Foot Well Lighting - Page 4 - Pontiac Solstice Forum
post #46 of 118 (permalink) Old 10-22-2008, 10:13 PM
crappa's Avatar
My pods never completely shut off either, but they are very very dim in the off mode. I don't notice them when night driving anymore. There not noticeable at night with the top up, unless you bend down and look through the window. The draw is minimal, I have let the car sit for four days with no problem starting. I imagine the draw is still there with the mirror lights, just so little draw they didn't glow at all like the LEDs do.
My Mods Post (as of June 16, 2010)
Avatar photo courtesy of Tommyboy, at 2010 NASSM
What do I want to be when I grow up? In denial.
crappa is offline
post #47 of 118 (permalink) Old 10-23-2008, 05:45 AM
jonymac's Avatar
Mine do shutoff completely - the problem is that they turn fully back on 10 minutes after I leave the car and stay that way! I do not know what kind of timer is in the system to turn them on and not the mirror lights. You would think the mirror lights would turn on too after 10 minutes. Any info on resisters - size, type, how to wire in etc?
jonymac is offline
post #48 of 118 (permalink) Old 10-23-2008, 08:37 AM
cartmann32's Avatar
Mine do not turn all the way off either. As stated above, it's an issue with the ECM, well I wouldnt' way issue, but it's just how our car works.
Trax Customs
www.traxcustoms.com
cartmann32 is offline
post #49 of 118 (permalink) Old 10-23-2008, 12:18 PM
jonymac's Avatar
How about the trning back on fully after 10 mins without the mirror lights turning on - anyone have this action? That just doesn't make sense to me...
jonymac is offline
post #50 of 118 (permalink) Old 10-27-2008, 08:31 AM
jonymac's Avatar
Update: I rewired the footwell LEDs this past weekend. No more problems! Woohoo! They dim and turn fully off with the mirror lights and now do not magically turn back on after 10 minutes. Still don't know why this was happening, but now its not, so I am very happy!
jonymac is offline
post #51 of 118 (permalink) Old 10-27-2008, 11:19 AM
Yamatr3's Avatar
How did you fix it? Did you add a resistor?
Yamatr3 is offline
post #52 of 118 (permalink) Old 10-27-2008, 03:13 PM
jonymac's Avatar
No resister - just rewired the whole thing - don't know anythnig bout resisters - maybe I had a short or something. Replaced the fuse link and installed 2 new 5 amp breakers in it. Now that I think about it, I was also replacing the throttle body at the time with a big bore throttle body from Saturn Motorsports and reset the computer by disconnecting the battery for 1/2 hour so the computer would relearn the throttle position and clear my pesky CEL. Soooo - maybe the computer reset contributed to fixing things. I know - crappy troubleshooting methodology, but it works now!
jonymac is offline
post #53 of 118 (permalink) Old 11-10-2008, 11:58 PM
So... how did you get the C3 block apart so you could see and trace the wires... I did a "tug test", but figure there must be a trick to popping it open...
Thanks,
RaiderFan
Originally Posted by AztekzRpurty View Post
Just finished phase I of mine. Here's some pics, and a video when it gets through processing on youtube. Thanks to everyone for the great info.
PNWRaiderFan is offline
post #54 of 118 (permalink) Old 11-11-2008, 07:04 AM
Chemist's Avatar
Thanks,
RaiderFan
The little (8 mm, 10mm?) bolt in the center must be unscrewed, then the whole "plug" unit can be pulled. Then the cover can be removed from that and the wires exposed.
Chemist is offline
post #55 of 118 (permalink) Old 02-15-2009, 02:19 AM
BIO Hazard's Avatar
Love this mod and after previous help from BLK GXP and this awesome forum thread here I think I can do the wiring without sending my car up in smoke.
I want to do RED LED lighting to go with the dash. Since these lights are only going to come on when the door is opened and closed they can be as bright as they make them.
Here are my questions:
Which LEDS are the best and brightest to use? Who makes them and what size do I want for the foot wells?
Is everyone using the adhesive backing that just stick on to mount the LEDs in place ~ or ~ is there a better method for mounting the LEDs?
Related question... Has anyone had trouble with the adhesive weakening and the led bars drop down after awhile?
I see some have actually replaced the actual dome mirror lights with RED LEDS... How is that done and again which LED mfg do I want to order? (an actual part number would be extremely helpful so that I dont order the wrong thing) FYI - I have a 2008 GXP with the Onstar controls - I know that makes a difference.
Final question... I have the wiring down (I think)... Based on the fact that I have absolutely nothing electrical parts wise here... Does someone have a complete shopping list put together including all the electrical pieces, connectors, wires, relays, taps, and wiring I need to complete this project? - (again actual part/model numbers would be great and very much appreciated)
Thanks in advance for any help you can provide to a complete novice like myself.
BIO Hazard is offline
post #56 of 118 (permalink) Old 02-15-2009, 05:34 AM
Yamatr3's Avatar
Here is a god website where I bought my LED's I used in my car.
LEDs - underbody kits, cathodes, flexible LED strips, dome lights I used the flexible LED strips and they come with adhesive backing.
Yamatr3 is offline
post #57 of 118 (permalink) Old 02-17-2009, 04:03 AM
BIO Hazard's Avatar
Thanks for the link... Lots of lights here to chose from...Which did you get? I should mention I dont want to solder anything. Did you have to solder anything?
post #58 of 118 (permalink) Old 02-18-2009, 10:12 AM
BIO Hazard's Avatar
This is a great mod GM should incorporate into future Solstice models and offer it as an accessory kit to current owners for purchase. Great post and info.... Just wish someone one list a comprehensive/complete parts list (with model numbers) needed to complete the installation of this awesome mod.
post #59 of 118 (permalink) Old 02-18-2009, 10:21 AM
Brazen Orange : This is a great mod GM should incorporate into future Solstice models and offer it as an accessory kit to current owners for purchase. Great post and info.... Just wish someone one list a comprehensive/complete parts list (with model numbers) needed to complete the installation of this awesome mod.
What future models ?
Kappasphere, et al, are the more likely source for a kit. This type of thing is way too niche-market for an OEM.
post #60 of 118 (permalink) Old 02-18-2009, 10:30 AM Thread Starter
No soldering needed, just some wire ends and wire and a pair of crimps Get a fuse holder from Autozone Part #BP/HHA (don't forget the fuses to fit it I used 3 amp) I might add that the fuses are hard to insert into the holder so don't be afraid to apply a little muscle. A 8 or 9 inch led strip will work fine, can also be gotten at AutoZone and follow the install instructions from this post and you are in business.
Hoosier GXP is offline
