Gmpp upgrade - Page 2 - Pontiac Solstice Forum
 1Likes
post #16 of 26 (permalink) Old 01-18-2019, 02:47 PM
The GMPP upgrade isn't just a tune so what's the dynamic re: 2 bar vs 3 bar sensors and an aftermarket tune that mimics the GM one?
Gone but not forgotten:
ChrisBlair is offline
post #17 of 26 (permalink) Old 01-18-2019, 02:54 PM
There's some debate about whether the sensors are really necessary, and whether they're really "3 bar" sensors vs 2.8 or whatever.
The GMPP tune kicks it up to about 24 psi, which is (roughly)~38 absolute. (This isn't entirely accurate as there's an offset and a scale, just like converting between Celsius and Fahrenheit, but it's close enough for the moment.)
That's roughly 2.6 bar. I'm not sure what the stock MAP sensors do when they get close to their limit, but typically sensors don't provide the most reliable data in that condition. In order for the ECM to correctly manage all the little twiddling bits, it needs an accurate boost measurement - which isn't always possible with the stock sensors.
For fun, you could open up the GMPP tune, set the MAP offset and scale to match the stock sensors, and see what happens. I'd guess that you'd just get a boost reduction or fuel cut a little earlier than with the 3 bar MAPs. (It COULD just let you get as much boost as the turbo can generate since you never really hit the ceiling, but fuel delivery would be an issue and Very Bad Things might happen. I'll let someone else try it.)
Trifecta's budget tune - correct me someone if I am incorrect - can work without the 3 bar sensors. I'm guessing they're just really careful. If you want to run something crazy like 30psi, you'd need sensors that can go that high, and over.
post #18 of 26 (permalink) Old 01-18-2019, 03:01 PM
wspohn's Avatar
Trifecta considered it an added complication to have to include the GMPP sensors in their tune at the beginning but got used to doing it as many who had the basic GMPP wanted more.
I already had the GMPP tune (because it was all I could do while under warranty) so they included that in my basic Trifecta tune and later in the enhanced big wheel tune. The GMPP sensors give you no more power - they were just done by GM to match their standardized headroom for sensors.
1958 MGA Twin Cam (race car)
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #19 of 26 (permalink) Old 01-18-2019, 10:23 PM
Greatgab's Avatar
wspohn - are you still using the Trifecta tune with the bigger turbo?
2008 GXP Aggressive Red - SOL LVR - Trifecta custom tune - DDM CAI/charge tubes/silicone hoses - Werks IC - Solo Hi-flow Cat/Mach Shorty exhaust - DDM Probeam/Backbone/Venom brace - Short throw shifter - Full LED conversion - Michelin Pilot Sport 4S
Greatgab is online now
post #20 of 26 (permalink) Old 01-19-2019, 08:45 AM
wspohn's Avatar
Yes. Vince hadn't tuned a Kappa before my car although he had been active with Cobalts for awhile. I explained that I wanted to eventually upgrade to a big wheel turbo once my warranty expired and he was kind enough to send me the basic Trifecta tune and then to follow up with a custom tune (absolutely needed when you do anything as serious as changing the turbo) later when I added that.
It took 4 or 5 refinements (send it out, install it, do a data capture to send back to them so they could fine tune, repeat as necessary) to get things perfect.
It is probably possible to do the job in just a couple of tries give all the experience they have had now.
Mine is tuned for 94 octane with no ethanol content (we are fortunate in being able to get that from Chevron here) so I generally avoid full boost when travelling in areas with other mixes, although the built in safeties would probably cut back ignition etc. to compensate safely.
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
post #21 of 26 (permalink) Old 01-22-2019, 05:52 AM
Nervous Norvous's Avatar
Brethern,
What appx. would the HP increase be with the GMPP tune .I have a 2007 GXP
Thx, Nervous
Nervous Norvous is online now
post #22 of 26 (permalink) Old 01-22-2019, 07:20 AM
Originally Posted by Nervous Norvous View Post
Brethern,
Thx, Nervous
Search is your friend: https://www.solsticeforum.com/forum/...07/#post782267
post #23 of 26 (permalink) Old 04-28-2019, 11:42 AM
Don't know if this thread is still being read but the advertised gain from the GMPP tune kit was 30bhp.
I was more interested in the additional 80 lb/ft it offered. We still get hung up on bhp. Frankly these cars may be 'light' compared to many modern cars but as a two seater they are hardly svelte at all. The torque increase was quite noticeable in the '07 GXP I had the GMPP kit installed on.
One thing that makes me hesitant for several tunes is that vague terms are used to describe the results.
post #24 of 26 (permalink) Old 04-28-2019, 02:04 PM
The GMPP tune is about 290BHP not quite 300 as mentioned. The torque is well over 330.
LatinVenom is online now
post #25 of 26 (permalink) Old 04-28-2019, 03:15 PM
Advertised as 290bhp and 340 lb/ft and I always wondered what real gains were
post #26 of 26 (permalink) Old 04-29-2019, 08:22 AM
wspohn's Avatar
According to GM:
Cobalt 2008-2010 HP & Torque ratings:
280HP @ 4,700 RPM
320 lb,-ft of torque @ 4,300 RPM
This performance upgrade maintains no-lift shift feature on Cobalts and HHR's and adds it for the Solstice/Sky.
Note:
Solstice SKY HP & Torque ratings:
290HP @ 5,200 RPM
MT 340 lb,-ft of torque @ 3,600 RPM
AT 325 lb,-ft of torque @ 3,600 RPM
HHR HP & Torque ratings:
290HP @ 5,200 RPM
MT 315 lb,-ft of torque @ 4,800
AT 315 lb,-ft of torque @ 4,800
2007 BMW Z4M coupe
Bill in BC
wspohn is offline
