help I Need info on fuse - Pontiac Solstice Forum
post #1 of 7 (permalink) Old 07-19-2017, 10:13 AM Thread Starter
Preadus's Avatar
My Stereo is dead. I checked the wires and have no power to the battery wire. I can't locate any fuse for the stereo to even check. The space that the manual shows for stereo fuse in 23 is empty. Its a 2007 GXP.
Any help would be appreciated.
Thanks
Preadus is offline
post #2 of 7 (permalink) Old 07-19-2017, 10:39 AM
AKA SolWhat?
DaveOC's Avatar
Thanks
You are looking at the fuse box under the passenger footboard, right?
#23 in the fusebox under the hood is normally empty.
From the owner's manual page 327:
Floor Console Fuse Block
The floor console fuse block is located on the
passengerís side of the vehicle under the carpet.
Remove the fuse block cover to access the
fuses. Use the fuse puller to remove fuses.
After re-installing the fuse block cover, be sure to
tuck the carpet under the heater floor outlets.
Hope this helps.
1st 1K - #741
DaveOC is offline
post #3 of 7 (permalink) Old 07-19-2017, 12:02 PM Thread Starter
Preadus's Avatar
Cool i had no idea there was another fuse block there.
Preadus is offline
post #4 of 7 (permalink) Old 07-19-2017, 12:09 PM
AKA SolWhat?
DaveOC's Avatar
It's also known as the BCM, Body Control Module.
FWIW, a lot of owners don't know about this extra "fuse box".
1st 1K - #741
DaveOC is offline
post #5 of 7 (permalink) Old 01-10-2018, 04:06 PM
Did the fuse solve your dead radio? I have the same issue in my new to me Solstice. My fuses all check out.
Amanda11270 is offline
post #6 of 7 (permalink) Old 01-10-2018, 04:28 PM Thread Starter
Preadus's Avatar
If I remember correctly it was a small amp fuse either 2 or 3 amp that is in the box on the passenger side floor.
Preadus is offline
post #7 of 7 (permalink) Old 12-24-2018, 08:42 AM
I am trying to replace an aftermarket head unit with an updated one in a 2007 solstice gxp and everything is working except that a have no sound from the speakers. I suspect that the monsoon amp is not turning on and donít know why. Am I missing a bad fuse somewhere? I have checked the fuse block under the hood and the interior one in the passenger footwell.
Steeleye is offline
