LDK Casting? - Pontiac Solstice Forum
post #1 of 7 (permalink) Old 06-11-2019, 07:34 AM Thread Starter
Saveaux's Avatar
LDK Casting?
ZZP claims that the LDK is a third gen block that's different than the LNF in the fact that it's sand cast as opposed to the LNF's foam casting.
Apparently the foam casted blocks are more porous and crack.
Wikipedia states that the LDK is foam cast and that the sand cast blocks weren't made until the LHU (one model after LDK).
Wiki also states that the "gen 2" turbo blocks are the LNF, LDK, LHU.
So ZZP claims the LDK is gen 3 and sand cast. This is very different than what Wiki states. Who is truly correct? Does the LDK block not suffer from the porous castings??
Thank you for your time and help in this matter!!!
Saveaux is offline
post #2 of 7 (permalink) Old 06-12-2019, 12:39 PM Thread Starter
Saveaux's Avatar
Bump.....I'd like to order a new engine, just wanted to clear this confusion up first.
Saveaux is offline
post #3 of 7 (permalink) Old 06-12-2019, 05:28 PM
The block, head and internals are the same the main difference is the oil pan, but you can't use the fwd oil pan.
I don't remember if the LDK have the Opel injectors, but the LHU does (you need to retune your car for those injectors or switch them with yours)
SSolstice is offline
post #4 of 7 (permalink) Old 06-12-2019, 05:36 PM
The Silver Fox's Avatar
I think you'll find your answer here:
https://www.cobaltss.net/forums/2-0l...rences-276906/
The Silver Fox is offline
post #5 of 7 (permalink) Old 06-12-2019, 11:12 PM
I would get the sand cast.it is stronger and dosent have the leek/seep issues.
marksbug is offline
post #6 of 7 (permalink) Old 06-13-2019, 04:06 AM
There are threads by members who used ZZP motors in their Sol. I will go looking
rob the elder is online now
post #7 of 7 (permalink) Old 06-14-2019, 10:38 AM
znaut's Avatar
I think the general consensus is that (most) LDK blocks are sand cast.
https://www.cobaltss.net/forums/2-0l...-block-320732/
znaut is offline
