New engine. new problems! - Pontiac Solstice Forum
 21Likes
post #1 of 41 (permalink) Old 03-17-2019, 07:44 PM Thread Starter
I just put a new crate engine in my 07 GXP. It fired up fine, then after a couple minutes started throwing codes and "reduced engine power". P2138, P0449, P2544, and C0561. I'm also getting the service stabilitrak, abs, etc.
I had this problem when I first got the car, but it ended up being the battery.
Am I missing a ground or something simple. It runs fine, but every couple of starts, it has no throttle response. (None, not delayed)
Thanks for any help in advance!
2007 Solstice GXP Mysterious/Darkside
2014 Camaro ZL1 6 Speed
2014 Silverado LTZ Z71
2014 Silverado 2500HD
2000 Silverado RCSB Lifted on 35's
2017 Sonic RS
2001 Newmar Mountainaire 4095
1998 Seadoo Challenger 1800
[email protected]
Carver1 is offline
post #2 of 41 (permalink) Old 03-17-2019, 08:35 PM
My guess is its electrical. There is a ground on the front of the head. Are you sure you got a good ground.
Sting Ya likes this.
post #3 of 41 (permalink) Old 03-17-2019, 08:58 PM Thread Starter
I did check the engine ground. it's good. I also have zero boost. not sure if it's a cause or effect....
2017 Sonic RS
[email protected]
Carver1 is offline
post #4 of 41 (permalink) Old 03-17-2019, 09:14 PM
ChopTop's Avatar
Location of all the grounds
https://www.solsticeforum.com/forum/...rounds-127585/
ChopTop is offline
post #5 of 41 (permalink) Old 03-18-2019, 10:51 AM
So, you've got:
P0449 : Evaporative System Vent Control Circuit Malfunction
P2138 : Throttle/Pedal Position Sensor/Switch "D"/"E" Voltage Correlation
P2544 : Torque Management Request Input Signal "A"
C0561 : Traction control
* C0561-71 System disabled. Information stored. Invalid serial data received.
* C0561-72 System disabled. Information stored. Alive counter incorrect.
Is this an auto or a manual?
I would:
0. Check your harness connectors at the ECM. Make sure they're firmly clamped down.
1. Check all of the grounds (mentioned in ChopTop's link above) and ensure that they're clean and correctly attached
2. Check your battery terminals, also to make sure they're clean and properly connected. (An bad negative battery connection can act like a flaky ground),
3. Make sure the wiring harness is firmly seated where it connects to the bottom of the engine bay fuse box. I spent a week chasing that one after swapping an engine.
4. Make sure the big (4" x 2" x 2", roughly) harness connector that's near the fusebox is firmly connected. It has one of those lever-action camlock things that secures to two pieces together.
5. Make sure all of your fuses and relays are properly seated.
And, of course, check the harness connectors for the evap, throttle and wheel speed sensors.
But, typically when you see multiple failures like this, it's a ground.
P2138 indicates that there's an intermittent or bad connection involving the throttle body, the pedal and the ECM.
post #6 of 41 (permalink) Old 03-18-2019, 11:58 AM Thread Starter
Replacing the battery tomorrow and will check all those connections this evening! Thanks for the help! Btw, it’s an auto.
raygun likes this.
2017 Sonic RS
[email protected]
Carver1 is offline
post #7 of 41 (permalink) Old 03-18-2019, 05:29 PM
Charge your battery.
Now a few other questions....
Did you replace the ECM?
BCM?
Wiring harness?
Here's why I ask...an '07 ECM is not compatible with an '08 or '09. Motor shouldn't matter, but harnesses, etc will. Did your motor have a harness already installed? Was it for an '08 or '09? If so, there's your problem.
post #8 of 41 (permalink) Old 03-18-2019, 09:50 PM Thread Starter
Everything is the same from the original car except the engine itself. I had to reuse the accessories, as well as the intake manifold/throttle body. I'll toss in a new battery and see what happens.
Every time I clear the codes, I get the same codes back, but not always all at once. Some codes are intermittent, but the reduced power is always there. Hoping it is just a battery! The only thing that is different from when the car had the original engine is the long block.
2017 Sonic RS
[email protected]
Carver1 is offline
post #9 of 41 (permalink) Old 03-18-2019, 09:56 PM Thread Starter
Hang on fellas! We have a winner! I guess when I put the fender liner back on, this little guy worked its way loose. No I have no codes, but the battery light is on. Seems to run fine. I'll replace the battery and see what happens!
Thanks everyone!
Sting Ya, ChopTop and raygun like this.
2017 Sonic RS
[email protected]
Carver1 is offline
post #10 of 41 (permalink) Old 03-18-2019, 10:37 PM
Before you replace the battery, I'd disconnect the negative cable, crank the engine (it won't turn over, but it'll clear any residual charge in those pesky capacitors that are everywhere), reconnect the battery and see what happens. Basically, this is trying to tell the ECM "Hey, I know you're mad, but I fixed it. So, chill."
Takes 10 minutes and it could save you some cash.
Carver1 and Sting Ya like this.
post #11 of 41 (permalink) Old 03-19-2019, 01:32 AM
znaut's Avatar
Thanks everyone!
Make sure that battery light isn't actually the low coolant light. It looks just like a battery to me. When I first got my car I chased non existent battery problems for a while until I figured out my coolant was actually low lol.
Carver1, showtime and raygun like this.
znaut is offline
post #12 of 41 (permalink) Old 03-19-2019, 02:46 PM
ChopTop's Avatar
Is this recommend anytime the battery is disconnected?
ChopTop is offline
post #13 of 41 (permalink) Old 03-19-2019, 02:56 PM
It's probably not necessary, but it's a good way to make sure that there's no residual charge in the system. Depending on where and what you're working on, you could potentially get a nice little shock if that's not done. To be honest, I've only done this once or twice under very special circumstances.
I had an issue on another car where, apparently, a cap keeping something on that really needed to be off. If you do something that requires serious current - like trying to start the car - it'll discharge any capacitors on that circuit. It's also faster than waiting 10 minutes after disconnecting the battery which isn't guaranteed to work, anyway.
In other news: the headlights on an 05 Boxster S are not fused.
ChopTop likes this.
post #14 of 41 (permalink) Old 03-19-2019, 07:09 PM
I know it's problem solved, just figured i'd chime in with my 2 cents on the subject for any future readers
I had the EXACT same set of codes popping up on my 07 solstice
It would start just fine, but somewhere between 15 seconds to several minutes later the dash would light up and i'd get reduced power and all that jazz
replaced battery,
replaced pedal sensor,
cleaned TB,
cleaned ECM harness connector,
gave up and took it to the dealership
they called me 15 minutes later
The culprit was one wire in the harness from the ECM, it had developed a crack and the wire itself was damaged. Replaced the harness. Problem solved
Worst part was I thought it was something really serious and I actually drove the car like that for 4 months!! Just puttering around town with the rev limit and no boost because I didn't want to hear that my baby would have to be put down
Carver1 and raygun like this.
Zanepaul is offline
post #15 of 41 (permalink) Old 03-23-2019, 09:59 PM Thread Starter
Well, the original problem has been fixed. It was just the harness connector loose.
Now I have the battery light issue...
Battery has been replaced. Alternator tested off the car. everything good.
The battery light comes on about a minute after starting. It stays on constant while driving.
Hooking up the tester at the parts store says the alternator is not charging. It also says the batter is almost dead. But the car drives fine, starts fine. No issues other than the actual light on? I'm down to thinking it is a wiring issue. Any ideas where to start?
2017 Sonic RS
[email protected]
Carver1 is offline
Similar Threads
New engine problems rmahoney General Tech, Solstice GXP Specific 7 04-11-2016 07:59 PM
New engine problems j.e.jones jr. General Tech, Solstice GXP Specific 4 07-17-2014 09:02 AM
P0336, P0338 Crankshaft problems dealer suggests new engine JBGXP General Tech, Solstice GXP Specific 9 03-16-2014 01:02 PM
Problems and more problems! MyNewSolstice General Solstice Discussion 19 05-29-2006 11:17 AM
problems problems problems mybaby General Tech, Platform Common Issues & Solutions 43 04-19-2006 07:12 PM
