3D Printing Discussion - Page 5 - Pontiac Solstice Forum
 45Likes
post #61 of 315 (permalink) Old 09-18-2017, 08:31 PM Thread Starter
working a complex print using water soluble support material
ID:	74865   Click image for larger version
Name:	hydrofil three.JPG
ID:	74873   Click image for larger version
raygun likes this.
post #62 of 315 (permalink) Old 09-20-2017, 06:57 PM
chickenwire's Avatar
Finally got a chance to "finish" it.
rob the elder likes this.
chickenwire is offline
post #63 of 315 (permalink) Old 09-21-2017, 04:33 AM Thread Starter
Nicely done. Does it light up!
post #64 of 315 (permalink) Old 09-21-2017, 05:41 AM
Yes, with the lights in front of it shining down on it.
post #65 of 315 (permalink) Old 09-26-2017, 08:37 PM Thread Starter
By request, generated a turbo dash text thingie
post #66 of 315 (permalink) Old 09-27-2017, 05:50 AM
Rob - did you ever print the Sky version of the model I sent you? Just curious if it turned out alright.
post #67 of 315 (permalink) Old 09-27-2017, 07:13 PM Thread Starter
I was waiting for the other print to finish. I'm on it
post #68 of 315 (permalink) Old 09-27-2017, 08:54 PM Thread Starter
The test run of the Sky wall plaque is in progress. Will have pics tomorrow.
post #69 of 315 (permalink) Old 09-29-2017, 10:03 AM Thread Starter
Got a few of the Sky plaques printed. Painted one for a friend. Turned out pretty well.
ID:	75577   Click image for larger version
chickenwire likes this.
post #70 of 315 (permalink) Old 10-08-2017, 09:29 AM Thread Starter
Found seatbelt retention clip on thingverse
https://www.thingiverse.com/thing:2131348
post #71 of 315 (permalink) Old 10-08-2017, 09:30 AM Thread Starter
still printing plaques in colors
ID:	76305   Click image for larger version
ID:	76313   Click image for larger version
ID:	76321   Click image for larger version
ID:	76329   Click image for larger version
post #72 of 315 (permalink) Old 10-08-2017, 01:43 PM
Those are purdy
post #73 of 315 (permalink) Old 10-08-2017, 01:45 PM
Hey, here's an idea... remember those roof-open/close rub protection pads that a certain person ran a production of?
I wonder if they would work OK if 3D printed in nylon? Might they be too rough or not strong enough?
If I can fine my spare set (doh!) I could (maybe) make a print file using OpenScad, if it's worth the trouble.
post #74 of 315 (permalink) Old 10-08-2017, 05:07 PM Thread Starter
Should work. Let me know if you need a set
post #75 of 315 (permalink) Old 11-01-2017, 03:34 PM
Well, it's not a 3D printer, but in typical I-do-it-the-hard-way fashion:
(Warning: I'd turn the sound down before playing this.)
(Pardon the mess. With four kids, I can either clean, or make stuff. Though the mess has, I think, reached critical mass.)
If I had specs for the entire cup holder assembly, not just the part that breaks - apparently, the previous owner just took the whole thing out and tossed it - I'd make one. The plan is to make foam plugs for the hard top I have in mind, using the rubber and misc. trim bits from my old convertible top. The whole thing won't fit in the ~4' square cutting area, but I can cut in sections and include tabs to get the individual parts aligned.
Or I might go buy 3D printer and try and keep up with @Robtheelder.
The Corvette logo worked out better, but it's in MDF and pretty much 2D. The raised sections on the Pontiac logo are a little more challenging.
raygun is online now
