Tuning - misfires at high(ish) boost - Page 3 - Pontiac Solstice Forum
 7Likes
post #31 of 38 (permalink) Old 01-03-2019, 02:02 PM
What is "CRC?" I'm thinking error detection & correction, but that can't be right.
CRC is a brand name. e.g...
Sting Ya and raygun like this.
post #32 of 38 (permalink) Old 01-03-2019, 05:39 PM
SaturnSkyDude's Avatar
My friend used CRC Intake Valve Cleaner that is safe for direct injected engines and turbos. He pulled the sensor on the cold side of the intercooler pipe (to bypass the turbo). He used a heat resistant putty to hold the solvent straw in place (and to seal the rest of the hole) and sprayed in the cleaner. He followed all the instructions on the can. Right after that, he changed the oil (as it was dirty with carbon) and the car ran fine.
Please Support The:
Be The Match Bone Marrow Registry
Drove My Redline home top down on 12/12/06
In Akron, Ohio !!
Silver Pearl / Black Leather
5 Speed
Limited-Slip Differential
Chrome Wheels
6-Disc CD Monsoon
B Series Stubby Antenna
Enjoying Another Cancer Free Day
SaturnSkyDude is offline
post #33 of 38 (permalink) Old 01-03-2019, 06:07 PM
wmf246's Avatar
it's a Brand Name... see post 17
Bill
wmf246 is offline
post #34 of 38 (permalink) Old 01-04-2019, 10:32 AM
I'll flash it back to stock this weekend and compare boost levels vs GMPP. What sort of boost should I expect from the GMPP tune? I also need to get it out on the highway and log some WOT pulls.
Spark plugs are the Delco 41-108s, which come pre-gapped.
Also, I previously had a CEL due to multiple random misfires, even before the new tune. There's something else going on here. I replaced the HPFP recently, but as far as I can tell the new one is working fine.
It's still a balmy 40 F here; supposed to be back up close to 70 in the next day or two. New Year's resolution: clean out the garage so that my wrenching time isn't restricted to good weather days.
What are they pregapped at? Just because they are pregapped doesn't mean they didn't get knocked around in the boxes messing up the gaps. Also, the gaps may still be too far for the strength of spark your coils are putting to them (thus blowing spark out).
The Gmpp should be the same (fairly close) amount of boost as a trifecta tune which should be around 20 to 24psi. 14psi is flat out stock. I'm saying this because you are only 800 ft above sea level so it won't have that much of an effect on your boost levels either. Regardless you should be seeing around 20+ psi with the GMPP.
MattM is online now
post #35 of 38 (permalink) Old 01-04-2019, 03:30 PM Thread Starter
They're at 0.035, I think? They were all identical, with the little plastic cylinders protecting the electrode. I'll pull them and check again, but I've been told by more than one tuner not to mess with the plug gap if it's at spec.
My handy-dandy endoscope showed up today, so I pulled the brake booster hose & nipple off of the manifold and had a look. There's so much crap in the thing that I'm not sure how it runs *at all*.
If I can get through the honey-do list tomorrow, I'll go ahead and pull the manifold and clean things up.
Sting Ya likes this.
post #36 of 38 (permalink) Old 01-23-2019, 10:58 AM Thread Starter
Solved, finally.
After walnut blasting the (REALLY gross) intake valves, replacing the bypass valve that I broke, replacing the cam actuator solenoids - I wasn't getting a code, but they looked pretty rough and I had a set in a box from the other car - everything is working very well.
These are from Virtual Dyno, based on some HPT logs. Obviously that's not as accurate as a real dyno, but the buzz online is that this should be really close. Having owned & driven a number of other cars in that power range, I don't have trouble believing that the numbers are close to reality.
3rd gear is a pretty graph,
But 4th is the 1:1 ratio gear, so it's probably more accurate:
ID:	93157   Click image for larger version
post #37 of 38 (permalink) Old 01-23-2019, 12:43 PM
Saveaux's Avatar
Wow!! Great numbers Raygun!!!
Saveaux is offline
post #38 of 38 (permalink) Old 01-26-2019, 04:32 PM Thread Starter
@Saveaux Yeah... the more I think about it, I think I'm just not handling the virtual dyno software correctly. Getting the right data out of HP Tuners is a bit of a trick. If you include data from part of the log that was in a different gear, the charts go nuts. I need a button on the steering wheel that will tell HPT to stop and start logging. I could probably find some sort of USB or BT "button" and map that to a key macro... (Thought for the day: over-engineering is under-rated.)
Once I get it on the real dyno on March, we'll see.
But, fun fact: if you floor it in second, the traction control turns on.
I had another few misfires after logging some hard 3rd gear pulls, so something else is still going on. Hopefully the next revision of the tune will address that.
