how to: remove cigarette lighter - Page 2 - Pontiac Solstice Forum
post #16 of 21 (permalink) Old 06-23-2011, 01:48 PM Thread Starter
Manuel's Avatar
Originally Posted by MARVIC 1 View Post
This guy is doing the most basic "Push to Start" connection, will still need the key in the Start Positions than pressing the start button.. As for Helios project it was way more sophisticated push to start system where no key was involved just the chip I believe...
u got it
Manuel is offline
post #17 of 21 (permalink) Old 06-24-2011, 06:02 PM
boboborino's Avatar
Originally Posted by solmio View Post
cool! good luck and keep us posted!
$$$The Madness Never Ends$$$
boboborino is offline
post #18 of 21 (permalink) Old 06-24-2011, 08:46 PM
zzzybil's Avatar
..... thanks - i knew i remembered someone actually explaining much more than '' 4 wires ''
lol if u doubt , its probably cause u dont know much about cars
....hahaha no i don't know much as you...
.... tho i've done enuff projects to learn - its always more complicated than yuh think its going to be....
... no insult intended ... i've never used it for a ''lighter''...... it is necessary @ times for the gps,phone charger, laptop...haven't had any experience with the air compressor yet but i betcha it needs a power source too........ nope not something yuh need often BUT WHEN YUH NEED IT ?????????...
..i wouldn't give up my 12v access for ''the button start''......not that it won't look cool..
.maybe you can relocate your 12v...to gb or under dash.. that's prolly piece a cake too! .
something to think about...
BOOsted 2.4
42lb injectors
3" tubes front to back
10 boost
38mm tial wastegate / bov
custom i/c (BELL)
Werks radiator
aem wideband
gxp exhaust /magna flo - integrated dumptube
hi flo cat
HPTUNING -
(tune therapy -> randy @DDM)
JET-HOT 2000
aerologic egt kit
DDM backbone
AEM boost control
custom .08ss heatshield
SPEC 2+ UNsprung
YEAH I DID THAT !
zzzybil is offline
post #19 of 21 (permalink) Old 06-10-2019, 06:42 PM
Hi
My socket is missing (removed/empty)! Only the little flip cap is there with some taped wiring within. Can I install a new socket without removing the "boomarang" section?
Thanks
kentlarue is offline
post #20 of 21 (permalink) Old 06-11-2019, 06:38 AM
Originally Posted by kentlarue View Post
Hi
Thanks
As long as you can reach the connector, yes. The socket inserts from the top.
Now I see you say 'taped wiring'. The the PO cut off the connector? If so, that's bad.
post #21 of 21 (permalink) Old 06-11-2019, 06:35 PM
Hi
I was able to fish out the wires (one black, one red/white). No connector of any kind; someone cut it off. They are live without the ignition on.
I plan to buy a dorman cigarette lighter socket that is supposed to fit into the space and to wire it up somehow or other to charge my phone and run my GPS.
