Cooling Fan Failure - GXP (Variable Speed?) - Page 4 - Pontiac Solstice Forum
post #46 of 89 (permalink) Old 06-22-2015, 07:26 AM
I need help I'm a bit of a novice but know enough to try to fix most simple issues myself.... I've read and re-red and re-read all the posts regarding over heating, I've installed the valves, removed the air from the lines all seemed well except when I was driving in slow traffic or at lights... I then discovered the fan stopped working.. I purchased the relay mentioned above (RY1532 Fan Control Relay Module Fits Ford Crown Victoria Town Car Marquis | eBay), installed it, and bam it threw a code after a few minutes. I don't recall the code something like 196...fan voltage.. something.. I can get it again, but I noticed that the fan plug is scorched and partially melted (fuse did not blow)... Did anybody else have this issue after purchasing the relay?
I have a 2009 gxp model. I need to now replace the fan and/or plug from the fan that connects to the relay.. I've searched the web, but I'm having a hard time finding what I need. Any links for a new fan and any suggestions on why this may have "blown" like this, and if anybody else had the same experience.
Jumbler is offline
post #47 of 89 (permalink) Old 06-22-2015, 09:45 AM
what i found so far
OK so from my post above I did some more searching and found a picture... I need number 4 in this pic... 2008 Pontiac Solstice ENGINE COOLANT FAN
anybody know if I can get that part alone or still need the full assembly? Trying to save as much money as possible, also still need suggestions advice on why this may have blown with the new relay on it. 2009 gxp
Jumbler is offline
post #48 of 89 (permalink) Old 06-22-2015, 10:24 AM
So, you want a new motor? Did the failure burn the plug on that new controller that you just installed? It could be that they are both fried. You would need a good DVOM to test the controller. With a fried fan connector, I
wouldn't connect that fan motor again unless I was sure that it was OK and the controller is the problem.
Yogi
2008 Saturn Sky Red Line
5 Speed Stick, Chrome Wheels
Black with Black Top and Black Leather
Single Disk Monsoon
Yogi is offline
post #49 of 89 (permalink) Old 06-22-2015, 10:47 AM
burn
Yogi
It burnt the plug to the fan motor. The controller had no burn marks that I could see. so I'm assuming all I need is to replace is the fan motor?? i'll find a DVOM and test the controller. I've put the old controller back on for the time being.
Jumbler is offline
post #50 of 89 (permalink) Old 06-22-2015, 11:18 AM
I would think that either the motor connector was burnt before (with old controller) or maybe wasn't plugged in tightly and arc'd. I cannot see how the controller itself was to blame (it's only switching 12V after all).
As for getting a new plug or motor, you cannot buy them new on their own. GM only sells the complete assembly at great cost.
Put up a WTB post for just the fan/motor. Others have had the controller blow and replaced the whole assembly, so may have the fan still. Otherwise a trip to the local scrap yard to pull an equivalent connector (obviously, Crown Vic's use them).
post #51 of 89 (permalink) Old 06-23-2015, 07:47 AM
crown vic fan
my local autoparts store o'reilly sells an 08 crown vic fan/motor for around 70 bucks...would this work to replace the fan/motor in an 09 solstice? I have not pulled the fan motor out of my 09 solstice yet, just thought I would post this inquiry as looking at the schematics they look very similar... any thoughts/suggestions?
Jumbler is offline
post #52 of 89 (permalink) Old 06-23-2015, 10:56 AM
Well the motor itself might not fit or have the same fan attachment. But at least you could cut off the connector and solder it on. I'd be sure to test that your motor still works though (hook it up to 12v and see if it runs - like from a battery charger)
post #53 of 89 (permalink) Old 06-23-2015, 07:30 PM
tested
Ok, tested the new controller with a Volt reader.... it went from 2.98 to 11 to .23 to 30 back to 2.45. Don't think this is right as the most it should be, to my understanding is a max of 10 volts and with it acting like that I would assume the new controller is bad.... So I tested the old controller.. got -0.00 nothing else... So I plugged a couple wires into the fan connecter (neg, positive) and connected those to the battery... nothing, fan does not turn on.... so I'm thinking at this point the fan is hosed (possibly due to the "new" controller) as well as both the old and new controller do not work.... I'm exchanging the new controller for another one... but I think I still need a new fan motor.... Thoughts/suggestions... help....
Jumbler is offline
post #54 of 89 (permalink) Old 06-23-2015, 07:42 PM
Sly Bob's Avatar
As TS said, use a couple of wires and hook the fan motor directly to a 12 volt source to see if it works but you said you've done that already. If the motor is dead you will need to get a fan motor as well.
You sure the wires weren't backwards when testing the fan?
Born April 30, 2008
Delivered on May 27, 2008
Sly Bob is offline
post #55 of 89 (permalink) Old 06-23-2015, 10:23 PM
Bills86e's Avatar
The fan controller relay is also used on the 2007 Ford Crown Victoria. I bought one for $31.
Bills86e is offline
post #56 of 89 (permalink) Old 06-24-2015, 07:37 AM
Most modern controllers work by outputting a voltage that is "PWM" (Pulse Width Modulated). That is, the voltage cycles constantly between on-off-on-off.... The speed of the motor is determined by the ratio of length of time that the voltage is on compared to how long it is off. Of course, you also have to give the controller a signal that says "Turn on the fan motor X percent" in order to get a PWM output.
Your new controller may be fine. If the fan motor does not work when connected directly to a 12 v. source, I would say that is your problem, or at least a place to start.
Yogi
Single Disk Monsoon
Yogi is offline
post #57 of 89 (permalink) Old 06-24-2015, 08:24 AM
well I'm gonna have to break down and get the entire assembly as I cannot find just the fan motor... and after all my tests it appears i'll need another controller and the motor anyway.... I'll be sending the defective controller I got on ebay back to the seller.
Jumbler is offline
post #58 of 89 (permalink) Old 06-25-2015, 06:55 AM
Thanks for all the insight and suggestions everybody. I ordered the entire fan shroud assembly as it appears to be the fan and I am unable to find just the fan/motor and.... I can't go without my car any longer...
Jumbler is offline
post #59 of 89 (permalink) Old 06-26-2015, 07:56 PM
Lucky45's Avatar
So I got a question for all you Solstice gurus...
Fan wasn't working today so the car overheated. While I was waiting for the tow truck I found this thread. I have a pretty good relationship with the service department at the local Chevy dealership so I showed them all your findings about the Crown Vic's relay working on a Solstice GXP. They said to grab on and they'd use it if needed. Anyways, the only one I could find locally was:
Dorman OE Solutions 902-209 - Radiator Fan Relay | O'Reilly Auto Parts
Not nearly as cheap as the ones on eBay nor do they look the same but I was tight on time. So is it safe to assume they work the same?? Plug and play??
Lucky45 is offline
post #60 of 89 (permalink) Old 06-29-2015, 08:56 AM
So I pulled the fan/shroud assembly while I wait for the new one to arrive... and just on a whim I tried testing the fan again (connecting to battery) I got a spark.. fan didn't kick over so this intrigued me so I wiggled the fan plug a bit tried to locate any possible disconnected wire or plug.. and nope... then accidently dropped the fan while setting it down, retested and the fan kicked on.... then stopped.... I was confused... so I tried testing again and the fan would not come on... so I hit the back of the fan motor with a wrench... plugged it back in and the fan came on, shot out a bunch of black soot and remained on.. I unplugged it, plugged it back in and it remained on... unplugged it again and plugged it back in... nothing turned on.... hit it again, still nothing turned on... did get a small spark when touch the wires to the battery.... sooo I'm not sure, is this a bad fan still or is there something in the "under the hood" fuse box that might be shorting out, other than the 60 amp fuse as this is fine... reason I'm thinking the fuse is fine is because with the fuse out, then testing the plug the relay goes in I get 0 volts, plug the fuse back in test the relay and I get a contstant 12v. Again, is this the fan and its shorting out or is there something else in that "under the hood" fuse box I can test.... I did notice when the fan did kick on there was a clicking in that fuse box area.... like something was "flipping" on. ??????
Jumbler is offline
