 AM
sjw
sjw's Avatar
Use mine regularly with no issues. The lifts do end up at a slight angle but are perfectly stable.
2008 GXP (?)hp on Werks Mustang Dyno
Werks LS3 Conversion
1 7/8 in custom Werks headers
BTR Stage 2 blower cam
DDM Backbone
Kapasphere ReBar
BG Racing coilovers
Norms rear diffuser, fenders, one off hood. Werks Gurney Flap.
Edelbrock EForce supercharger. Water/meth injection. GM 6L90, trans brake and 2 step. DSS Ford 9in IRS rear conversion, drive shaft and axles. Werks roll bar. Line lock. CCW D540 wheels. MT drag radials. Recaro seats.
sjw is offline
post #4 of 14 (permalink) Old 08-10-2019, 06:44 AM
Put the lift points under the slots in the frame. They are aligned and are better than the forward “jacking point” which will bend with repeated use. See my entry on adding shoes to Punisher.
The critical dimension is the spacing between the lift points. The 3500 is just the right length to access the two frame slots. I don’t have the dimensions of the 5000 but I am sure it’s heavier and requires more effort every time you have to lug it around.
post #5 of 14 (permalink) Old 08-14-2019, 07:10 AM
is anybody using the 5000SLX? home depot has them "pro special buy of the week".
i see that the 3500 works but i would like one that i can put my FJC up on as well. just wanted to see if anybody had run into issues with the lifting points.
thanks
showtime likes this.
pyrofreek is offline
post #6 of 14 (permalink) Old 08-14-2019, 09:42 AM
I had thought about getting 2 of the harbinger of fright lifts like this( motor cycle lift...big motor cycle lift) for my 356. I now wish when I built my shop I had done it with 12' ceilings or more for a nice inside lift like my brother has..or a better one!!
marksbug is offline
post #7 of 14 (permalink) Old 08-14-2019, 09:48 AM
BL-3500SLX SPECIFICATIONS
Lifting point spread 26.75” - 50.5” (679 mm - 1,283 mm)
BL-5000SLX SPECIFICATIONS
Lifting point spread 29.5” - 60” (749 mm - 1,524 mm)
The 3500 fits the lift points just right. I am not sure if adding 9.5 inches will work. Measure your lift points and see if it fits. It might. :-)
Since the jacks need to be parallel with each other and the car being lifted, recommend you go with the frame and not the front lifting pad as it will cause the jacks to be angled so both ends are on a hard point.
My experience with the 3500 is it JUST fits at the narrowest adjustment available.
post #8 of 14 (permalink) Old 08-15-2019, 11:30 AM Thread Starter
Rob_the_elder, excellent advice as always, would it be a big imposition for a picture of where your 3500 is actually aligned with the car for the lifting? I am considering strongly purchasing one for my car but the whole not -in-line- confuses and concerns me. I have seen pictures of where the lift points vs. jack points etc.. but I want to be 100% sure. would it be possible once again for a picture -- would be greatly appreciated.
- Charles
post #9 of 14 (permalink) Old 08-16-2019, 01:25 PM
sjw
sjw's Avatar
thanks
I have the 5000 and it works just fine.
Name:	quik jak 1.jpg
ID:	98871   Click image for larger version
Name:	quik jak 2.jpg
DDM Backbone
Kapasphere ReBar
BG Racing coilovers
sjw is offline
post #10 of 14 (permalink) Old 08-16-2019, 02:05 PM Thread Starter
The lift points are used? (BY the way your car is really clean and nice -- the back of the car that is not stock correct? ) -- but very nice. I want to be sure where I put the 'included rubber blocks' are you using the large ones etc?? could you perhaps; sorry to ask so much; detail the spots where the blocks lift the car? from what I can see it looks in line with each other correct? front to back?
thank you - Charles
post #11 of 14 (permalink) Old 08-16-2019, 02:52 PM
wmf246's Avatar
a thought.... I see the 'jacks' are not anchored or restrained from moving, so why can't you slide them to the proper angle to pick up the required lifting point pads
Bill
wmf246 is offline
post #12 of 14 (permalink) Old 08-16-2019, 03:16 PM
Because they rotate as ther raise. The lift cylinder imparts a rotation to the rear. If they are not aligned, the motion, which is several inches, will result in unstable forces as the jacks side motion works against each other. They need to be parallel with each other so there is no side mogipn
post #13 of 14 (permalink) Old 08-18-2019, 07:54 AM
sjw
sjw's Avatar
thank you - Charles
The rubber blocks are very close to the factory lifting points. Im using the shorter blocks due to the reduced ground clearance on my car. The front of the jacks are slightly inboard. The jack has always operated smoothly up and down with the lifts in this position. I would take some pics for you but I no longer own the car. The rear valance is a Norms Fiberglass piece.
DDM Backbone
Kapasphere ReBar
BG Racing coilovers
sjw is offline
post #14 of 14 (permalink) Old Today, 10:07 AM
jwvess00's Avatar
Hello,
I have the QuickJack 5000SLX and have used it to lift my Solstice more than once. My car has been lowered a bit, and I use the short blocks that come with the lift. This lift also works on my '82 Chevy S10 truck and my '17 WRX. The WRX is a bit tricky since it uses the pinch block lift blocks, and they can be a bit fussy to align.
Jay Vessels
jwvess00 is offline
