good manual transmission fluid/oil? - Page 2 - Pontiac Solstice Forum
post #16 of 30 (permalink) Old 06-23-2010, 10:58 AM
lil goat's Avatar
That would be a personal choice, I have had no issue's with the synchromax, if you go to the web site they have a tech support link, ask them. They have always gotten back to me really quickly.
Wester's Garage tune
RMR Style Bar.
HKS Coilovers
JL Audio 10" sub
lil goat is offline
post #17 of 30 (permalink) Old 11-18-2010, 04:57 PM
Jebsmith's Avatar
so RP syncromax 75w90?
V-8 B8
Jebsmith is offline
post #18 of 30 (permalink) Old 11-18-2010, 08:38 PM
Jeb, I was going to go that route. After talking with Royal Purple tech support, I returned the Syncromax. RP says 10w40 is the best for our cars.
imaj is offline
post #19 of 30 (permalink) Old 11-18-2010, 11:23 PM
SOLSTICE-D's Avatar
Could the 10w40 be used for the transmission and diff?
2006*COOL*SOLSTICE
POWDER COATED RIMS
C.F INTERIOR
STEREO: ALPINE SPS-610C, PRECISION POWER 8"
DEBADGED
A.E.M: COLD AIR INTAKE
MAGNAFLOW: DUAL EXHAUST
GXP PARTS: BUMPER, SPOILER, FULL FE3 SUSPENSION
EIBACH SPRINGS: SPORT LINE
KAPPASPHERE: REBAR
DDMWORKS: RACE BACK BONE
ASAP.DIGITAL.IMAGING: SLOTTED BACK UP LIGHTS,SIDEMARKERS,THRID BRAKE LIGHT,TRANSFORMER OVERLAYS
SOLSTICE-D is offline
post #20 of 30 (permalink) Old 11-19-2010, 01:43 AM
bigblau's Avatar
Thanks gmtech for the great explanation
For what it's worth I use Red Line for drivetrain:
--MT-90 75W90 GL-4 Gear Oil for Trans.
--75W90 GL-5 Gear Oil with a couple ounces of their Limited Slip Friction Modifier for diff.
Mobil 1 for engine.
Emotions Feelings and Values
"Many of life's failures are people who did not realize
how close they were to success when they gave up."
Thomas A. Edison
bigblau is offline
post #21 of 30 (permalink) Old 11-19-2010, 06:37 AM
Use 10w40 in a manual trans ONLY! Use RP max gear 75w90 for the diff. ONLY.
imaj is offline
post #22 of 30 (permalink) Old 11-19-2010, 02:27 PM
Jebsmith's Avatar
excuse my ignorance but 10w40 motor oil? or is there a 10w40 transmission oil?
V-8 B8
Jebsmith is offline
post #23 of 30 (permalink) Old 11-19-2010, 03:37 PM
Motor oil. (The XPR stuff.)
imaj is offline
post #24 of 30 (permalink) Old 11-19-2010, 03:40 PM
Jebsmith's Avatar
wow. on a different topic.... Maybe I dont need to change the fluid. But for some reason i push the clutch in all the way and it seems to not completly disengage all they way all the time. I thought chgnaing the xmission fluid would remedy this some what, maybe there are other issues. I assume the clutch pedal is not adjustable?
V-8 B8
Jebsmith is offline
post #25 of 30 (permalink) Old 11-19-2010, 03:46 PM
You are correct. The clutch is hydraulic therefor it cannot be adjusted.
imaj is offline
post #26 of 30 (permalink) Old 11-19-2010, 07:39 PM
jwvess00's Avatar
Hi there!
The clutch and brakes share the same reservoir. Check to make sure you're not low on brake fluid. Beyond that, you may just need to flush/bleed the brake and clutch systems. If that doesn't help you may have more serious issues, but I'd check the brake/clutch fluid first.
Jay Vessels
jwvess00 is offline
post #27 of 30 (permalink) Old 11-20-2010, 10:55 AM
Jebsmith's Avatar
just got done using the mity vac and bleed the system. clutch still engages very close to the bottom. I have changed to a non sac
V-8 B8
Jebsmith is offline
post #28 of 30 (permalink) Old 11-20-2010, 11:35 AM
SAC= Self-Adjusting Clutch? The self-adjusting feature is in the throw-out bearing. Did you somehow change to a non-self-adjusting throw-out bearing assembly?
2008 Saturn Sky Red Line
5 Speed Stick, Chrome Wheels
Black with Black Top and Black Leather
Single Disk Monsoon
Yogi is offline
post #29 of 30 (permalink) Old 11-20-2010, 07:58 PM
Jebsmith's Avatar
I changed the clutch and flywheel to a Spec non sac. There is no throw out bearing, its like a throwout bearing and slave cyl all in one.
V-8 B8
Jebsmith is offline
post #30 of 30 (permalink) Old 04-09-2019, 06:56 PM
hmm I wonder what toyotas& the colloroado used in thier trans....I dont like redline, not a big rp fan, not a mobile fan either.I run penizoil syn75-90 gl5 in my bug transaxle.
marksbug is offline
