Converting a convertible into a coupe - Pontiac Solstice Forum
 13Likes
post #1 of 42 (permalink) Old 01-22-2019, 11:24 AM Thread Starter
WadeLinger's Avatar
Some of you may remember that I have made several major changes to my 2006 Solstice since I bought the car new in 2006. The first change was the LS7 / T56 engine swap. Next I designed and fabricated new bumpers, a hood scoop, and opened up the front fenders for a Cobra-style look. The latest modification is the conversion from convertible to coupe. This mod was made possible when coupe #802 was sent to a salvage yard and cut in half because of Lemon Law issues. I learned of the car and bought the back half and top several years ago. So the parts I used from the donor were practically new. All of the unique pieces and parts were there, including the unique plastic bits and pieces.
If anyone has any specific questions, I will be happy to answer.
Name:	Solbra CP Bumper On.jpg
WadeLinger is offline
post #2 of 42 (permalink) Old 01-22-2019, 11:32 AM
AKA SolWhat?
DaveOC's Avatar
Wow, that is quite nice. Well done! How about a few more pictures?
44thSKY likes this.
1st 1K - #741
DaveOC is offline
post #3 of 42 (permalink) Old 01-22-2019, 11:34 AM
Northern Sol's Avatar
Wow!!!!!!!!! She looks amazing. She is a masterpiece!!!! Love the white stripe. Have one on my black coupe. More pics from different angles if you can?
Mods: too many to list!
The Mean Machine
The Ace of Spades
Northern Sol is offline
post #4 of 42 (permalink) Old 01-22-2019, 01:07 PM
ChopTop's Avatar
Outstanding! More pics and video please. BTW, please consider offering the vented Solbra fender.
ChopTop is offline
post #5 of 42 (permalink) Old 01-22-2019, 01:24 PM Thread Starter
WadeLinger's Avatar
It was necessary to disassemble the car down to the frame rails in order to replace the tub. The hard part about that was avoiding damage to the rear fenders. As it turned out, we did have to remove the filler panels with the tub. With luck I was able to source two new filler panels to use during re-assembly.
ID:	93075   Click image for larger version
ID:	93077   Click image for larger version
ID:	93079   Click image for larger version
ID:	93081   Click image for larger version
post #6 of 42 (permalink) Old 01-22-2019, 01:31 PM Thread Starter
WadeLinger's Avatar
The mounting points behind the doors had to be fabricated, located, and welded in place. We made a template from the donor and then worked off of that.
ID:	93085   Click image for larger version
ID:	93087   Click image for larger version
ID:	93089   Click image for larger version
post #7 of 42 (permalink) Old 01-22-2019, 01:53 PM
Greatgab's Avatar
Amazing transformation... love those fenders!
2008 GXP Aggressive Red - SOL LVR - Trifecta custom switchable tune - DDM CAI/charge tubes/silicone hoses - Werks IC - Solo Hi-flow Cat/Mach Shorty exhaust - DDM Probeam/Backbone/Venom brace - Sprint Booster - Short throw shifter - Full LED conversion w/pulsating third brake light and sequential turn signals - SaddlX & GearTripR center console - Michelin Pilot Sport 4S
Greatgab is offline
post #8 of 42 (permalink) Old 01-22-2019, 02:12 PM Thread Starter
WadeLinger's Avatar
I was able to source a new tub from GM, so I did that instead of destroying the donor body just to save the tub. We glued it in place and then painted and installed the new filler panels.
ID:	93093   Click image for larger version
ID:	93095   Click image for larger version
ID:	93097   Click image for larger version
ID:	93099   Click image for larger version
post #9 of 42 (permalink) Old 01-22-2019, 02:18 PM Thread Starter
WadeLinger's Avatar
The next step was dry-fitting the top sections.
ID:	93103   Click image for larger version
ID:	93105   Click image for larger version
ID:	93107   Click image for larger version
post #10 of 42 (permalink) Old 01-22-2019, 02:24 PM Thread Starter
WadeLinger's Avatar
Next step, prep & paint.
ID:	93111   Click image for larger version
ID:	93113   Click image for larger version
ID:	93115   Click image for larger version
ID:	93117   Click image for larger version
post #11 of 42 (permalink) Old 01-22-2019, 02:25 PM
wmf246's Avatar
where did you get the coupe doors, or door glass?
Bill
wmf246 is offline
post #12 of 42 (permalink) Old 01-22-2019, 02:27 PM Thread Starter
WadeLinger's Avatar
More painting
ID:	93121   Click image for larger version
ID:	93123   Click image for larger version
ID:	93125   Click image for larger version
post #13 of 42 (permalink) Old 01-22-2019, 02:31 PM Thread Starter
WadeLinger's Avatar
I did not mention a lot of details such as moving the EVAP canister, extending some wiring, installing coupe window regulators and door glass, but final assembly was pretty standard stuff.
post #14 of 42 (permalink) Old 01-22-2019, 02:33 PM Thread Starter
WadeLinger's Avatar
Bill
The doors are the original convertible doors. I only changed the glass and the regulators. Both are readily available.
post #15 of 42 (permalink) Old 01-22-2019, 02:36 PM Thread Starter
WadeLinger's Avatar
The SOLBRA fenders are easily done. Just buy the vents from any of the Cobra replica parts places. Cut your fenders out and use epoxy to roll the edges. You might need to remove a little out of the back side of the passenger side vent to clear the battery.
ChopTop and raygun like this.
