Cooling Fan Failure - GXP (Variable Speed?) - Page 3 - Pontiac Solstice Forum
post #31 of 89 (permalink) Old 03-14-2015, 08:45 AM
Supporting info... Another guy on the KappaPerformance forum tried the same thing (Crown Vic controller) and also reported it working: Engine Fan control module
post #32 of 89 (permalink) Old 03-22-2015, 07:04 PM
All I had the same issue, bad controller.
alternates available:
china 50 bucks including shipping 15 day delivery -
100% factory New 902 209 Radiator Fan Control Module/Relay RR28 6W1Z8B658AC/ 940002904-in Air-conditioning Installation from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
Dorman 902-209 Radiator Fan Control Module/Relay
oriely autoparts: $192.99 Each (Part Number: RR28)
Rockauto - 100 bucks
APDTY 013310 Radiator Fan Relay (Replaces Ford 6W1Z-8B658-AC RR28)
2007 GXP
good luck all - hope this helps someone.
PS- do not buy the radiator fan assy from Rock auto for 78 bucks (says it is fo turbo but is not - have to send mine back :>(
Stinger28 is offline
post #33 of 89 (permalink) Old 03-22-2015, 09:32 PM
Good info.
Thanks
post #34 of 89 (permalink) Old 03-30-2015, 01:04 AM
Sorry for the late update but the Crown Vic controller is still working
CFL-GXP is offline
post #35 of 89 (permalink) Old 03-30-2015, 02:13 PM
Jn2
That si great news summer is here and mine has been bad for a while, so to confirm, you ordered this one?
RY1532 Fan Control Relay Module Fits Ford Crown Victoria Town Car Marquis | eBay
if so I'm buying it like NOW
Solstice GXP
K04r, Term2 tuned, ZZP DP, Hahn intercooler, SA charge pipes, K&N intake
Jn2 is offline
post #36 of 89 (permalink) Old 03-31-2015, 05:29 PM
That is the module I ordered
CFL-GXP is offline
post #37 of 89 (permalink) Old 03-31-2015, 06:18 PM
Jn2
Perfect I ordered it, life saver you are. I was about to bypass the module completely by making a relay harness that plugs into the fan motor directly. Bypassing the module
Solstice GXP
Jn2 is offline
post #38 of 89 (permalink) Old 03-31-2015, 08:56 PM
tknsols's Avatar
I put the crown vic controller in a couple weeks ago working fine. Picked it up at napa auto parts
tknsols is offline
post #39 of 89 (permalink) Old 04-01-2015, 09:32 AM
2007 GXP
How much $ is the Crown Vic module, please?
Yogi
2008 Saturn Sky Red Line
5 Speed Stick, Chrome Wheels
Black with Black Top and Black Leather
Single Disk Monsoon
Yogi is offline
post #40 of 89 (permalink) Old 04-01-2015, 11:03 AM
SolNut's Avatar
Yogi, Ebay had them for under $40
eCar
SolNut is offline
post #41 of 89 (permalink) Old 04-01-2015, 12:13 PM
OK - Thanks, Steve.
Yogi
Single Disk Monsoon
Yogi is offline
post #42 of 89 (permalink) Old 04-03-2015, 07:46 PM
It works!
Just joined the Forum so i could tell you guys that i ordered the RY 1532 from ebay($33) on Monday. Installed thursday night and voila! Now my fan comes on. The original and new part looked identical. I figure out that the module was bad by just connecting leads from the battery to the fan pigtail. Fan turned on full blast. So i figured it was the controller. I wonder if the new Caddy ATS 2.0 have the same fan module. Doesnt buick have a turbo 2.0 in one of their cars as well. Might be another alternative if you can buy the controller on its own. Thanks for the help. Cut my price and hours of work by at least 2/3.
Mclemente88 is offline
post #43 of 89 (permalink) Old 04-05-2015, 12:55 PM
Jn2
Glad to hear this, i tested it the same way, i almost bypassed the module and made my own fan relay harness, figured 100% fan speed was better than 0%. I ordered mine during the week:
Expected Delivery Day: Saturday, April 4, 2015
well its sunday now....
Solstice GXP
Jn2 is offline
post #44 of 89 (permalink) Old 04-15-2015, 12:45 AM
Jn2
So I threw the new module on the car and the fans are working again, yay! exact same part.
Solstice GXP
Jn2 is offline
post #45 of 89 (permalink) Old 06-14-2015, 03:55 PM
duckSol's Avatar
Location: Roosting on the west central flyway in Colorado Springs
My fan quit and I found the 60 amp fuse blown.
Replaced the fuse and it worked fine for awhile then blew the fuse again.
Replaced fuse, then the temp climbed and I pulled over for a cool down and found coolant leaking from where I know now is the thermostat.
My theory now is the thermostat blew out from on and off high coolant temp caused by the failed module stopping the fan rather than the water pump which is what I am into now.
Long and short, keep an eye on these fans as they should be running when you shut down and carry extra 60 amp fuses and copper wire to jump blown fuse pins (Elmer Fudd sez "bwe berry, berry cwarefewl) as the potential high resistance from "Fudding" like this can cause lots of heat. Wire jumps are only for EMERGENCIES, not a "Fudd" fix.
My research says a resistor in the module goes high in resistance increasing amperage and blowing the fuse.
This can be checked with power supplied to the module. Dealers do it all the time which is where I got my info but why bother if the unit is constantly blowing the fuse. The module is BAD if it keeps blowing fuses.
Now be conservative about replacing the water pump as it is a pain. The thermostat can be a pain but change that if a puddle is there near the firewall and when you change it, boil it to make sure it works and drill a 1/16 - 1/8 hole in it.
If coolant is leaking towards the front, that's obviously water pump so do the thermostat too.
Thanks so much for the module sourcing information
Saves us po folks $$$
2012 Summer Solstice in the Land of Sky
duckSols Mods revised 9-4-09
Transformer SLY
"Okolemaluna"
duckSol is offline
