Performance auto werks intake and IC pipes - Pontiac Solstice Forum
post #1 of 4 (permalink) Old 10-17-2018, 09:55 PM Thread Starter
CPayne's Avatar
Just got them in today and the maf plate is upside down. So the air will not flow properly. I then checked the passenger side IC pipe and the hole for the map sensor is about 1/8" off so you can't screw it in. I have contacted Dave. I am very disappointed. I have wasted about 2 hours installing this stuff because someone there was careless.
CPayne is offline
post #2 of 4 (permalink) Old 10-17-2018, 09:57 PM Thread Starter
CPayne's Avatar
Here is a picture of the issues.
ID:	91719   Click image for larger version
CPayne is offline
post #3 of 4 (permalink) Old 10-17-2018, 10:12 PM Thread Starter
CPayne's Avatar
Would not have posted this here except they screwed up during the summer and "forgot" to ship my stage3+ clutch and aluminum flywheel... They sent it like a week after I complained.
CPayne is offline
post #4 of 4 (permalink) Old 01-04-2019, 03:48 PM
Sorry to hear that! I know that can be frustrating. Especially with something like a clutch & flywheel where you probably have a certain amount of time allocated for the install, and a shipping delay can push that by quite awhile.
That said: I've bought a lot of parts from Dave @ PWerks over the last four years, and only had one issue - two wires were swapped from their proper position in a MAP sensor harness adapter. (This item was drop-shipped from the manufacturer; the error was there's, not Werks'.) Dave identified the issue very quickly and offered to replace the errant part Real Fast. Fortunately, I was able to fix it myself in about 10 minutes once we identified the problem.
In my experience, stuff like this happens with smaller shops and low-volume cars a lot more than it would with, say, a Miata parts vendor. But, I've found DDM, PWerks and RPM to be very responsive when there is an issue.
