How do I get to 400-450whp for minimal cost? - Pontiac Solstice Forum
 21Likes
post #1 of 43 (permalink) Old 08-27-2019, 12:24 PM Thread Starter
I'm looking to get to 400-450whp without building the engine or breaking the bank. What are the best mods for the buck? Need it to be somewhat reliable too.
Already have 3bar and a tune.
2007 Solstice GXP
laser411 is online now
post #2 of 43 (permalink) Old 08-27-2019, 01:00 PM
stevebot39's Avatar
Location: Cleveland Heights OH in summer, Tucson AZ in Winter
If you can get an honest 300 hp out of 2 liters you are already in exotic company. Think Ferrari, Bugatti, Porsche. These engines are usually turbo AND supercharged. NOBODY short or racers get 200 hp per liter.
I would go for a V8.
Unless you add a supercharger and run E85.
Good luck. I look forward to hearing what you do.
SteveBot39
Summer Solstice, Cleveland Heights OH - '09 NA Auto Mysterious Black Coupe; DDM Supercharger, MagnaFlow, DDM chassis kit, Hawk brake pads, Conti EC Sport tires on Black ASA wheels, Advent radio w/ NAV and b/u camera. Plate SOL 4 OH
stevebot39 is online now
post #3 of 43 (permalink) Old 08-27-2019, 02:08 PM
znaut's Avatar
You may get reliable or you may not. So far mine has been but the stock pistons on these cars are a bit of a crap shoot.
I haven't had mine on the dyno but the MAF reads 44lbs/min at 6400 rpm so I am probably in the neighborhood of 400 to the wheels. I run an EFR6758 at 27-28psi on E47 and methanol injection. I also have the Werks intercooler and high flow cat.
My theory is that the methanol is important for the durability of the pistons in keeping the combustion temps down. E47 helps with this as well. My intake temps are the same at idle as they are at 27psi and the end of a third gear pull.
Mine is a daily driver. No issues so far.
znaut is offline
post #4 of 43 (permalink) Old 08-27-2019, 05:01 PM Thread Starter
Anything else under there? The 3 bars are good for 29psi right? Does the 6758 spool faster than the k04?
I have been collecting info for a few weeks and here is my current blueprint (subject to change):
-Either upgraded k04 or EFR6758
-Werks intercooler
-High flow cat
-Cold air intake and charge pipes
Late game:
-Larger throttle body
-Upgraded fuel rail, HPFP, injectors
-Carillo rods and wiseco piston
I heard some of us are running 500-600HP with the lnf, what are they doing?
2007 Solstice GXP
post #5 of 43 (permalink) Old 08-27-2019, 05:24 PM
You can't get there from here
showtime and raygun like this.
post #6 of 43 (permalink) Old 08-27-2019, 05:24 PM
You MUST upgrade internals to go past 350hp. First steps are IC tubing, IC, HFC, freer flowing exhaust (Solo Street Performance has no mufflers and is quit enough) and CAI. This will get you to about 350hp, then internals, then turbo and finally a tune. You could go to e85 if you can find a bigger lob for the HPFP and much bigger injectors. Tony owner of ASAP Graphics, IMSMC was pushin over 600hp (I wanna say it was almost 800hp, but I'm not certain)....I watched him SMOKE a Mustang GT500 one night. I tried to warn the Mustang.
Your best bet is either an LS motor, or the Supra block with mods....
post #7 of 43 (permalink) Old 08-27-2019, 05:30 PM
stuck's Avatar
Rob's right. You don't.
It's sticky!!!
stuck is offline
post #8 of 43 (permalink) Old 08-27-2019, 05:35 PM
Cheap - Fast - Reliable
Pick 2
Amorget is offline
post #9 of 43 (permalink) Old 08-27-2019, 05:40 PM
CycleCat's Avatar
Pick 2
I was thinking the same thing. Was about to make that three circle graphic like we had at the motorcycle shop "Fast, cheap, good: You can pick two!"
Chris
CycleCat is offline
post #10 of 43 (permalink) Old 08-27-2019, 05:45 PM
CycleCat's Avatar
Here it is! Just substitute "reliable" in place of "good."
Amorget and mike.robinmc like this.
Chris
CycleCat is offline
post #11 of 43 (permalink) Old 08-27-2019, 05:52 PM
znaut's Avatar
Well there's a minimum cost to achieve a goal. I have probably about $5000 in power parts including the tune and HP Tuners.
znaut is offline
post #12 of 43 (permalink) Old 08-27-2019, 06:22 PM
znaut's Avatar
-Werks intercooler
-High flow cat
That's pretty much it. You don't need the intake and charge pipes to make the power. I have them but they are just for aesthetics.
Get the 6758, it's a great turbo. Boost threshold is maybe a 100-200 rpm later but it's not very noticeable. I do recommend meth injection (with or without ethanol) and you'll need a tune/tuner.
Stock pistons may or may not make it. Just be ok with the possibility of having to rebuild with better rods and pistons if it comes to that.
Larger turbo/more boost (EFR7163) and higher redline. Built bottom end, stiffer valve springs, neutral balance shafts (or none), etc. You could drop the compression a little to facilitate additional boost but that would probably require a full custom piston. I don't know if there's anything off the shelf that will do that.
znaut is offline
post #13 of 43 (permalink) Old 08-27-2019, 06:54 PM Thread Starter
Everything I've read so far from just about everywhere says that the stock bottom end is good for 400-450 and needs to be built if exceeded. Is that not true?
I don't mind spending some money but I dont want to exceed 4-5k
2007 Solstice GXP
post #14 of 43 (permalink) Old 08-27-2019, 10:04 PM
Mine didn't survive... ended up buying a new engine and am installing pistons and rods in it.
Amorget is offline
post #15 of 43 (permalink) Old 08-27-2019, 10:23 PM
skersfan's Avatar
Spend/build/break/repeat. No way to do what you are wanting to do without a lot of money, talent and patience.
It is not going to be dependable, reliable nor a daily driver. Maybe a daily project for months.
More education, a rich girl friend, become a trusafarian. These are the things that will make it easy, not cheap.
But either way have a ball on your road of a lot of fun and destruction.
rob the elder likes this.
skersfan is offline
