Manual to Auto Conversion - Pontiac Solstice Forum
 2Likes
  • 1 Post By JohnWR
  • 1 Post By rob the elder
post #1 of 7 (permalink) Old 01-30-2019, 02:20 PM Thread Starter
Saveaux's Avatar
A car that came with manual door locks and windows - can this be converted to automatic by changing out the door internals....or will the ECM need to be changed as well?
My father's car came with manual but found a salvage yard that will sell him the doors for a song.
Saveaux is offline
post #2 of 7 (permalink) Old 01-30-2019, 02:34 PM
Seems to me the only issue would be your fobs and the BCM not programmed for the locks, assuming BCM's are programmed for each specifically configured Kappa and not a one-size-fits-all type BCM. Do your fobs have door lock/unlock buttons?
SkyPilot is offline
post #3 of 7 (permalink) Old 01-30-2019, 03:08 PM
Power windows would be relatively simple since "all" you would need is power to the driver's door and wiring connecting it to the passenger's door.
Remote Keyless Entry is probably going to need a Remote Control Door Lock Receiver, unless the car has TPMS, in which case it may only require programming. And wiring. The doors will have the internal wiring, but you will need the vehicle body harness as well.
Programming will have to be done by a dealer or someone with a Tech2 and access to TIS2WEB. And the programming may be VIN specific, so it may not even work.
I guess he can get the body harness, BCM, and RCDLR from the salvage yard as well, but it will still be a lot of work.
An alternate approach would be an aftermarket RKE system using the actuators from the salvage doors.
raygun likes this.
post #4 of 7 (permalink) Old 01-30-2019, 04:27 PM
ChopTop's Avatar
Calling Tomato Soup
ChopTop is offline
post #5 of 7 (permalink) Old 01-31-2019, 09:00 AM
While you're digging into the wiring and installing motors and what not, why not try this?
post #6 of 7 (permalink) Old 01-31-2019, 09:29 AM
He could have at least picked a good car.
raygun likes this.
post #7 of 7 (permalink) Old 01-31-2019, 09:40 AM
Originally Posted by ChopTop View Post
Calling Tomato Soup
I am trying to decide if I should feel insulted by this.....
Maybe he didn't want to risk a "good" car. Or maybe he used what he had.
Similar Threads
Manual Vs. Auto Trans Kel3420 General Solstice Discussion 10 04-05-2008 07:30 PM
Trade in auto trans for manual ? SamGuy24 General Tech, Platform Common Issues & Solutions 5 09-03-2007 10:43 PM
Dilemma Deep Manual or Aggressive Auto mcronec5 Getting Your Solstice 21 08-28-2007 11:08 AM
Auto vs Manual firedup General Solstice Discussion 66 08-26-2007 04:39 AM
GXP Manual VS Auto yellowSOLofTX Solstice GXP Discussion 92 08-21-2007 02:50 PM
