Dirty Valves - Page 5 - Pontiac Solstice Forum
 31Likes
post #61 of 102 (permalink) Old 02-14-2019, 07:43 AM
Originally Posted by Saveaux View Post
@raygun You were at NASSAM 2018? I really should have gotten off call and spent more time there than the 4-5 hours total that I did. I missed the opportunity to meet a lot of good people.
Grammer was my worst subject ever, I still to this day don't know when to use a comma. At least @raygun is a hella mechanic!
I believe the tool is aluminum....maybe???
You may have missed the below link earlier in this thread.
https://www.cobaltss.net/forums/08-1...tlanta-325238/
A Cobalt fella used this same adapter with a lot of success. I think he had pictures on the 17th response to the below thread? Check it out!
Huh. That's neat. I'd love to see some pics of the other side of the adapter when it shows up. (Also, despite the Cobalt guy's really pretty setup, I'd still recommend taping off the other three ports.)
Yeah, I was at NASSAM last year Monday through Thursday, about a week after I bought the GXP. And, of course, my windshield got cracked on a cruise. I think the best part was the stop light at the top of mountains in the park.
I won't be able to make it this year. Next year I might bring my (now) nine year-old along.
I met a lot of great people. It would've been better, I think, if there had been some more organized social things in the evening. It was sometimes difficult to find anyone to have dinner with as I really didn't know anyone. But, I still had a lot of fun.
For future reference (when the picture inevitably disappears from the Cobalt site, and someone is looking for it here):
raygun is online now
post #62 of 102 (permalink) Old 02-15-2019, 06:39 AM Thread Starter
Saveaux's Avatar
Much larger than I imagined. The Harbor Freight blow gun extension fits perfectly through the hole.
ID:	93741   Click image for larger version
ID:	93743   Click image for larger version
rob the elder, raygun and syjos like this.
Saveaux is offline
post #63 of 102 (permalink) Old 02-15-2019, 09:57 AM
syjos's Avatar
How does it fit into the intake passage? Tight, loose?
syjos is offline
post #64 of 102 (permalink) Old 02-15-2019, 11:33 AM Thread Starter
Saveaux's Avatar
Loose, however the Cobalt forum member stated that he wrapped tape around the adapter until it was snug-ish. I suspect that it wouldn't take that much tape.
Also, if the adapter was pushed against the head, even with a little force, nothing would leak. I'm not sure if two hands are enough but I'm going to try it that way.
Additionally, I'll have all valves taped off that I'm not working on, as well as the spark plug holes. Then I plan on taking a giant painters clear sheet of plastic and drape the entire engine bay with it, leaving only a small hole to work through.
Saveaux is offline
post #65 of 102 (permalink) Old 02-15-2019, 05:17 PM
syjos's Avatar
Thanks Saveaux,
Will wait to see how it works.
syjos is offline
post #66 of 102 (permalink) Old 02-15-2019, 05:22 PM
I think he said the vacuum helped keep it against the head.
You might be able to cut a silicone gasket from something like an old phone case to help make it air tight
sLAsh is offline
post #67 of 102 (permalink) Old 02-15-2019, 05:47 PM Thread Starter
Saveaux's Avatar
What direction do I turn the crank bolt to raise/lower valves? Clockwise? Tightening the bolt?
Am I correct that if I spin in the opposite direction I can potentially bend valves?
Saveaux is offline
post #68 of 102 (permalink) Old 02-15-2019, 08:48 PM
It shouldn't matter.
rob the elder is online now
post #69 of 102 (permalink) Old 02-15-2019, 09:02 PM Thread Starter
Saveaux's Avatar
Thanks Rob! Btw - you me tioned getting supplies from a BMW site to walnut blast. Do you already have the vacuum/media blaster adapter I just got?
Saveaux is offline
post #70 of 102 (permalink) Old 02-16-2019, 08:56 PM
I bought the wand from the BMW site a year ago. I ordered the sucker last week
post #71 of 102 (permalink) Old 02-20-2019, 07:59 AM
I received the vacume attachment yesterday. Its metal. Nicely made
post #72 of 102 (permalink) Old 02-20-2019, 02:23 PM Thread Starter
Saveaux's Avatar
Bummer, I would have made you a GREAT deal on a "slightly used" one once I'm finished with it!
Saveaux is offline
post #73 of 102 (permalink) Old 02-20-2019, 05:41 PM
syjos's Avatar
Wouldn't you keep it for the next time?
syjos is offline
post #74 of 102 (permalink) Old 02-20-2019, 06:00 PM Thread Starter
Saveaux's Avatar
Rob mentioned that he will probably clean valves once every 12 years or so based on the amount of miles that are put on the green car.
I put about 2300 miles on my GXP the first year I had it. Based on that, I may be looking at 10-15 years before I'll need to clean valves again. I'm a tool hoarder, but this may be one worth flipping after I use it.
Ive hung onto my Trifecta Red cable, but it too may be worth selling...
syjos likes this.
Saveaux is offline
post #75 of 102 (permalink) Old 02-20-2019, 08:37 PM
Mine will be available to the club
RobR likes this.
Similar Threads
Engine overheating / Check valves in coolant lines Final 1 Solstice Coupe Discussion 15 02-06-2015 04:07 PM
Coolant Bleeder Valves omw41 General Solstice Discussion 5 04-08-2013 11:08 AM
Valves rattling ? GTfastbacker Solstice GXP Discussion 12 11-13-2011 11:53 AM
FS: intake/exhaust valves, valve springs, rocker arms sky888 Solstices and Parts for Sale/Want to Buy (incl other vehicles) 0 06-25-2010 03:28 PM
Whats The Diff in Ferra or Supertech Valves/Springs IBDRINKEN Mods - Engine 2.0 Turbo 1 02-24-2010 07:20 AM
