Starting issue - help? - Page 4 - Pontiac Solstice Forum
 5Likes
post #46 of 59 (permalink) Old 07-04-2019, 04:42 PM Thread Starter
Northern Sol's Avatar
Originally Posted by chickenwire View Post
Glad you found the solution. For $200.00 I'd come up to the great white north and change it out for you! lol
Hey, I’m in Windsor so not far. Come on over. I might even be south of you. (Lol)
Mods: too many to list!
The Mean Machine
The Ace of Spades
Northern Sol is offline
post #47 of 59 (permalink) Old 07-04-2019, 05:14 PM
John - is it a "proximity" sensor? Honestly I understand the function of the "switch" but didn't know if it was a physical "switch" or a sensor.
It sends a 0-5V signal to the BCM, but I do not know if it is solid state or some sort of variable resistor. The manual doesn't say what it is, only what it does.
post #48 of 59 (permalink) Old 07-04-2019, 06:30 PM
I had the same problem...push started...took it to my mechanic...replaced battery...everything is good now.
Larrygun is offline
post #49 of 59 (permalink) Old 07-05-2019, 06:57 AM
Are you sure it's an analog level device? Both of my schematics (2006 NA & 2008 GXP) show it as a simple switch.
Also, but slightly unrelated, a google search seems to indicate it is a commonly used device - so common that AutoZone (etc) carries them: https://www.autozone.com/electrical-...ntiac/solstice. And see description from O'Reilly's: https://www.oreillyauto.com/detail/b...solstice?pos=2
post #50 of 59 (permalink) Old 07-05-2019, 07:36 AM
Are you sure it's an analog level device? Both of my schematics (2006 NA & 2008 GXP) show it as a simple switch. .........
I was, but now you are making me question myself. You can be sure that I will check tonight.
post #51 of 59 (permalink) Old 07-05-2019, 08:09 AM
chickenwire's Avatar
I wouldn't be surprised if it was a common switch, especially if it's only $12.00. (You can bet your a$$ if it were Solstice specific it would be a helluva lot more expensive!)
chickenwire is offline
post #52 of 59 (permalink) Old 07-05-2019, 03:25 PM
Are you sure it's an analog level device? Both of my schematics (2006 NA & 2008 GXP) show it as a simple switch......
Well, I have now either learned to not assume that anything was kept consistent from year-to-year, or to not trust my service manuals. Or both.
I will definitely be checking the year more thoroughly in the future.
My 2006 Solstice and 2007 Sky Service Manuals both identify the clutch pedal position devices as simple switches.
My 2008 M-Car Service Manual identifies it a an analog sensor. Either my manual or yours is incorrect, but I have not yet looked to see what I actually have.
Name:	08-09-034 2.0 Sensors.jpg
ID:	98005   Click image for larger version
Name:	08-09-342 2.4 sensors.jpg
ID:	98007   Click image for larger version
Name:	08-17-366 CPP Relearn.jpg
ID:	98009   Click image for larger version
Name:	08-17-367 CPP Relearn.jpg
post #53 of 59 (permalink) Old 07-05-2019, 05:47 PM
numbbers's Avatar
Weak Battery
Originally Posted by sirwm View Post
I'd say 'yes'.
not all batteries are created equal.
some have lasted 12 years, others 12 weeks.
But double checking the battery connections as suggested above is a good idea too
Down here in the desert, my batteries last 3 years max. I have tried optimas but they do not last any longer. Now I just buy the cheapest battery I can find.
TomatoSoup likes this.
Thanks, Dave Russell
Mallett #33
VIN #1G2MB35B27Y106697
Platinum Pearl over Deep
Ebony Leather
Custom Arelli
numbbers is offline
post #54 of 59 (permalink) Old 07-31-2019, 09:54 PM
Hi all. New to the forum partly because I'm at wits end. 2008 GXP that won't always start. As others have noted, dash lights and radio come on then I turn the ignition and nothing. I've had it towed 4 times because of this. Mechanic diagnosed as clutch ignition switch? He has replaced twice but it still is happening. He showed me that I can turn ignition and jump on clutch a few times until it cranks. That saved me a tow bill tonight but this is really frustrating. Thoughts?
Radiodude1! is offline
post #55 of 59 (permalink) Old 08-01-2019, 06:44 AM Thread Starter
Went to dealership yesterday and the wrong part came in. Will go back in two weeks when new part arrives. I am not freaking out as she is not acting up as much. As per advice from dealership I make sure I depress clutch hard and all the way down. She then, 95% of the time starts up right away. Will update once part arrives.
The Mean Machine
The Ace of Spades
post #56 of 59 (permalink) Old 08-01-2019, 09:27 AM
If the radio turns off while you are holding the key in the start position, the ignition switch is working.
Pumping the clutch pedal suggests the the (switch or sensor) on the pedal is not working, and may need to be (adjusted or calibrated). It may also be loose, so you could contort yourself under the steering wheel to check it.
Do you know what they ordered, or what it should have been? As I read the manuals, the '07 is supposed to be a switch, but the '08 is analog. TS had some different information, so I am really curious about what you actually have.
post #57 of 59 (permalink) Old 08-01-2019, 12:07 PM Thread Starter
Hello JohnWR,
They ordered a “clutch pedal position switch”. That was not what was needed. They have now ordered a “clutch pedal start switch”.
The Mean Machine
The Ace of Spades
post #58 of 59 (permalink) Old Yesterday, 08:58 AM Thread Starter
Went to the dealership this morning. Told them that she has started every time with no issue for the last two weeks since they adjusted clutch. They told me not to bother replacing part. They said that sometimes when you adjust the clutch that is the end of problem. They are going to hang on to part and if this happens just once ......back to dealership she goes for the part. At this point, I am saving about $200 not getting this done. I like my dealership. Gus Revenburg Windsor. I am doing a road trip in a month so plenty of time to monitor doing local driving. The money can go towards new shoes for my Coupe.
The Mean Machine
The Ace of Spades
post #59 of 59 (permalink) Old Yesterday, 09:09 AM
easyryderca's Avatar
Glad to hear your problem may be solved .
easyryderca is offline
