Stereo Install Costs - Pontiac Solstice Forum
 7Likes
post #1 of 31 (permalink) Old 05-02-2019, 10:19 PM Thread Starter
NYC_Sol's Avatar
So I have all the parts I need to install my pioneer mvh-1400NEX & backup camera but I just haven’t had time to do it so I was going to get a quote from a local place to do it. They quoted me $500!!! Did the cost of car stereo installations go way up or is this guy just trying to rip me off? Feels like the later. The pioneer radio is only $350 new.
2007 SLY w/ Ebony Leather & Top
Power | Convenience | Polished w/ Polished Caps | LSD | ABS | A/C | 6-Disc w/ MP3 | Monsoon | XM
GMPP CAI | GMPP Cat-Back Performance Exhaust | Kappashield | 2.55" Stubby | Kappapouch | GXP Alum Sill Plates | GM All Weather Mats & Splash Guards
My mother said to me, "If you are a soldier, you will become a general. If you are a monk, you will become the Pope." Instead, I was a painter, and became Picasso. ~Pablo Picasso
NYC_Sol is offline
post #2 of 31 (permalink) Old 05-03-2019, 12:44 AM
Do it yourself, it's pretty easy 5 minutes to remove the old radio + 2-3 hrs to install the aftermarket head unit
SSolstice is offline
post #3 of 31 (permalink) Old 05-03-2019, 04:59 AM
sirwm's Avatar
... don't forget the time to take the dashboard apart...
Sir William's Fleet
sirwm is offline
post #4 of 31 (permalink) Old 05-03-2019, 06:07 AM
Even a professional doing a particular car for the first time is going to take 4-6 hours to get the installation done, especially with a wired backup camera, so $500 does not seem completely unreasonable.
I would get a second quote, then decide if a day of your time is worth $500. And, of course, the time and effort needed for the installation has nothing to do with the cost of the component being installed.
I wondered if the Solstice was that much easier than the Sky. It took me almost an hour to get to the radio the first time, and even the second time took a half hour.
After that it was 5 minutes to get out, but then it took another hour to put everything back together, so 2-3 hours total would be about right.
I haven't run the wires for the cameras, but I am expecting at least another couple of hours for that.
post #5 of 31 (permalink) Old 05-03-2019, 06:33 AM
showtime's Avatar
As seen with our water pumps.
showtime is offline
post #6 of 31 (permalink) Old 05-03-2019, 06:46 AM
Just bought a Pioneer AVH-601EX, I am in the same boat, also has an aftermarket amp in the trunk professionally installed by the previous owner, I bought the kits to retain steering wheel control and chimes, hopefully the install goes smoothly! May attempt this weekend
Zinger is offline
post #7 of 31 (permalink) Old 05-03-2019, 06:48 AM
Solstice *is* pretty easy. Pop the gauge rings and pull the tunnels; Pop off and unclip the shifter trim ring; pop the panel behind the grab handle, undo 2 bolts, rotate handle out and off; pop the boomerang clips all the way round; lift boomerang up enough to unplug the 12V accessory connector and then pivot it up and tie it up to the roof clip (or you can disconnect all the other connectors and remove it completely - but not necessary). Boom - everything is exposed. Takes maybe 10 mins tops, once you've had practice.
NYC_Sol likes this.
post #8 of 31 (permalink) Old 05-03-2019, 07:23 AM
Just follow what tomato soup wrote. The last time I removed the factory radio it took me 3 mins, but it was my third time doing it lol. There is a video on YouTube on how to remove the dashboard/boomerang.
NYC_Sol likes this.
post #9 of 31 (permalink) Old 05-03-2019, 10:30 AM
sirwm's Avatar
...Takes maybe 10 mins tops, once you've had practice.
ah... yes...
Sir William's Fleet
sirwm is offline
post #10 of 31 (permalink) Old 05-04-2019, 05:46 PM
D289421's Avatar
The first time I removed the boomerang, I pulled the gauge rings and tunnel off; however, the next few times I did it I realized it's unnecessary. Otherwise TS's instructions are great if you're interested in doing it yourself.
David
06 Mysterious - Totaled
07 Mysterious GXP
D289421 is offline
post #11 of 31 (permalink) Old 05-05-2019, 05:09 AM
wmf246's Avatar
the biggest problem I had was deciding how to run the camera wire to the head unit (had to drill a hole...), and then where to tie into the reverse light....
Bill
wmf246 is offline
post #12 of 31 (permalink) Old 05-05-2019, 08:53 AM
Bill
How did you route the cable? I have just started looking at options.
post #13 of 31 (permalink) Old 05-05-2019, 09:54 AM
wmf246's Avatar
the plug to the head unit was kinda big, so the hole had to be sized accordingly, we closed the hole with RTV but I suppose an appropriate grommet could be used. fished the power wire to the right rear backup light (but it might be possible to pick the backup wires out of the harness somewhere.
routed the wire to the head unit around the trunk and across to the center behind the seats and then down and along tunnel to dash/radio.
I spaced the camera out past the license plate light so the license plate light didn't interfere with the camera
if the new head unit has gps, the antenna can be tucked in an empty spot above the head unit
Bill
ID:	95399   Click image for larger version
ID:	95401   Click image for larger version
ID:	95403   Click image for larger version
ID:	95405   Click image for larger version
wmf246 is offline
post #14 of 31 (permalink) Old 05-05-2019, 10:38 AM
Thanks Bill. That does look like the best route. I am considering getting power directly from the BCM, but haven't decided yet.
post #15 of 31 (permalink) Old 05-05-2019, 10:58 AM
$500 including wiring a backup camera doesn't seem outrageous to me. Cleanly installing the camera and properly routing the wire to the dash can involve a good bit if interior dismantling. $500 for just a head unit does, though. I swapped mine out to a 2010 OEM with USB input and I don't think it took more than an hour (maybe it's easier on a Sky?).
But I live in Seattle where we just got bids to replace a hot water heater that ranged from $2500 to $4000 (I ended up doing it myself).
lorennerol is offline
Similar Threads
BIG car stereo install... here's what I used. Fortimir Mods - Audio & Etc. 6 06-22-2019 10:41 PM
New Stereo Install (Pioneer MVH-1400NEX) NYC_Sol Mods - Audio & Etc. 1 03-30-2018 12:12 PM
Stang's Sol. Now in stereo! [GXP exhaust install] stang Mods - Interior/Exterior Functional/Appearance 9 08-03-2009 11:02 AM
Additional Solstice Costs Adrenaline General Solstice Discussion 7 06-10-2005 10:12 PM
upgrade costs newfan General Solstice Discussion 3 05-12-2005 09:27 AM
