Punisher - Page 208 - Pontiac Solstice Forum
 100Likes
post #3106 of 3139 (permalink) Old 03-03-2019, 09:04 AM Thread Starter
Minus 3 this morning and 3 inches of snow. Now we are having fun!
post #3107 of 3139 (permalink) Old 03-03-2019, 04:00 PM
Saveaux's Avatar
Wasn't exactly the weekend I was hoping for. Last weekend I declared today being the day to get the car running after walnut blasting. Needless to say....it's not running now.
Is your garage heated??
Saveaux is online now
post #3108 of 3139 (permalink) Old 03-03-2019, 08:33 PM Thread Starter
Yes. I have two heaters. I keep it about 65 when I'm working in there. I did tile most of the day and cut it in the garage.
post #3109 of 3139 (permalink) Old 03-05-2019, 07:10 PM
skersfan's Avatar
Good to see you back out working on the cars. I did the tile, cabinets and counter tops last summer. Get to do the bathroom this summer I guess. Not making the journey to New York so will penty of time I think. Putting a overhead in the garage so I have storage for the stuff the train keeps moving out of its way.
skersfan is offline
post #3110 of 3139 (permalink) Old 03-05-2019, 07:13 PM
Saveaux's Avatar
hahahah!!
post #3111 of 3139 (permalink) Old 03-05-2019, 08:44 PM
skersfan's Avatar
My feelings exactly!!!!!!!!
skersfan is offline
post #3112 of 3139 (permalink) Old 03-08-2019, 06:32 AM Thread Starter
The Hooker's for the Punisher Hauler showed up. Now to get them installed.
ID:	94081   Click image for larger version
post #3113 of 3139 (permalink) Old 03-08-2019, 07:14 AM
Saveaux's Avatar
Those look great RTE!!
post #3114 of 3139 (permalink) Old 03-12-2019, 06:17 AM Thread Starter
Have been working on my new little commuter vehicle. Since I now commute over 50 miles a day I decided to get a higher mileage vehicle to use as a commuter. More mods are in the works LOL.
Name:	Taco badge 2.jpg
ID:	94153   Click image for larger version
Name:	taco badge.jpg
ID:	94155   Click image for larger version
ID:	94157   Click image for larger version
Northern Sol likes this.
post #3115 of 3139 (permalink) Old 03-21-2019, 11:42 AM Thread Starter
The PunisheR is at the body shop. I am nervous LOL
Name:	Empty Garage.jpg
post #3116 of 3139 (permalink) Old 03-21-2019, 11:45 AM Thread Starter
Found time between thunder snow storms to detail both trucks and the wife's Trax. Quite a day's work.
Name:	Ram detailed.png
ID:	94429   Click image for larger version
Name:	RAM Detailed 1.png
ID:	94431   Click image for larger version
Name:	RAM Detailed 2.png
post #3117 of 3139 (permalink) Old 03-24-2019, 06:50 AM Thread Starter
Punisher Hauler Headers are ceramic coated. Here is a pic of baking the coating in my garage oven.
Name:	header baking.jpg
post #3118 of 3139 (permalink) Old 03-24-2019, 06:53 AM Thread Starter
Installed the SpeedHut speedometer. Works great! I am waiting on the new tachometer.
ID:	94465   Click image for larger version
Name:	speedo install 1.jpg
ID:	94467   Click image for larger version
Name:	Speedo Install.jpg
ID:	94469   Click image for larger version
post #3119 of 3139 (permalink) Old 03-24-2019, 07:06 AM
Saveaux's Avatar
Looks awesome, nice job!
post #3120 of 3139 (permalink) Old 03-25-2019, 05:56 AM Thread Starter
three of us repaired John's rear window. About half the left side had come loose. We had an abundance of clamps that worked well. The only issue was the suckers are large enough so you are limited on the number of clamps that will fit the window and getting into the narrow side can be a challenge. We ended up cutting a piece of aluminum bar and using it as a clamp across the top and bottom edges to spread the force between the clamps. We first test fit the clamps till we got the optimum placement then applied the glue followed by installing the clamp arms and tightening everything down. On the end, we used a couple of dense foam wedges to make sure the narrow end was fully in contact with the glass. Worked pretty well. Will see how the result is once it cures.
Name:	clamps lined up before gule.jpg
ID:	94501   Click image for larger version
Name:	all clamps in a row.jpg
ID:	94503   Click image for larger version
Name:	clamps with foam wedge.jpg
ID:	94505   Click image for larger version
Name:	clamps in position.jpg
  LinkBacks (?)
LinkBack to this Thread: https://www.solsticeforum.com/forum/f62/punisher-65168/
Posted By For Type Date
Daily driver? - Page 2 - Saturn Sky Forums: Saturn Sky Forum This thread Refback 05-16-2013 10:28 PM
Building the Kappas. - Saturn Sky Forums: Saturn Sky Forum This thread Refback 05-16-2013 03:20 PM
Replace instrument cluster? - Saturn Sky Forums: Saturn Sky Forum This thread Refback 05-16-2013 02:10 AM
