Engine died, replaced batterythromycin now no crank. - Page 5 - Pontiac Solstice Forum
 27Likes
post #61 of 148 (permalink) Old 08-03-2019, 10:35 AM
The relays are reversible, with one set of diagonal pins for the coil and the other for the contacts.
JohnWR is online now
post #62 of 148 (permalink) Old 08-03-2019, 10:47 AM Thread Starter
McDoug's Avatar
No good, no change
ECM?
McDoug
2009 Solstice Street Edition W/Spoiler, Automatic, stock with the exception of DDM CAI and Windrestrictor, 38k miles.
Build date 09/08
McDoug is online now
post #63 of 148 (permalink) Old 08-03-2019, 01:09 PM
Originally Posted by McDoug View Post
No good, no change
ECM?
Do you get a click from the relay? Do you have voltage at the fuse with the relay plugged in?
post #64 of 148 (permalink) Old 08-03-2019, 02:00 PM Thread Starter
McDoug's Avatar
No click from the relay in either location. See post 43, the readings are the same.
I will go through your check list again tomorrow just in case I missed something or something has changed.
McDoug
Build date 09/08
post #65 of 148 (permalink) Old 08-03-2019, 02:10 PM
Did your Alldata give you anything different for the electrical circuits? Another move would be to check continuity from the ECM plugs to the UFB plug or to the fuses.
This is unfortunately looking more and more like a bad ECM.
post #66 of 148 (permalink) Old 08-03-2019, 07:18 PM Thread Starter
McDoug's Avatar
Alldatadiy.com was pretty dismissive when I informed them of the issue, and refused to respond when I asked if they could contact thier sources, I even offered to provide my vin to help.
McDoug
Build date 09/08
post #67 of 148 (permalink) Old 08-04-2019, 09:18 AM
I worked for a company that used OE data, it's impossible for them to, on a whim, "contact their sources". It takes weeks if not months usually to get an answer back for a question. It used to take us over a week to get a response from Ford on part number issues (and we were the part catalog for over 75% of their dealers!!). I'm not saying Aldata hasn't contacted them, if they have, you might not get an answer for a week or two...and they won't let you know anything in the mean time.
post #68 of 148 (permalink) Old 08-04-2019, 11:22 AM Thread Starter
McDoug's Avatar
Ghost, and that's fine and I understand that, what gets under my skin is attitude. Just say sorry, can't help you as you just very ellaquently put it, that's all.
McDoug
Build date 09/08
post #69 of 148 (permalink) Old 08-06-2019, 02:39 PM Thread Starter
McDoug's Avatar
I finally gave up on Saturday, I thank everyone for their help (especially JohnWR, Ghost, Raygun). I figure either I missed something or it's the ECM. I spent Sat / Sun looking for someone that could bench test it.
Dealer wanted
$100+ to check it but he can't bench test if so I'd have to deliver the car to him, ($50 ish to truck it)
$400+ for a new ECM
Probably 1 hr to install it at $100+.
And that's assuming that it is the ECM and they don't spend a lot of time replacing parts until they find it.
So I was looking at maybe $650 or more if I let the dealer do it.
I finally found a company an hour drive from me that rebuilds all sort of auto electrical and electronics. If they can't find or fix the problem it will still be cheaper than the dealer and they suggest I will have it back by the Friday, the dealer wouldn't even look at it until Thursday or Friday.
So, keeping my fingers crossed.
McDoug
Build date 09/08
post #70 of 148 (permalink) Old 08-06-2019, 03:33 PM
Bama's Avatar
Is the part number for that ECM #24239785 for a 2009 NA base?
If so, I found one for $273.00.
I found a place that has hard to find parts for our Solsti.
Just An Ordinary Average Guy
With A Super Cool Car!
Bama is offline
post #71 of 148 (permalink) Old 08-06-2019, 05:12 PM Thread Starter
McDoug's Avatar
BAMA, no but thank you.
E37 12629018
McDoug
Build date 09/08
post #72 of 148 (permalink) Old 08-07-2019, 04:01 AM
tygriff's Avatar
Before giving up on a new ECM, you may want to search alternate part number on the ECM. Its GM #12612397. You will see that this number is the SERV#.
When you search by this part number, you can see lots of choices. GMpartsdirect has it for $223. Rockauto has it for $260. Summit racing is only $184
tygriff is offline
post #73 of 148 (permalink) Old 08-07-2019, 05:56 AM
Those ECMs will have to be taken somewhere, whether a dealer of a well-equipped shop, to be programmed with the vehicle's VIN. That will cost between $50 and $200.
The next step really should be to get a scanner plugged in to it to find out what the problem really is.
post #74 of 148 (permalink) Old 08-08-2019, 10:00 AM Thread Starter
McDoug's Avatar
I'm told that my ECM is dead and a replacement (remanufactured) will cost me $400 so I am shopping!
McDoug
Build date 09/08
post #75 of 148 (permalink) Old 08-08-2019, 10:33 AM Thread Starter
McDoug's Avatar
Summit Racing, new, plug and play, overnight for just over $200. Need to do key relearn.
McDoug
Build date 09/08
