Help understanding permament OBD fault - Pontiac Solstice Forum
post #1 of 8 (permalink) Old 05-24-2019, 02:29 PM Thread Starter
bottom line up front- the car passes all inspection criteria, and today. The car is throwing no OBD DTCs.
But I noticed on my paperwork a Permanent OBD fault code: 7F 0A 11
I think (just think) this means a false-positive error for an unsupported fuel pressure.
Anybody have better info?? Can't find it on 'search' here, google-fu turns up more questions than answers.
Gone but not forgotten:
ChrisBlair is offline
post #2 of 8 (permalink) Old 05-24-2019, 02:48 PM
No idea. Sorry
post #3 of 8 (permalink) Old 05-24-2019, 03:01 PM
As far as I know, the Kappa does not have permanent fault codes. They were phased in starting in 2010, so i don't know why they would show up for any of our cars.
post #4 of 8 (permalink) Old 05-24-2019, 03:19 PM Thread Starter
That's what it reads on my Massachusetts State Vehicle Inspection Report. Very last entry:
OBD Permanent Fault Codes
_________________________
7F 0A 11
I've found ref to 'general fault' 'unsupported' and 'fuel pressure'. Also found ref to mode 7 being for 'unconfirmed fault codes', useful for check after repair, so a long test period wouldn't be needed.
Maybe the inspection software is looking for something, cannot find it since it isn't supported, and reports a false positive. Had it done at a Cadillac dealer.
post #5 of 8 (permalink) Old 05-24-2019, 04:04 PM
And what did the dealership say when you asked them about it?
Bert
ECOBOOSTEC is offline
post #6 of 8 (permalink) Old 05-24-2019, 04:59 PM Thread Starter
didn't notice until I got home
post #7 of 8 (permalink) Old 05-24-2019, 05:21 PM
A permanent fault is one that a scan tool will not reset, and that will not reset when the battery is disconnected. It does not cause a MIL and it would not be cause for emissions failure assuming that the other parameters are satisfied. It will be reset when the ECM records a sufficient time/distance/cycles to indicate that the fault is actually gone.
Since our ECMs pre-date their roll-out, I don't see how one can be recorded. It could be that the testing software shows that to indicate that the feature is not available in that ECM.
post #8 of 8 (permalink) Old 05-24-2019, 06:10 PM Thread Starter
Sorta what I've been thinking all along. "Unsupported" probably refers to the unit under test not having a possible feature, it's a "permanent" thing since the ECM doesn't have it and never will, and the specific reason is probably dependent on a cyclic/algorithmic/timeout issue during which the test software performs some task, be it time, number of tries, or similar, and my roulette wheel lands on 11 for whatever reason. I expect to see this with every inspection I have for the car.
I was never worried about it, just curious. Thanks for guessing along with me. We'll probably never know exactly what is happening, but I am very curious to see if any other MA owners get a similar result. I also wonder if the test equipment in MA is the same as the test equipment elsewhere. Never thought about it before.
Similar Threads
OEM parts - Need help understanding values... downingracing General Solstice Discussion 4 07-09-2014 11:48 AM
Help With Obd Ii Message flaj General Tech, Platform Common Issues & Solutions 5 03-30-2007 11:01 AM
Carrier Replacement / Fault tree Chip General Tech, Platform Common Issues & Solutions 3 07-26-2006 02:45 PM
Digital radio, understanding the options hagenaer General Solstice Discussion 3 09-20-2005 07:30 AM
