Attention: For no heat/over heat issues - Page 2 - Pontiac Solstice Forum
 1Likes
post #16 of 168 (permalink) Old 11-25-2009, 12:46 PM
Small Dealer's Avatar
Eyeno reports the final piece of this puzzle will be out the end of next month.
Originally Posted by Eyeno 11/25
The cooling system on the 2.0L Solstice/Sky is completely different than anything you may of seen in the past. Drilling a hole, of any size, in the thermostat will not correct the no heat Ė over heat condition. When your DIC is reading 245 deg, turn on your heater blower. If cold air is coming out of the heater, the problem is the result of air in the cooling system that will not purge. In every case Iíve reviewed the cooling system was opened on a warm/hot engine when the engine was turned off. When you open the coolant recovery system on a hot engine, you can hear the air being sucked into the system.
This condition can be corrected by installing two check valves in the cooling system. The information and part number for the valves will be available to your GM dealer sometime towards the end of December.
INFORMATION POSTED ON SITE
Small Dealer is offline
post #17 of 168 (permalink) Old 11-25-2009, 01:02 PM
Jebsmith's Avatar
I saw that... So how do I drive my car until then? This new info seems crazy to me.
V-8 B8
Jebsmith is offline
post #18 of 168 (permalink) Old 11-25-2009, 01:06 PM
Unitl something changes, one goes with the current information and procedures.
post #19 of 168 (permalink) Old 11-25-2009, 02:03 PM
that's great mom, I wonder if I actually needed a thermostat, when they replaced mine they obviously purged the system and that might have been all it really needed
well done
perris is offline
post #20 of 168 (permalink) Old 11-25-2009, 02:10 PM
sd, my radiator was never opened and I had the problem, I guess it could have been opened at the dealer but I doubt it, I believe I had the experience even before my very first service
anyway, I think I had hot air when I turned the heater on but I never did let it get to 145 degrees, the funny thing about our car, when you turn the heater on the engine temperature actually goes up not down, I suppose this might be becuase coolant scavenged to go to the heater coil?
don't know, purely speculation, maybe you do know and that would be good info if you could post it
perris is offline
post #21 of 168 (permalink) Old 11-25-2009, 03:21 PM
Jebsmith's Avatar
I have an appointment that I will keep for tuesday. Start a paper trail. But, I don't want to pay for this flush and then pay for the check valve procedure a month later.
V-8 B8
Jebsmith is offline
post #22 of 168 (permalink) Old 11-25-2009, 03:44 PM
If that is the case, do not have the check valves installed when they become available.
post #23 of 168 (permalink) Old 11-25-2009, 04:21 PM
Jebsmith's Avatar
true, but if the check valves are a permanent fix, maybe i should just wait for them
V-8 B8
Jebsmith is offline
post #24 of 168 (permalink) Old 11-25-2009, 04:26 PM
JeffInDFW's Avatar
There is a guy on the Sky forum that bought a brand new Sky recently, and 6 miles from the dealership the overheat light came on. He checked the temp, and it was very very high. Stopped, turned car off. Let it cool. Got it back to dealer, and nobody can get it to recur. Sounds like this air problem. So, either it had this problem from the factory, OR during make ready, someone in the shop opened the overflow can and let air in the system.
I just had one of my cars inspected, and the people checked all my fluids. If I had been there with my Sky, they would have opened the overflow can to check my coolant level, and I would have been screwed. My point is, this is going to be a problem going forward, even for people who do not have it today. At SOME point, someone is going to pop that overflow reservoir lid and let air in your system.
JeffInDFW is offline
post #25 of 168 (permalink) Old 11-26-2009, 06:55 AM
Jebsmith's Avatar
That is so true. Sounds like the vac n fill is more like a Temp fix and the check valves are permanent.
V-8 B8
Jebsmith is offline
post #26 of 168 (permalink) Old 11-26-2009, 11:36 AM
Jpdub's Avatar
Jeb,
My issue was taken care of by the dealer under warranty. I gave them a copy of the TSB when I went in to install the Stage II and the problem is now gone. If they give you any flack about doing it under warranty, just let them know that the alternative of potentially serious engine damage from overheating would be under warranty...their choice.
Jpdub is offline
post #27 of 168 (permalink) Old 11-26-2009, 06:42 PM
Both procedures will take car of a car that has had the cooling system improperly opened.
It is just expected that the installation of check valves, which will most likely recommend the vac n fill during the procedure, will reduce/eliminate the chance that another inproper opening will allow air into the system.
post #28 of 168 (permalink) Old 11-26-2009, 06:48 PM
There has been no TSB issued to cover this topic. As posted, one is expected near the end of December.
Also, the warranty excludes damaged cause by "Improper Maintenace". So the threat may not work.
post #29 of 168 (permalink) Old 11-26-2009, 06:56 PM
...when I went in to install the Stage II......
One site member reported that when they installed the kit themselves, upon removing the original sensor, a rush of coolant came out of the previously removed lower hose.
So it is possible that the kit install could be a source or air introduction into the engine.
So it should be watched until it can be confirmed either way.
post #30 of 168 (permalink) Old 11-26-2009, 07:37 PM
Does this apply to the 2.4 engine also?
Kappster is offline
