Hood / Bumper Alignment - Pontiac Solstice Forum
 5Likes
  • 4 Post By rob the elder
  • 1 Post By joybill44
post #1 of 5 (permalink) Old 03-26-2019, 06:34 PM Thread Starter
Finally got a better look at the "overbite" of the hood on my one week old vert. The forums mentioning alignment seem to favor leaving the hood alone unless necessary. The rear seam of hood doesnt vary from left to right, so hoping the bumper cover is the culprit. Any lessons learned on adjusting it welcomed.
Okiebill
okiebill is offline
post #2 of 5 (permalink) Old 03-26-2019, 09:00 PM
If it fits the windshield, the doors and the fenders then work on the front bumper cover. Read the alignment manual. It's mentioned here somewhere. I keep a paper copy handy
The cover has many adjustment point that should fix that issue
post #3 of 5 (permalink) Old 03-28-2019, 10:01 AM
a_bartle's Avatar
This might help...
a_bartle is offline
post #4 of 5 (permalink) Old 03-28-2019, 05:16 PM
joybill44's Avatar
had the same problem with mine when I bought it. every problem is different, but I fixed mine by putting plastic fender washers under the bumper cover at each of the screws on the top of the bumper which lifted it enough to close the hood/bumper gap. It then can move forward or backward to adjust the overbite. There are also two vertical jack screws with rubber bumpers on them inboard of the headlamps at the front edge of the hood which can help with the evening up the gap.
Good luck! There's a lot of trial and error involved.
Sting Ya likes this.
joybill44 is offline
post #5 of 5 (permalink) Old 04-15-2019, 05:46 PM Thread Starter
Am trying all the adjustments from the pdf file and elsewhere. Hood is perfectly aligned on all sides. Appears that bumper was pushed inward just enough to have the hood protrude over the bumper cover.
okiebill is offline
Similar Threads
Hood Alignment ? FieroVin General Solstice Discussion 5 01-30-2009 11:42 AM
Bumper alignment GXPmach General Solstice Discussion 2 06-26-2008 09:08 PM
RK Sport bumper alignment darylandmichele Mods - Interior/Exterior Functional/Appearance 2 04-22-2008 06:51 PM
Alignment question? [Race alignment impact on daily driving] brentil Autocross and Racing Discussion (Solstice/Kappa) 68 04-23-2007 05:04 AM
