Any Dyno's Of Redlines or GXPs on Base Trifecta Tune with Solo HiFlow Downpipe? - Pontiac Solstice Forum
 1Likes
  • 1 Post By MattM
post #1 of 5 (permalink) Old 01-30-2019, 10:53 AM Thread Starter
Hey! Title says it all.
I've searched and searched and searched and I can't seem to find any dyno's anywhere of a redline (or gxp) with a Trifecta base tune and Solo Hiflow downpipe. I know the typical stock redline with base trifecta numbers are around 250-280 whp and 300-315ft lbs of torque (judging by 1/4mile performance my car's 13.6 at 102 last year was right there in that range before the downpipe). I'm just really curious to see what a Solo Hiflow downpipe does to those numbers and am hopeful someone out there has a dyno of one.
raygun likes this.
MattM is offline
post #2 of 5 (permalink) Old 01-31-2019, 10:33 AM
wspohn's Avatar
Vince told me way back when we were tuning my car that the best he had seen was about 286 whp. The Solo CAT should add around 10 whp to that (although many will claim more). Someone must have some actual dyno results to confirm.
As I was looking through my old emails with him, I found an interesting comment on tuning the NA cars. He said that the gains with them were often better than customers expected because the stock tune has a PE mode that requires about a 5 second lag between flooring it and getting full enrichment. By eliminating that, he was seeing up to 20 ft-lbs improvement on those cars.
1958 MGA Twin Cam (race car)
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #3 of 5 (permalink) Old 02-07-2019, 10:50 AM Thread Starter
So I did find a somewhat similar comparison on Skyroadster.com (which i'm quoting below). It's from Monadzback's dynos. First dyno was trifecta on stock redline. Second dyno was a gutted cat, but on a custom Trifecta tune (so it would be a little different) but the stock tunes are definitely comparable.
Originally Posted by MattM View Post
Ok. Closest comparo i could find has to do with Monadzback's dynos. The first graph is a stock Redline with Trifecta tune:
https://www.skyroadster.com/forums/a...104101&thumb=1
The second one is of Monadzback's Redline with gutted cat and 25 psi trifecta tune:
https://www.skyroadster.com/forums/a...104103&thumb=1
This is on the same superflow dyno as well. So on the stock cat dyno with trifecta he made 264whp and 310ftlbs torque. On the second dyno with gutted cat he made 283whp and 348 ftlbs torque.
I think the really high torque increase on the second dyno has to do more with the modified tune than the gutted cat.
That said, he dynoed without the trifecta on stock car and got 232whp and 236ftlbs torque. He also dynoed after the gutted cat on the stock tune and got 253.5whp and around 250ftlbs of torque....
Essentially, I'd say he was able to get about a 20whp and 20ftlbs of torque increase with the gutted cat. That at least is some good evidence to go on. As to the differences of the tuned numbers....I would very much doubt I'd see a 38ftlb of torque increase over a stock cat. I think he may have gotten it retuned by vince after he gutted the cat. Anyway, at least we have similar circumstances to make a comparison.
Here is the stock tune stock cat dyno curve:
https://www.skyroadster.com/forums/a...104105&thumb=1
Here is the stock tune gutted cat dyno curve(again this one made 253whp and around 250 torque:
https://www.skyroadster.com/forums/a...104107&thumb=1
PS. sorry for the low quality of the "gutted cat" dyno curves...I basically took screen shots of the video he had of the dyno.
Name:	Monadsback stock car stock tune.jpg
ID:	93609   Click image for larger version
Name:	Gutted Cat Stock Tune.jpg
ID:	93611   Click image for larger version
Name:	Monadzback stock car Trifecta dyno 2.jpg
ID:	93613   Click image for larger version
Name:	Monadzback Trifecta Gutted Cat 26psi dyno.png
MattM is offline
post #4 of 5 (permalink) Old 02-07-2019, 10:59 AM
easyryderca's Avatar
Thanks Matt. Very interesting as i'm going to get a dyno this spring done on my coupe as i do have the hiflo with DDM'S high end tune. This dyno stuff is a real learning curve for me as trying to understand it all.
easyryderca is offline
post #5 of 5 (permalink) Old 02-08-2019, 10:47 AM Thread Starter
When comparing dynos. There are a few things to look at. The stock dynos (without the gutted cats) have obviously been smoothed a little more but the overall characteristics of the graphs (comparative shapes) of the before and after graphs are pretty similar. What most people do (but you shouldn't) is compare just the top numbers. What's more important are the changes to the shapes of the graphs before and after the peaks.
Just to observe....I've circled a few places on the two graphs and drawn the shapes their increases make. The second graph shows a more aggressive increase over the first one, which means you are getting much better performance throughout your rpm range and power band. That would be the one you want EVEN if the peak numbers are lower because you are only getting better performance at one single spot of the curve. Hopefully that makes sense.
Name:	Monadzback stock car Trifecta dyno 22.jpg
ID:	93653   Click image for larger version
Name:	Monadzback Trifecta Gutted Cat 26psi dyno2.jpg
MattM is offline
Similar Threads
tok the car to the dyno agressive trifecta tune ripped Mods - Engine 2.0 Turbo 38 04-10-2011 08:04 AM
Fitment question-Solo NA Header & HiFlow Cat Aspenrose Solo Performance 14 04-25-2010 01:21 PM
Solo HiFlow Cat Install pj-33 Mods - Engine 2.0 Turbo 8 04-28-2008 05:13 PM
How many GXPs or Redlines in Chicagoland? werks Great Lakes 8 01-18-2007 08:09 AM
