I did a search but didn't find anything. I have an 07 GXP with the 5 speed. When I am on the freeway doing about 65 and slowly push the throttle to the floor, I get no boost and very slow acceleration. If I lift a little and then stomp on it, 1 get 15 psi of boost and lots of acceleration. I am new to small displacement turbo engines. I grew up in the age of large displacement V8's. Is this normal or do I have a problem.
I guess it depends on what you mean when you say that you "slowly push the throttle". Mine seems to accelerate proportionally to pedal displacement. If I push it what I consider very slowly its acceleration matches pedal movement without needing boost. As long as it works when you "stomp it", I wouldn't worry.
So John are you saying that suddenly this is a change from the norm in your GXP or that the way the GXP is 100% new to you and you're unsure if it is the way it's supposed to work?
15 psi is fairly representative of the norm in my experience, but your elevation can affect that...in Florida I'd say you're close to sea level. I live fairly close to the ocean and see 15psi as a normal thing, but the range has been 14-18psi depending (two different GXPs), before I installed the GM turbo upgrade tune in my previous GXP. Afterwards I'd see 18-22psi.
I grew up with big V8s as well. Mounds of torque is a sensation that is distinct. You have a really nice flat torque curve in your GXP, but it's not the same as a V8 with tons of low end torque. Turbo cars will experience lag to some extent. In my experience the manual trans Sol GXP has about as much turbo lag as a family sedan's auto trans downshift.
You have a variable vane turbo and a variable valvetrain and a blowoff valve in your GXP. But that won't completely negate turbo lag. Soon you will adjust to the way this car drives. I think you'll find the gear spilts (if manual trans, I never drove an Auto Solstice of any type so I can't comment there), the torque curve- which is damned near flat- and the final drive ratio are a really nice combo, but you will need to expect a touch of turbo lag.
Related Threads
Pontiac Solstice Forum
1.4M posts
38.2K members
Since 2003
