Starting issue - help? - Pontiac Solstice Forum
 5Likes
post #1 of 59 (permalink) Old 06-26-2019, 09:35 PM Thread Starter
Northern Sol's Avatar
Hello all,
Not sure what is happening with my 2007 “Mean Machine” GXP. Went to start her today. Depressed clutch, turned key and nothing. No sound or clicking like when you try to start her and battery is weak. Did it again and she started right up. Drove her and stopped after 30 minutes. Started her up again no prob. A bit of background....have had this happen a few times ( three or four times if memory is correct) over the last year. Battery died last week. I am guessing from a lack of driving ( I was away for a week in the Coupe). I boosted it, then trickle charged it and took her for a good 90 minute drive three days ago. All good. Put a new battery in her 4 years ago.
She is stored 6 months each year with battery disconnected. When I woke her up in the spring and connected the battery she started right up. A couple of weeks later battery died ( I had not driven her much since winter hibernation) Could my battery be on its last legs after four years? Appreciate all thoughts / feedback.
Thanks.
Mods: too many to list!
The Mean Machine
The Ace of Spades
Northern Sol is offline
post #2 of 59 (permalink) Old 06-27-2019, 04:38 AM
It does sound like a battery issue
post #3 of 59 (permalink) Old 06-27-2019, 04:43 AM Thread Starter
Thanks Rob.
The Mean Machine
The Ace of Spades
post #4 of 59 (permalink) Old 06-27-2019, 04:46 AM
phil1734's Avatar
Check all the battery connections. Both battery terminals, chassis ground, starter cable, etc.
2007 Solstice GXP
#3 ASP, DET and NWOR SCCA
phil1734 is offline
post #5 of 59 (permalink) Old 06-27-2019, 05:21 AM
sirwm's Avatar
Originally Posted by Northern Sol View Post
...Could my battery be on its last legs after four years? ...
I'd say 'yes'.
not all batteries are created equal.
some have lasted 12 years, others 12 weeks.
But double checking the battery connections as suggested above is a good idea too
Sir William's Fleet
sirwm is offline
post #6 of 59 (permalink) Old 06-27-2019, 09:43 AM
chickenwire's Avatar
Clutch interlock switch could be the culprit.
chickenwire is offline
post #7 of 59 (permalink) Old 06-27-2019, 09:54 AM
easyryderca's Avatar
If you pull it out Northern you can take it in & get it tested for a bad cell. When i changed mine i had it done at the dealership & had them check the charging system at the same time. I use a trickle charger on mine all year round. Good luck.
easyryderca is offline
post #8 of 59 (permalink) Old 06-27-2019, 02:03 PM
The mistake is disconnecting the battery!!. It should be left on the car and a trickle charger put on it.
LatinVenom is offline
post #9 of 59 (permalink) Old 06-27-2019, 02:19 PM
There are people, and I think NS is one of them, who do not have access to power where they store their car. For them, disconnecting is the only valid option.
And I assume that you mean battery maintainer and not literally a trickle charger, as a trickle charger can easily overcharge and damage a battery.
I do suggest disconnecting power at the underhood fuse block instead of at the battery.
post #10 of 59 (permalink) Old 06-27-2019, 04:06 PM Thread Starter
I know. I have no access to power.
The Mean Machine
The Ace of Spades
post #11 of 59 (permalink) Old 06-27-2019, 05:54 PM Thread Starter
Happened again today. She started right up ...all good. Went to Supermarket ( parked in the middle of no where of course) .... came back and nothing. Turned the key again and she started right up.
By the way. Thank you to everyone for weighing in on this. This is a truly amazing forum with so many knowledgeable members. A tremendous resource.
The Mean Machine
The Ace of Spades
post #12 of 59 (permalink) Old 06-27-2019, 06:05 PM
My Father's Ford Escape had this problem for years. Finally chased down the ignition switch gremlin.
In my 1970 Buick, this will happen, and it's a mechanical transmission gear selector issue. If you burnish the contacts by going through the gears (auto on the column) it will start up in a nanosecond. But otherwise, it's like trying to start in 'drive'. This of course is not your problem, but I mention it to illustrate the wacko things that can happen that aren't the battery.
Gone but not forgotten:
ChrisBlair is offline
post #13 of 59 (permalink) Old 06-27-2019, 07:06 PM
When it doesn't start, what happens when you switch to run, before trying to crank?
post #14 of 59 (permalink) Old 06-27-2019, 07:13 PM Thread Starter
Nothing. Turn key...no sound no nothing. Turn her back and turn key again she starts right up as normal as can be?
The Mean Machine
The Ace of Spades
post #15 of 59 (permalink) Old 06-27-2019, 08:51 PM
The problem could be the ignition switch, but another possibility is the run/crank relay (51) in the underhood fuse block. It powers quite a lot.
Making sure it is seated is easy to do, and unplugging it and plugging it back in may help. You can rule it out if the transmission is in reverse and the backup light is on.
