1 - 8 of 8 Posts
Hi. In my experience, it has been a process, not an event. Just for the database, open your trunk and take a real close look at your main hinges on both sides. Is there any paint scraping wear? Is anything bent? Close the hood and watch the operation of the hinges. I say this because I started to adjust my trunk for the same problem you are having and I noticed my hinge was bent way out of whack.:smash:
At first, I thought it was just an adjustment. See page two of this post to see some pictures. http://www.solsticeforum.com/forum/f12/rear-deck-hinge-bolt-73494/
Why did it get bent? Who knows. I am the second owner. I have the part. It just has to get warm enough here in southern Virginia for me to install it. Anyhow, if the hinges are not up to snuff, all the adjusting in the world will only make your overall condition worse. As much as I love this car (2008 Base Premium) the body panel fitment is worse than any other car I have ever seen, excepting the Original Griswald Family Truck'ster.
If you read the PDF, the instructions are pretty much right on. The pictures are OK, but sometimes the text is a bit off. The movement of things is easy. The problem is you move it to one place, and then someplace else pops up, or down. It can be accomplished; it's just a process. If you would not mind, can you post some pictures of your condition and your work? I am very interested in lining up the body panels, and I prefer to see the real deal daily driver out in someone's backyard, rather than two guys working on a new car in a shop.:driving:
Usually the hinges are bent, because someone opened the trunk and it was windy, causing the trunk lid to fly open and overextend itself........Common to non or first time soltice owners.
my 06 seems to shut good but you have to push the top down real good. I don't know if it's common buy I have 2 small dents on the rear deck and I guess this is from someone forcing the lid shut without having the top all the way in. almost tempted to take out my rubber mallet and knock them in but don't want to crack the paint so unless someone has done it with good results, I guess I'll live with it.
Charlie
well, I just answered this myself. this forun is already paying off. page 25 of the body adjustment PDF. Now all I got to do it replace the hinges. anyone done this yet?
Charlie
1 - 8 of 8 Posts
