fixed the door panel bubble at last - Pontiac Solstice Forum
 3Likes
  • 3 Post By joybill44
post #1 of 6 (permalink) Old 07-07-2019, 02:13 PM Thread Starter
joybill44's Avatar
Been watching that bubble grow foe a year, finally decided to fix it. Pulled the door panel, removed the window switch and lifted the vinyl away from the plastic panel. Stuck a coat hanger in to keep the vinyl away from the panel and sprayed Loktite adhesive into the resulting cavity. removed the coat hanger, pushed everything together and BINGO! No more bubble.
ID:	98085   Click image for larger version
ID:	98087   Click image for larger version
ID:	98089   Click image for larger version
Rusty Boltz, ChopTop and CycleCat like this.
joybill44 is offline
post #2 of 6 (permalink) Old 07-07-2019, 03:29 PM
chickenwire's Avatar
Nice! Can you please share what exact adhesive you used?
chickenwire is offline
post #3 of 6 (permalink) Old 07-07-2019, 03:32 PM
Good job
post #4 of 6 (permalink) Old 07-07-2019, 03:53 PM Thread Starter
joybill44's Avatar
Loctite 300 spray adhesive. Comes in a 13 oz. spray can.
Word of caution. get it right the first time, very hard to reposition.
Bill.
post #5 of 6 (permalink) Old 07-07-2019, 06:04 PM
Good job!
You were lucky (?) that your bubble happened where it did. Most I've seen (including mine) seem to occur at the rear of the panel, far away from the window switch opening
post #6 of 6 (permalink) Old 07-07-2019, 07:28 PM Thread Starter
joybill44's Avatar
Good job!
You're right. anywhere else would be much more difficult. I saw somewhere a trick for getting that whole middle panel off. It is held on by several plastic studs which are (I think) spun welded into place. The plastic heads were ground off flush for removal and once the panel is recovered or glued, the studs can be center drilled and small washers and screws used where the stud heads were removed. Having that center panel off of the door panel would make repairs much simpler.
Bill.
