cigarrette lighter fix - Pontiac Solstice Forum
post #1 of 4 (permalink) Old 06-13-2019, 08:51 PM Thread Starter
For anyone with a non-functioning cigar lighter/power port.
The socket to my cigar lighter was missing. Only the plastic housing and cap were there. I fished the two wires out of the hole without removing any trim. There was a black ground and a red/white hot wire.
I bought a GM socket/special tool at Advanced Auto Parts for about $16 in stock. This socket is 7/8 inch in diameter and fits right into the plastic housing. They did not have the connector I was also missing so I bought very small female crimp terminals and pried them a bit to fit on the socket's hot and ground terminals. There was no 20 amp fuse in terminal #30 of the engine fuse block, so I put one in and everything went live.
Total cost - about $18.00
kentlarue is offline
post #2 of 4 (permalink) Old 06-14-2019, 03:58 AM
What is the GM socket special tool.
rob the elder is online now
post #3 of 4 (permalink) Old 06-14-2019, 08:33 AM
joybill44's Avatar
It is a T shaped tool that fits inside the power socket to engage the two small plastic detents in the socket. It isn't really special to GM. Usually, if you buy a dorman replacement socket , you get the tool with it. I just use a small screwdriver instead. If you look inside the socket, you will see two small ( about 3mm square) black plastic detents, one on each side of the socket. Depress these and the socket will pull out.
Bill.
joybill44 is offline
post #4 of 4 (permalink) Old 06-14-2019, 07:51 PM
Cool. Did not know that
