"How To" Convert Side Marker Lights into Marker/Turn Signals - Page 5 - Pontiac Solstice Forum
 1Likes
post #61 of 160 (permalink) Old 09-23-2008, 02:22 PM
Skyman-CT's Avatar
Originally Posted by Deepbluegxp View Post
The reason this simple mod works is that the fog and turn signal share a ground. When you cut the side marker wire and connect it to the blue wire, it essentially is like extinding the brown wire to the other lights to share the same ground as the fog and turn signals. Now worries. Do this mod...
Agree
However I think you meant NO worries.
Sky Redline
Chili Pepper Red with Black Trim
5-SPD, 6-CD/MP3, XM, Polished Alloy, LSD, Spoiler
Deposit 06/10/06
Order # KGNMQ4
3800 02/09/07
Delivered 02/28/07!!!
Skyman-CT is offline
post #62 of 160 (permalink) Old 09-23-2008, 03:01 PM Thread Starter
Deepbluegxp's Avatar
Originally Posted by SOLSTICE-D View Post
which one of these is the simplest???
Post 1 method 2
https://www.solsticeforum.com/forum/f...signals-48817/
See my car on cardomain.com
Deepbluegxp is offline
post #63 of 160 (permalink) Old 10-04-2008, 10:47 PM
Rizz1435's Avatar
Flashing
I am flashing with everybody else now..yipeee Easy mod
Rizz1435 is offline
post #64 of 160 (permalink) Old 11-18-2008, 07:27 PM
tinsley2207's Avatar
ok so i just did this mod it took all of 10 min for an experianced person like myself it was really easy i went for a drive and saw a sol we talked for a second and he thought it was cool that its worked so well and so easy so thanks for the cheap easy mod if u have any ohers let me know
tinsley2207 is offline
post #65 of 160 (permalink) Old 11-21-2008, 09:52 PM
summer_solstice's Avatar
Did it.
DeepblueGXP
Many thanks for the idea and the instructions. Your instructions made it very easy to set up.
Unfortunately with day time running lights it is hard to get a good video of the mod.
I am in:
Is there any way to power the side markers when the park lights are off?
I really like the mod
May All Your Solstice Driving Days be Top Down...
2007 GXP, PURE, STD, purchased 2007/05/31, tan top, all options, red stitching, clear bra, painted splash guards & calipers, wind restrictor, Solo Street Race Exhaust, JPM red stitched sun visor covers, K&N air filter, Side marker turn signal, Norms Fenders, Hahn intercooler & BOV and Wester's race tune.
summer_solstice is offline
post #66 of 160 (permalink) Old 11-23-2008, 07:33 AM Thread Starter
You can turn off the lights with the turn signal control on the steering wheel.
You can test then with the car off by hitting the emergency flasher control and then by turning the lights on one click on the turn signal arm.
BTW, I did 16 of these mods on Skys and Sols at the last mod meet and Go-N Def's last week and Midlife's car this weekend
post #67 of 160 (permalink) Old 11-23-2008, 07:34 AM Thread Starter
Originally Posted by summer_solstice View Post
DeepblueGXP
I am in:
From the sound of your video, it sounds like you used the relay version of the mod. Great job!!!
post #68 of 160 (permalink) Old 11-23-2008, 08:06 AM
Sly Bob's Avatar
Without the relays I would assume Joe? Do we know yet if the LEDs can be powered with this mod without the relays?
Nice job Summer Solstice!
Born April 30, 2008
Delivered on May 27, 2008
Sly Bob is offline
post #69 of 160 (permalink) Old 11-23-2008, 02:33 PM Thread Starter
If you play the video, you can hear clicking. With the no-relay mod, you can't.
No one has installed LEDs yet as far as I know and did the mod.
post #70 of 160 (permalink) Old 11-25-2008, 09:27 AM
crappa's Avatar
Here is a variation of this mod using LEDs
My Mods Post (as of June 16, 2010)
Avatar photo courtesy of Tommyboy, at 2010 NASSM
What do I want to be when I grow up? In denial.
crappa is offline
post #71 of 160 (permalink) Old 11-25-2008, 12:57 PM Thread Starter
Sorry crappa, that isn't what we are talking about. Cool though, I didn't know that thread existed. What we want to know is if in doing the mod described on the first post and replacing the existing filament bulb with an led, will the marker light still work?
post #72 of 160 (permalink) Old 11-25-2008, 09:48 PM
Relay versus non relay method
I assume the benefit of the relay method is to get the side marker flash in alternate sequence to the turning signal light. Where the non relay method you can only get the side marker to flash in sequence with the turning signal light.
I think the side marker flashing in alternate sequence is way cool Where the side marker flashing in the same sequence not worth the effort.
post #73 of 160 (permalink) Old 11-26-2008, 06:11 AM Thread Starter
Both methods do the same thing. Flash sequencially and when the parking lights are on they alternatly flash. I changed mine to the non relay mod version and it performs the same way.
post #74 of 160 (permalink) Old 11-27-2008, 06:27 PM
After further reading of this thread I see why the side marker alternates:
What it does do however is to cause the 12Volts to buck each other while the parking lamps are on which is why I believes it alternates because the current flow thought the bulb is actually reversed in that state, as was mentioned elsewhere it should work fine with any Park/Turn Signal incandescent bulbs but LEDís or HIDís most likely wonít work due to reverse current flow. (just a guess at this time?)
Last edited by summer_solstice; 11-27-2008 at 06:43 PM. Reason: Understand why it works
post #75 of 160 (permalink) Old 11-29-2008, 12:02 PM
duckSol's Avatar
Location: Roosting on the west central flyway in Colorado Springs
This is an IF THEN theorem argument,
If an LED is a light emitting diode,
If current flows only one way in a Diode
If the 12v is bucking,
then, the answer is obvious.
2012 Summer Solstice in the Land of Sky
duckSols Mods revised 9-4-09
Transformer SLY
"Okolemaluna"
duckSol is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.solsticeforum.com/forum/f62/how-convert-side-marker-lights-into-marker-turn-signals-48817/
Posted By For Type Date
Making the DBG 'Convert Side-Marker Lights into Turns' mod work with LEDs This thread Refback 05-15-2013 07:26 AM
