Shifting Problems - Pontiac Solstice Forum
post #1 of 8 (permalink) Old 05-22-2019, 06:00 AM Thread Starter
Shifting Problems
I just purchased a 2016 Slingshot (Pontiac Solstice drivetrain) with 4200 miles on it. I have only driven the vehicle about 20-30 miles and now I am having trouble with it shifting into 1st gear and also reverse, very very hard to get into reverse. I have the pedal pushed all the way to the floor and cannot get into 1st or reverse without extreme difficulty.
bcffprez is offline
post #2 of 8 (permalink) Old 05-22-2019, 06:23 AM
will it go into those gears eazely when the engine is not running? if so it's probably in the clutch system.
marksbug is offline
post #3 of 8 (permalink) Old 05-22-2019, 07:22 AM
Location: Phoenix Arizona where there are about 250 days a year for convertible Bebop-ing
OK prez, I'll take a stab at it. It is a hydraulic clutch. I had MG's with hydraulic clutches. So if it is installed on a different vehicle it might fix your problem to simply "Bleed" the system and fill it with fresh hydraulic fluid to get the air out. Plus usually a hydraulic system is actuated soething like a brakes master cylinder with a shaft tha comppresses the fluid. You know what I mean. If there is an adjustment on the shaft move it about 1/4 inch. dont try to sneak up on it a few turns at a time you'll be there all day. I am not an expert on Solstices!
Bebop2 is offline
post #4 of 8 (permalink) Old 05-22-2019, 07:50 AM
Talk with Dave at DDMWorks. they specialize in the slingshot and have a lot of experience with them
post #5 of 8 (permalink) Old 05-22-2019, 09:50 AM
Reverse is frequently an issue with the Aisin transmissions. I sometimes have to shift into third, then neutral, clutch out then in, and then go to reverse. Sometimes multiple tries. No problems with first, though.
If all of the other gears are working the clutch is probably OK. There isn't anything I can think of that would make a difference there. When my master cylinder was failing all of the gears were equally difficult to engage from stopped.
post #6 of 8 (permalink) Old 05-23-2019, 05:53 AM Thread Starter
Update! Found that the small reservoir was low on fluid and after filing up heard a slight vacuum sound coming from the underside of the reservoir when disengaging clutch pedal. going to replace the hose first and see if that fixes problem also check the neck on the bottom of the reservoir to see if cracked or broken. but that seems to be the leakage problem. There appeared to be a slight bit of moisture around the master where the clutch rod inserts into it. The local shop said with infrequent use of the machine (4200 miles in 3 years) that the seals could have dried slightly and could rework themselves back into seating fine with more frequent use
bcffprez is offline
post #7 of 8 (permalink) Old 05-23-2019, 05:56 AM
Hopefully you have found the issue and have it on the road to recovery
post #8 of 8 (permalink) Old 05-23-2019, 07:25 AM
Glad you found what appears to be a simple solution.
I hope that your seals re-seat, especially the slave cylinder.
Similar Threads
Shifting problems paul shelp General Solstice Discussion 1 11-16-2006 06:07 PM
Problems and more problems! MyNewSolstice General Solstice Discussion 19 05-29-2006 11:17 AM
problems problems problems mybaby General Tech, Platform Common Issues & Solutions 43 04-19-2006 07:12 PM
Problems shifting into reverse [Solstice Issue] toyman General Tech, Platform Common Issues & Solutions 27 10-25-2005 10:35 AM
Heel-toe shifting? giranda General Solstice Discussion 22 07-01-2005 09:48 PM
