End all, be all: Curt Trailer Hitch (and accessories) Thread - Page 11 - Pontiac Solstice Forum
 3Likes
post #151 of 163 (permalink) Old 03-17-2019, 04:05 PM
solman06's Avatar
Has anyone tried a turndown exhaust tip to keep the exhaust heat off of a rear cargo carrier? I have followed a lot of the hitch and cargo carrier discussions over the years and never seen this as a possible solution. I have an 06 NA Solstice - single exhaust. I installed a Curt receiver hitch years ago. I have had a carrier for a few years but never used it. If I install the carrier inline (actually it does have a small rise) it will be directly inline with the exhaust as many of you know. I have installed with a riser which solves that problem but creates another problem. Items on the carrier block the license plate. With the carrier installed inline or just above will a turndown tip solve the heat problem? Also with the carrier inline or just above, mounted close to the vehicle (no extender) would there be a possible dragging problem. I guess I could figure this out by trial and error but there is a lot of experience and wisdom to be had from forum members. I figure someone has already been there and done that.
Sly - everything but Onstar.
Mods - Clearbra 3M tape, splash guards, PCMforless.com custom dyno tune.
solman06 is offline
post #152 of 163 (permalink) Old 03-17-2019, 06:39 PM
Cmccomb1's Avatar
Is there a problem with the license plate being blocked?
Cmccomb1 is offline
post #153 of 163 (permalink) Old 03-17-2019, 07:43 PM
solman06's Avatar
It is my understanding that in many (if not all) states obscuring or blocking the view of a license plate is illegal and may get you a ticket.
solman06 is offline
post #154 of 163 (permalink) Old 03-17-2019, 07:58 PM
Cmccomb1's Avatar
Didn't know that. We drove to Nassam 2018 in Colorado from Illinois and back. Guess we got lucky!
Cmccomb1 is offline
post #155 of 163 (permalink) Old 03-17-2019, 08:07 PM
Knight's Avatar
I use my cargo carrier for runs to/from Lowes / Home Depot. I suppose if I use it for long trips, I might put the license plate onto the cargo carrier.
On the other hand we have driven all over the south with a our minivan and a bike rack carrying 4 bikes that definitely obscured the tag and we never have been stopped, so maybe I ought not worry about the cargo carrier.
2008 Saturn Sky Redline
Midnight Blue
Knight is offline
post #156 of 163 (permalink) Old 03-17-2019, 08:27 PM
solman06's Avatar
I guess it depends on the police officer. I have hauled bikes on racks that have obscured the plates many times myself and never got a ticket. But I believe in many states it is "technically" illegal. Someone please correct me if I am wrong.
solman06 is offline
post #157 of 163 (permalink) Old 03-18-2019, 06:29 AM
Not tried that, but it seems an expensive way to go.
In my case I just attached some strips of aluminum, cut off a roll of gutter flashing, to deflect the exhaust heat.
post #158 of 163 (permalink) Old 03-18-2019, 06:35 AM
solman06's Avatar
That looks like what most people have done TomatoSoup. Did it completely solve the problem? I just wondered if anyone had tried the turndown tip. Yes it would be more expensive and maybe difficult on a GXP because of the exhaust tip shape but I don't think it would be too difficult on a 06 NA.
solman06 is offline
post #159 of 163 (permalink) Old 03-18-2019, 06:50 AM
phil1734's Avatar
Are the exhaust exits really all that different? Or are there just two of them?
I personally don't care nearly as much as some here about the appearance of their car, but I imagine installing and removing turn-downs would almost certainly mar the finish on the tips over time, beyond even what I would consider acceptable.
2007 Solstice GXP
#3 ASP, DET and NWOR SCCA
phil1734 is offline
post #160 of 163 (permalink) Old 03-18-2019, 07:13 AM
Take your front plate (which should never actually be mounted on the car) and mount it to the trailer.
Saveaux likes this.
post #161 of 163 (permalink) Old 03-18-2019, 11:25 AM
mcurrier's Avatar
I photo copied my tag at 100% size, cut it out, put it in a plastic bag and then mounted it to the large cargo box that rides on the carrier with a chrome license plate frame (leaving the original attached to the car). Looks like the real thing. I also put some reflectors around the edges of the box.
Mark
2007 Aggressive GXP
Solo Street Race Exhaust
Side-panel Rebadge (GXP)
https://www.solsticeforum.com/forum/s...5&postcount=12
Curt 11119 Trailer Hitch
Trifecta Budget Tune
Drag Race #19 Wheels
https://www.solsticeforum.com/forum/a...507_105709.jpg
mcurrier is offline
post #162 of 163 (permalink) Old 03-18-2019, 02:05 PM
This may keep the obstructed plate from being noticed, but could cause more trouble if it actually is, depending on the mood of the officer involved.
post #163 of 163 (permalink) Old 07-26-2019, 07:22 PM
mike.robinmc's Avatar
Here is an option to consider for water-proof luggage. These are designed for equipment storage to keep the stuff inside dry. There is an o-ring seal on the cover and the snaps pull the cover very tight. I use these on some of my portable service equipment to keep them safe and dry when in the field. https://www.digikey.com/products/en/...=1&pageSize=25
And they are rated IP67 (Ingress Protection Rating) https://www.google.com/search?q=what...hrome&ie=UTF-8
There are a lot of different brands out there as with sizes. https://www.digikey.com/products/en/...=1&pageSize=25
Hope this helps.
mike.robinmc is online now
