Did I blow a gasket?? - Page 6 - Pontiac Solstice Forum
 29Likes
post #76 of 76 (permalink) Old 07-14-2019, 02:38 PM
So, for HP Tuners:
Credits are tied to the car's VIN *and* the HP Tuners interface (MPVI) based on its serial number. Once you use the credits for that car, you can re-flash it as many times as you want as long as you're using the same interface. (Some people call it a "cable," but it's really an embedded computer that plugs into the OBD-2 port.) You can switch PCs, etc. as many times as you want, reflash all you want, as long as it's the same physical interface and same VIN.
For the Opel Injectors:
When editing the calibration in the HPT VCM Editor application, set the Injector Constant (under Injector Control / Flow Rate) to 0.02471.
Under [ECM]12308 - Injector Offset vs Pressure Delta vs IGNV, you'll find a table labeled "Pressure Drop (MPa)." It's a table with 12 columns and one row. Set the following values
Column | Value
0.2 | 0.0420
0.4 | 0.0420
0.8 | 0.0450
1.4 | 0.0480
2.3 | 0.0510
3.5 | 0.0530
5.0 | 0.0560
7.5 | 0.0590
10.0 | 0.0620
12.5 | 0.0770
15.0 | 0.0920
18.0 | 0.0950
Or, see the attached image. (Courtesy of the nice guys at ZZP.)
I've had better experience with Dave Gilbert's tunes than with some other vendors. Also, his tunes are not locked, which is a Very Good Thing. Even though you've already put quite a bit of cash into this, I think the $375 for Dave's tune is worth it. I just installed the big wheel K04 from Werks yesterday along with their tune. The performance difference is substantial.
If you get a tune from any vendor, make sure you tell them that you're running an LDK with the Opel injectors. They should make the required changes in the tune before they send you the first round. Dave will have you drive and log some stuff, send the logs to him, and he'll make whatever changes are required and iterate.
For E85, the tune has to be adjusted, and I think you need the right HPFP if the LDK didn't come with it. I've seen quite a few mentions of using the C7 Corvette HPFP, but I haven't gone down that path yet so others would be more qualified to answer. If you can get the part number off of the HPFP on your new engine, you can look that up to see if it's E85 (or "flex fuel") compatible. If so, it should be fine.
Similar Threads
Why did you choose the color of Solstice that you did? BANDITCAR General Solstice Discussion 52 06-30-2008 10:37 AM
How Many Did Or Did Not Test Drive Gxp Before Purchasing dave clancy Solstice GXP Discussion 34 03-31-2007 05:53 AM
When did you cut your GXP loose? When did you begin to watch the boost (psi) gage? GXPinKC Solstice GXP Discussion 13 01-11-2007 08:04 AM
Mr Gasket FireSol General Tech, Platform Common Issues & Solutions 2 07-10-2006 03:17 PM
