Radio/CD display not working - Pontiac Solstice Forum
 2Likes
  • 2 Post By 1955c1d6
post #1 of 8 (permalink) Old 09-11-2019, 10:46 PM Thread Starter
1955c1d6's Avatar
Our 2008 GXP stock radio/CD display decided to not light up when the CD or radio is turned on. The radio functions but you get no readout as to station or CD info. Wondering if anyone has experienced this problem and what might be a potential fix. We have a 2008 GXP w/16,000 miles.We have had all the recalls done.
Last edited by 1955c1d6; 09-11-2019 at 10:48 PM. Reason: can't get the attachment correct
1955c1d6 is offline
post #2 of 8 (permalink) Old 09-12-2019, 04:33 AM
Is the DIC (Driver Information Center) display visible?
To get your picture to display correctly try saving it as a different name, then attaching it. It sounds crazy but usually works.
JohnWR is online now
post #3 of 8 (permalink) Old 09-12-2019, 05:54 AM
^ What John said... check the dimmer control first.
If not that, try a BFH... err ... sorry ... try tapping on the front center of the radio in case the front panel connectors have become dirty
post #4 of 8 (permalink) Old 09-13-2019, 10:58 AM Thread Starter
1955c1d6's Avatar
John, yes the displays on the consol behind the steering wheel are working. The only thing that is not working is when you turn the radio/cd on there are no lights showing on the radio screen. Strange but same thing happened on my 2007 F150. We never had it checked out to find out why. I wonder if it is just the led components of the time burning out?
1955c1d6 is offline
post #5 of 8 (permalink) Old 09-13-2019, 11:00 AM Thread Starter
1955c1d6's Avatar
Tomato, tried tapping and the dimmer switch but radio lights are still not functioning. Dare I take it to the dealer?
1955c1d6 is offline
post #6 of 8 (permalink) Old 09-13-2019, 01:30 PM
Just to be clear, the button backlights are not working, but the radio display *is* working? Or neither display nor backlights are working?
In either case it's unlikely that ALL the LEDs failed at once. I suspect that it's the faceplate that has failed. Good news (if you are up to the DIY) you can pretty much buy any radio that has the same display and swap out the faceplate circuit board (there's just clips and a couple of screws holding it all together).
If I were you, before I did anything else, I'd just open up the dash, take out the radio, take off the faceplate and put it back on and try it again -- just to clean the connector.
See also: https://www.solsticeforum.com/forum/...b-radio-62652/
post #7 of 8 (permalink) Old 09-14-2019, 08:39 AM Thread Starter
1955c1d6's Avatar
That worked! (that or the threat of taking her to the dealer.) All is good. Apparently just making contact. I guess I will have to use the car more.....
TomatoSoup and CycleCat like this.
1955c1d6 is offline
post #8 of 8 (permalink) Old 09-14-2019, 05:15 PM
chickenwire's Avatar
To follow up, if you use the "aux" jack - don't leave the cable plugged into it - it will oxidize and the contact gets wonky - similar to what you just experienced with the face plate.
chickenwire is offline
