The first nips of winter in the air reminded me of the heated seat mod - Pontiac Solstice Forum
post #1 of 18 (permalink) Old 09-06-2010, 07:30 AM Thread Starter
For those new to the forums, or the kappas, many of us have added aftermarket seat heaters to our cars. This morning I went out driving (top down of course) and for the first time in months, the temps were down in the lower 50's, so I though it would be a good idea to tell/remind others while there's time before winter.
Various heater kits are available from eBay and many different vendors. On the kappaperformance forum, DBG had set up a group buy type discount last year (though I don't know if that is still in effect): Heated seat kit - group buy
Forum member Odiaz had also gathered all the various install instructions and switch placement options into an excellent "how to" at his site: HowTos/HeatedSeats
Take it from me, this mod is CERTAINLY worth the time & effort!
post #2 of 18 (permalink) Old 09-06-2010, 12:13 PM
pj-33's Avatar
As a Canadian (Alberta) owner living at an elevation of about 3500 feet, heated seats are by far the first and most important mod (I can't believe they weren't a factory option...).
I often drive with the top down when it is as cold as 5 Celcius and with the heated seats, and heater on full blast, it is entirely comfortable. Heated seats effectively double length of the top-down season here in Alberta.
pj-33 is offline
post #3 of 18 (permalink) Old 09-06-2010, 01:31 PM
DRM
DRM's Avatar
I think this is one of my next projects.
2007 Pontiac Solstice GXP Deep/Ebony/Silver Stitching, traded 8/17/12 for a 2012 Ford F150 Lariat...I'm very sad.
2006 Pontiac Solstice Mysterious/Steel/Sand F1K(#78) 2nd owner, purchased with 1,400 miles, traded 3/07 for GXP
My Garage
DRM is offline
post #4 of 18 (permalink) Old 09-06-2010, 11:54 PM
jeffgtx's Avatar
do any of you fine fellows know where to find the full seat cover removal how to? the JPM document link is broken and this thread only shows the bottom seat removal.
thanks
jeff
Jeffgtx's Shades Of Gray Pontiac Armada
jeffgtx is offline
post #5 of 18 (permalink) Old 09-07-2010, 07:17 AM Thread Starter
The seat back cover removal is very easy. You just:
1. Unzip the two long zippers behind the seat
2. Either unclip from each other - or, more easily, slide-apart - the two interlocked plastic strips in the cover along the bottom rear of the back.
3. Peel the cover up from the bottom.
If you are just doing seat heaters, you only need to peel the covers up about 2/3's of the way. If you want to fully remove the covers, you'll also need to unclip and pull off the lever near the top (the one that releases the seat back when you want to swing it forward).
post #6 of 18 (permalink) Old 09-07-2010, 09:41 AM
jeffgtx's Avatar
Thank you kind sir.
jeffgtx is offline
post #7 of 18 (permalink) Old 09-07-2010, 09:45 AM
Project left from last winter to get on to soon.
1969 Firebird
1968 GTO
1979 Camaro Z28
1980 Camaro Z28
1984 Fiero
1986 Bronco
1989 Suburban conversion
1995 Silverado
1995 Camaro Z28
1996 Chevy G1500 Hi-top conversion van
2003 Suburban
2004 Avalanche
2008 Corvette Z51
2009 Solstice GXP coupe
2010 Camaro
2012 Avalanche LTZ
1955 Willys Wagon
1958 Willys CJ5
mickeykelley is offline
post #8 of 18 (permalink) Old 09-07-2010, 11:27 AM
GrandpaSolstice's Avatar
For some reason, probably from some retailer's web site, I was under the impression that seams would have to be ripped out and replaced during this mod. I think I may now take another look at it. It doesn't look to be too tough if the switches are installed in the waterfall below the rear cup holders.
GrandpaSolstice is offline
post #9 of 18 (permalink) Old 10-16-2010, 01:44 PM
Retired Free Range Sols
Aspenrose's Avatar
Got my driver side installed, also took the opportunity to bolster the seat, the easy way-worked in two 4" thick, 4" wide strips of foam between the seat foam and the seat springs underneath. Worked like a charm. Quick and easy. Now back to the seat, all that's left is the wiring, figure maybe an hour +/-.
06 NA...was 106k miles, do-over at 12k
06 NA...56k miles...Black today, black tomorrow?
01 Aztek GT...102k miles...Black and loaded. Best non-Solstice ever!
Team Solstice 2006 & 2006
Life is good with a pair of Sols in the garage.
Runs/Meets in '06:13 '07:13 '08:7 '09:9 '10:9 '11:6 '12:4 '13:3 '14:2 '15:3
Aspenrose is offline
post #10 of 18 (permalink) Old 10-16-2010, 02:01 PM
Bought some for me and the wifes redline at the end of last season. Just don't know if it gets cold enough here to install them or not.
Mine - '08 Brazen GXP. GMPP tune, Magnaflow exhaust, DDM backbone and brace, rear Z0K sway bar, Eiback springs, debadged, 19" MODA1 wheels.
Hers - '08 Bluestone Redline. GMPP tune, Magnaflow exhaust, DDM backbone, debadged (mostly).
brazen17 is offline
post #11 of 18 (permalink) Old 10-16-2010, 06:28 PM
crappa's Avatar
Used mine this morning
My Mods Post (as of June 16, 2010)
Avatar photo courtesy of Tommyboy, at 2010 NASSM
What do I want to be when I grow up? In denial.
crappa is offline
post #12 of 18 (permalink) Old 10-17-2010, 06:49 AM
rlhammon's Avatar
Mine were put in the seats back in the spring when the Michigan Kappa Club did their spring mod meet. I ran out of time at that event, and have yet to hook up the wiring. I could certainly use it here in Michigan about now... but doubt I'll get it down before I put the car away for the winter. It will be a winter time modification.
rlhammon is offline
post #13 of 18 (permalink) Old 10-17-2010, 05:12 PM
Aspenrose's Avatar
Still have to vacuum all the shavings out of the nooks and crannies, but here it is, slightly diff location than the others done so far, I think
post #14 of 18 (permalink) Old 05-08-2011, 07:34 AM
TomShadow's Avatar
Installing my heater (driver only) next weekend. I was thinking about putting the switch right underneath the ac/dc power plug (just to the left of the shifter). Does anyone know if there is room there to install the switch?
My second preference is to the right of the traction control switch.
Also, not too familiar with a step drill. Does it also drill the countersink bevels to match the factory buttons?
TomShadow is offline
post #15 of 18 (permalink) Old 10-18-2011, 10:19 PM
fiziksgxp's Avatar
warranty ???
Tomato Soup
Thanks for this thread ... it's time here - near Chicago - for me to get on this mod so I can keep the wife in the car for more rides for more months ... and cheers to Odiaz for the step by step instuctions with all those wonderful PICTURES ...
And PFYC has 10% off ... and they have kits with membrane switches which would make installations much more straight forward ... and both Allen and Brian from PYFC have been excellent with responses to my questions concerning these switches and their kits and I've been ... but then the other shoe dropped
since the Solstice has an airbag sensor in the passenger seat, PFYC won't / can't sell me a dual seat kit ...
I realize that there are other vendors who will supply a dual seat kit - but I wonder about my extended warranty ...
Since GM warns against installing seat heaters in the passenger seat, does anybody KNOW whether an installation in the passenger seat would void the warranty??
fiziksgxp is offline
