245/45/18 vs. 255/45/18 -- Front and/or Rear, Any Issues? - Pontiac Solstice Forum
 1Likes
post #1 of 18 (permalink) Old 02-11-2017, 12:33 PM Thread Starter
I am going to purchase new Bridgestone Potenza S-04 Pole Position tires for the 08 GXP. Question is, does it make any sense for a "summer only" low mileage driver of the GXP like me to buy 255/45/18s for the rear. The 255s are just .4" inches wider and there plenty of room for that in the rear and have the same sidewall height. As these tires are "unidirectional" I'd be stuck with leaving them on the rear unless I had them remounted and rebalanced for rotation to the other side. Even with 245s all around I can at least move them to front. Any thoughts?
WEB INFO:
The S-04 is a unidirectional asymmetric tire, the inside of which is tuned for wet handling, and the outside for dry (this is absolutely not a tire for winter driving; it is described as a “summer” tire by Bridgestone). The wide inside grooves are designed to provide rapid water evacuation, improving drainage of excess water from the rib area into main grooves for hydroplaning resistance. High silica (silicon dioxide) content improves traction in wet conditions by increasing flexibility of the tread compound.
The outside section of the S-04 is tuned for dry handling, and according to Bridgestone, the footprint is optimized for even contact pressure across the whole tread surface. Compared with the RE050A Pole Position, the S-04 Pole Position has wider, stiffer shoulder blocks to help maximize road contact and precision handling through corners.
Additionally, the S-04 features an interlocking centre rib that also improves responsiveness and handling, along with a higher stiffness centre block and a rayon body ply for high speed durability.
As with other Bridgestone tires, the S-04 uses a Resonance Noise Attenuated (RENOA) silencer groove to help minimize noise and provide a quiet ride.
ColoradoGXP is offline
post #2 of 18 (permalink) Old 02-11-2017, 06:08 PM
A.J.V's Avatar
From what I've learned while researching tire size if it fits on the back, you'll have no trouble fitting it in the front. Most will suggest a square setup (same size front and back) because you can still rotate, and it will keep the performance balanced. I went with a staggered setup because I wanted that look. I have 275's in the rear and 245's in the front.
A.J.V is offline
post #3 of 18 (permalink) Old 02-11-2017, 07:16 PM Thread Starter
A.J.V, did you notice any for change in handling with the staggered setup? Better, worse or the same? Agree the look would be better.
post #4 of 18 (permalink) Old 02-11-2017, 08:25 PM
kwtoxman's Avatar
If you want optimal handling never go over the max recommended rim width for any specific tire. Look at the specific tire manufacturer specs for the recommended rim width range. FWIW most 255's are too wide to be recommended for 8 inch width wheels.
Sting Ya likes this.
kwtoxman is offline
post #5 of 18 (permalink) Old 02-12-2017, 04:01 AM
A.J.V's Avatar
I didn't get a before baseline, nor have I pushed it after the new wheels to see what's different.
A.J.V is offline
post #6 of 18 (permalink) Old 02-12-2017, 11:08 AM Thread Starter
Good to know, will stick with 245s.
post #7 of 18 (permalink) Old 02-12-2017, 11:26 AM
stuck's Avatar
Been running 255s for years with 0 issues. The only thing is that it throws the speedo off 3-4 mph. Didn't stagger them, though.
It's sticky!!!
stuck is offline
post #8 of 18 (permalink) Old 02-12-2017, 11:38 AM
wspohn's Avatar
Good call to stick with stock size.
Consider spending $40 more a tire and getting the Michelins PSS.
1958 MGA Twin Cam (race car)
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #9 of 18 (permalink) Old 02-12-2017, 10:55 PM
skersfan's Avatar
Buy the 71R and leave the SS's where they belong. lol
Bill have you tried the Potenza RE71R tire. I really do not think there is a comparison between the two tires. I have the SS's on my stock Redline and Potenzas on my tuned Redline. Drive them back to back, and I really do not like the SS's. I have to run 38 pounds in them to keep them from feeling like silly putty. I know the autocrossers mostly use the Potenzas, very few SS's. But other than that I only know Robo has the 71R's.
skersfan is offline
post #10 of 18 (permalink) Old 02-13-2017, 08:13 AM
wspohn's Avatar
The PSS have a wear rating of 300 while the 71Rs have one of 200, so will wear out more quickly. The 71Rs are better for slalom, but don't have as good a wet rating as the PSS. Wet is a real factor up here in the rain forest, so for me the PSS were the better choice. Different story for the guys that live in southern climes or never drive in the wet.
I ran Bridgestones on the track in years past, but nothing at all recent so have no personal experience with the 71R.
http://www.autos.ca/auto-product-rev...re-shootout/2/
So which tire would I buy with my money? To be honest, whichever one is on sale at the time. Both tires perform amazingly well both on and off the track with an on-track advantage for the Bridgestones and an on-road advantage for the Michelins.
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #11 of 18 (permalink) Old 02-14-2017, 08:16 AM
What the aspect ratio on the tires? 4-5MPH at what speed?
post #12 of 18 (permalink) Old 02-14-2017, 08:30 AM
wspohn's Avatar
Stock tires have a diameter of 26.7"
255x45s have a diameter of 27" so off by 1.1%, not bad
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #13 of 18 (permalink) Old 02-14-2017, 08:46 AM
stuck's Avatar
...4-5MPH at what speed?
Since DDM has my car, I can't give you a break down at different speeds, but at 70, it's about 3 miles off from my Garmin.
It's sticky!!!
stuck is offline
post #14 of 18 (permalink) Old 02-14-2017, 10:05 AM
AKA SolWhat?
DaveOC's Avatar
My box stock 2006 NA is always 3-4 mph faster than the speedo, regardless of speed. If the speedo says 45, the real speed is 48. If the speedo reads 75, I'm probably doing 78.
I discovered this before I had a GPS device, and the GPS confirms the real speed.
It's just another of those things that makes my Solstice unique!
1st 1K - #741
DaveOC is online now
post #15 of 18 (permalink) Old 06-02-2017, 10:32 PM
DoUSail2's Avatar
AVJ, what are your wheel sizes including offset?
__________________________________________________ ________
Wife's car: 2007 GXP Manual Envious/Tan top - Purchased 4/29/17
My Car: 2009 Pontiac G8 GT Pacific Slate Metallic - Premium
NA, Cammed, top end build on stock bottom end
12.27 @ 114.6 with DA of 561 and 1.92 60 ft.
77 LeMans Can Am (Sold after 25 years)
2001 WS6 Trans Am M6 (Traded for G8)
DoUSail2 is offline
