Hello everyone. I hope you all can help out a new owner. I've had my 2008 Sky Redline for one day and I already messed up the top.
I believe I may have latched the top incorrectly and bent my latch upward. I couldn't line up the latch correctly any more so I took some pliers and bent it downward.
This got everything lined up correctly but now when latched, it would not stay locked in and could easily be pulled back out with a little bit of pressure.
I kept playing with it and got that part fixed but the next problem is the handle would not tighten the latch. It would get real close to latching but once it got to the point where some pressure was needed the lever would turn but the latch would stay still.
I tried to tighten the bolt in the lever thinking that was the problem but ended up torquing the head of the bolt clean off
Took it to the dealership and they want me to pay $341.88 for the part and a total of $879 for part & labor. That is just a rip off :brentil:
Anyone have any experience replacing the latch and can help me make sure I pick up the correct part from gmpartsdirect.com or another site?
I found two parts that I think are correct, and they may or may not be the same part.
I found this one labeled "LOCK Solstice; Front"
GMPartsDirect.com - Find a Item
And also found #20 on this diagram which is labeled "lock left"
I believe they are the same part since they have the same price but I'm not sure. Also the second one is labeled left for some reason.
Also these are both for a Solstice...am I correct in assuming that it should work for the Redline as well?
Did I find the correct part?
On another note, I would of loved to install this part myself. I took off the bow bracket of the top only to find that the cloth is glued to the framing of the convertible top. That makes me a little nervous to mess with. Anyone have experience or another way to get to the latch?
Thanks again guys!
Thanks again guys!
