Tapping into the dash lights - Page 2 - Pontiac Solstice Forum
 9Likes
post #16 of 26 (permalink) Old 06-14-2019, 10:12 AM
joybill44's Avatar
my modified instrument cluster lights, outdoors, top down.
no trouble seeing these in bright sunlight.
Bill.
rob the elder likes this.
joybill44 is online now
post #17 of 26 (permalink) Old 06-14-2019, 02:09 PM
joybill44's Avatar
forgot to mention, the added LEDs are dimmable. Notice the extra dimmer dial in the lower right of the picture. Needed that at night when they are too bright.
Bill.
post #18 of 26 (permalink) Old 06-15-2019, 10:41 AM
I'd like to see some gauge faces with white text on black background, lit by UV lights in front. My C5 had a similar setup and it looked amazing.
post #19 of 26 (permalink) Old 06-15-2019, 05:50 PM Thread Starter
Wired up per recommendation. Worked great! Thanks all
post #20 of 26 (permalink) Old 06-15-2019, 09:15 PM
Excellent. Glad it worked.
post #21 of 26 (permalink) Old 06-15-2019, 09:47 PM Thread Starter
I will post a picture tomorrow
post #22 of 26 (permalink) Old 08-13-2019, 02:21 PM
09GXP's Avatar
Rob, did you find a good, convenient grounding point for the Speed Hut gauge A-pillar pod installation you completed?
09GXP is offline
post #23 of 26 (permalink) Old 08-13-2019, 03:17 PM
wmf246's Avatar
my A pillar gauges, ambient temp and oil pressure
Bill
09GXP likes this.
wmf246 is offline
post #24 of 26 (permalink) Old 08-13-2019, 07:12 PM
There's quite a number of threaded holes along the top metal of the windshield, under the plastic trim. I used one as a ground for my mood lights and homelink transmitter.
09GXP likes this.
post #25 of 26 (permalink) Old 08-13-2019, 08:18 PM
CycleCat's Avatar
I helped with the last install we did at his garage day. We crimped a ring terminal on the wire and ran the ground to the screw that anchors the door strut that keeps the door from opening too far. There were only a few inches of exposed wire... hardly noticeable.
09GXP likes this.
Chris
CycleCat is online now
post #26 of 26 (permalink) Old 08-14-2019, 07:42 AM
09GXP's Avatar
Thank you all!
09GXP is offline
