Mallett owners or those with V8/AR5 - Page 2 - Pontiac Solstice Forum
 4Likes
post #16 of 25 (permalink) Old 07-21-2016, 01:29 PM
Originally Posted by skersfan View Post
Thanks for that information JohnWR. I will check with my dealer and see if I can order one as soon as I get the smog and registration done.
Do not get the G-80! get a Quaife: Quaife Limited Slip Diff LSD GM Sky Pontiac Solstice cts V6 Opel GT w Bearing | eBay
Details here: Quaife Limited Slip Differential
The Quaife is much stronger than the GM G80.
Yogi
2008 Saturn Sky Red Line
5 Speed Stick, Chrome Wheels
Black with Black Top and Black Leather
Single Disk Monsoon
Yogi is offline
post #17 of 25 (permalink) Old 07-21-2016, 01:38 PM
mkriebs's Avatar
I have never seen a failure in the actual differential mechanism, so to say the quaife is much stronger is a fallacy. It's probably more effective, depending on the intended use of the car, but it isn't necessarily stronger.
mkriebs is offline
post #18 of 25 (permalink) Old 07-21-2016, 02:48 PM
Saturn Sky Forums: Saturn Sky Forum - View Single Post - What is the true potential of the Redline?
https://www.solsticeforum.com/forum/1624178-post1.html
I saw some pics of one recently but today I couldn't find them.
Yogi
Single Disk Monsoon
Yogi is offline
post #19 of 25 (permalink) Old 07-21-2016, 03:42 PM
I have read of axle failures. And read of differential failures in non-modified cars. But its news to me to see your post Yogi.
Thanks for keeping us informed.
post #20 of 25 (permalink) Old 07-21-2016, 03:50 PM
You're quite welcome, Rob. I wish that I could've found the more recent photos.
Yogi
Single Disk Monsoon
Yogi is offline
post #21 of 25 (permalink) Old 07-22-2016, 03:45 PM
mkriebs's Avatar
Sorry, I should have used the term "carrier." The carrier is the piece that the ring gear bolts to, this is the Quaife part you're referring to. The parts that Travis (blackbird) and others have are case failures. This happens because the torsional force on the pinion and the ring gear causes the pinion gear to try to push toward the front of the car. The case is weak in the "snout" and the pinion puts so much pressure on that portion that it eventually breaks the case.
This could happen for a number of reasons, my guess would be the pinion trying to climb the ring gear, which could be alleviated a couple ways, but is an issue from the factory, as evidenced by the noisiness of the 06 diffs. Different backlash would help this a little bit.
The reason the CTS differential units appear "stronger" is because of the lower gear ratios. There is much less stress in a 3.23 or 3.42 gear than there is a 3.73 or a 3.91. Less torque means less torsional pressure to push the pinion out.
Hope that makes sense. This is why GMTech made the brace that he made, it holds the front of the case onto the rear so the torsional pressure isn't as stressful on the case.
2007 Solstice GXP - Canyon Carver in progress.
LQ4 V8, LS6 intake, BTR Stage IV cam (235/242 .621"/.592" 111+3), LS6 intake, T56 transmission, custom cooling system, custom roll bar, MegaSquirt ECU with traction control.
*All work done in house*
- Expecting 450whp.
mkriebs is offline
post #22 of 25 (permalink) Old 11-23-2016, 02:13 PM
cammerjeff's Avatar
Looks Like I will also be looking for a 3.23 LSD Carrier soon, but I will have to see how I like the driving experience this spring.
2009 G8 GT
cammerjeff is offline
post #23 of 25 (permalink) Old 10-29-2018, 05:57 PM
I am curious about the flywheel, pilot bushing and clutch assembly to match up a 4.8 o5.3 etc...to the stock AR-5. I have read many posts and searched quite a bit and still cannot find a good source for information. I just want to have everything ready when I start my swap.
Dusty Rose is offline
post #24 of 25 (permalink) Old 10-29-2018, 05:58 PM
Also would like information on bellhousing or conversion ideas.
post #25 of 25 (permalink) Old 10-30-2018, 06:38 AM
ChopTop's Avatar
FWIW, there's a "Kappa Swap" group on FaceBook, the focus is V8 swaps. It's a closed group so you'll have to join to ask questions or make comments.
ChopTop is offline
