What IATs should I be seeing with trifecta base tune stock turbo.. - Pontiac Solstice Forum
post #1 of 1 (permalink) Old 05-16-2019, 09:37 AM Thread Starter
Hey guys... I took the redline out last night and had the computer hooked up and decided to do a full wot run us in the nls through each gear. After my first run I was seeing around 110 degrees on a 65 degree day.
Also saw up to 5 degrees of kr early in the rpm range that went away. I felt a little "let up" from the cars pull at around 5k rpms that only last maybe 200 rpms.
I just put on the solo hiflow do as well. I would think better flow from the engine would result in lower IATs but the turbo probably had to spin a little harder to maintain the 20-23 commanded psi from the tune.
Just wondering what IATS you guys usually see with the trifecta.
Thanks!
MattM is offline
Similar Threads
GMPP Tune + Trifecta Tune? ChopTop General Solstice Discussion 20 04-26-2019 12:58 PM
Any Dyno's Of Redlines or GXPs on Base Trifecta Tune with Solo HiFlow Downpipe? MattM Mods - Engine 2.0 Turbo 4 02-08-2019 10:47 AM
DDM 2.0 Tune vs Trifecta Tune ILSolsticelvr DDM Works 14 02-28-2017 12:22 PM
Base Solstice Trifecta tune input Ozone2552 Mods - Engine 2.4 l Ecotec 24 12-21-2014 11:25 AM
Trifecta Tune or DDMWorks SuperCharger Tune Rx4theSol Mods - Engine 2.4 l Ecotec 0 10-24-2013 11:37 PM
