Help. Car wont start - Pontiac Solstice Forum
 3Likes
  • 1 Post By raygun
  • 2 Post By JohnWR
post #1 of 4 (permalink) Old 05-15-2019, 04:22 PM Thread Starter
Just replaced the Head Gasket, turbo, both chains, and catalytic converter. Now car wont start. It's an 08 automatic GXP. I have fuel pressure and I have spark. I found something about the ground on the front of the engine and cleaned that off. Any help would be appreciated.
frisos1 is offline
post #2 of 4 (permalink) Old 05-15-2019, 04:53 PM
Injectors firing?
yevgenievich is offline
post #3 of 4 (permalink) Old 05-16-2019, 07:50 AM
Security system, air, fuel, spark, compression.
I assume you don't have a security light on? (Yellow pad lock symbol in the instrument cluster.) If you're really getting spark, then this probably isn't the issue.
We'll assume you're getting air (as opposed to having a rag stuffed in the intake somewhere).
Did you properly reconnect the injector harness (to the injectors and to the main harness)? Check fuses & relays?
Last thing would be to perform a compression test. The numbers will be off since the engine is cold, but it's an easy test and may reveal the problem.
easyryderca likes this.
raygun is online now
post #4 of 4 (permalink) Old 05-16-2019, 08:29 AM
Also check that the throttle body and MAF sensor are properly connected and that the throttle plate is actually opening.
easyryderca and raygun like this.
JohnWR is online now
Similar Threads
Car wont start shabby General Tech, Platform Common Issues & Solutions 4 09-02-2017 05:01 PM
My 08 Solstice is registering a U0100 Lost Comm. with ECM/PCM Module A :wont start dennmon General Tech, Platform Common Issues & Solutions 23 05-03-2014 08:15 PM
GXP wont start FieroVin General Tech, Solstice GXP Specific 21 08-05-2013 06:08 AM
Car wont start. Not the battery Pauliewog General Solstice Discussion 26 06-09-2008 04:35 PM
07 gxp wont start Doro General Tech, Platform Common Issues & Solutions 2 01-29-2008 05:12 PM
