1 - 15 of 15 Posts
So, I blew a headgasket on my WERKS Turbo 2.4 Solstice lol. Soooo that just means time to build her up. Well.... Budget build....
I need these parts, so looking at seeing if one of the vendors would like to help me out!!
I know all these links are from WERKS but I'm open to other ideas also.
ARP LE5 Head Stud Kit, Performance Autowerks
WERKSracing LE5/LE9 Single Valve Springs, Performance Autowerks
Ecotec Front Cover Gasket 24435052, Performance Autowerks
WERKS Racing 2.4L Street/Race MLS Head Gasket Kit, Performance Autowerks
NGK Sol/SKY 2.4L Turbo Spark Plugs (set of 4), Performance Autowerks
https://agpturbo.com/precision-5431e-mfs/
Why aren't you going with one of the known, tried and true turbos from the vendors? Their turbos have been tested and work best reducing lag and giving the best power for that motor possible.
If I know what numbers mean on turbos, the one you have picked out is going to be horribly laggy and push very little air. Furthermore it's not twinscroll which drastically reduces lag. While this is my $0.02 and I know very little about different turbos other then what our vendors offer, I'm not quite sure you want the one you posted.
You also might want to check out zzperformance.....But I would stick with ddmworks or PAW first.
Headgasket
FYI performance autowerks head gasket for $150 is nothing more than the factory head gasket with a spray on coating... do not buy it for that price... i built 2LNF's and the second time there was an imperfection on the gasket, i sanded the area where the part number would be on a gm gasket, and guess what? there was a gm part number... when i confronted Dave, he didn't deny it... So buy the factory gasket and save your money. It's a multi layer steel and should be good to 30psi....
Well. Dave just sent me this:
Hey Brian,
We can beat any price out there just so you know. Shoot me over you prices yo uare seeing and I am sure we could do better. Also, as far as the head gasket goes, that is for a completely different head gasket than the LE5 head gasket. The LE5 head gasket is made by Cometic and does not come with a coating on it.
I do not like dealing with ZZP. Very long reason as to why but I use to deal with them in the Grand Prix world way back when and would go with DDM, Werks, Hahn or RPM before ZZP.
The gaskets and stuff OEM are good to go other than the head gasket. That one you COULD go with something special but the OEM unit...especially with the ARP studs...should be good.
What I wonder is though what blew the head gasket? I blew one out in my Grand Prix because the car developed a leak after seeing 9 degrees of KR (long story) and over pressurized the cylinder. (The engine was built out and under the stock parts never had an issue but then never saw that kind of pressure.) What kind of boost are you running on the Werks turbo? Are you still stock 10.5:1 (I think that's our stock LE5 ratio) compression?
Second thing I wonder is what's your goal? What's your desired end result of these modifications?
One more question I have...and this is as much for me as for you...LOL Does anyone make LE5 Turbo cams? I have seen Comp Cams have some NA LE5 cams but no idea how these work with a turbo motor nor have I seen turbo specific cams for this engine.
...One more question I have...and this is as much for me as for you...LOL Does anyone make LE5 Turbo cams? I have seen Comp Cams have some NA LE5 cams but no idea how these work with a turbo motor nor have I seen turbo specific cams for this engine.
Robo, I'm with you. I have looked high & low trying to find a cam for the 2.4, but everybody seems to be manufacturing for the 2.0. Spoke with Dr Dave & he said that you would have to find somebody to reman our stock cam. Didn't feel like messing with that.
Brian85 - Budget build + 2.4 + Forced Induction = Oooooops, it blew again. Save your pennies to beef up the bottom end. That's the 2.4's weak spot as far as boost goes. DDM has forged pistons & rods for the 2.4.
I want to see how far I can take the stock bottom end. I own a repair / performance shop and have done a lot of boosted builds. I have a 750hp SRT8 Magnum, 600AWHP Audi S4. I came across this car and it really got me interested lol.
I did a compression test and Cyl. 2 & 3 have no compression where 1 & 4 have 165, so that is a sign of a blown headgasket on the compression side between the two cyl. I was doing a WOT pull and the boost spiked ( unkown at this time as to why ) up to 33 PSI. I was watching my A/F ratio and it was still pretty rich lol but I backed out right away so I don't think I did any damage to the bottom end.
My goal is to have a very fun daily summer car to build up for my shop as advertising in this platform.
FWIW, early 2.4s used forged rods, later ones switched over to powdered metal.
Here are the different part numbers for the rods:
2006-2007: 12596088 A 2.4-B/P (LE5), (1ST DES) ROD, CONN (FORGED STEEL W/ROUNDED EDGES ON CAP AND MFG TRIM MARK AROUND OUTER PERIMETER) (FOR 2ND DES SEE 12611360)
2008+ 12598216 A 2.4-B/P (LE5), (2ND DES) ROD, CONN (POWDER METAL W/SMOOTH SURFACE CAP AND SINGLE RIDGE ACROSS CAP, W/O MFG TRIM MARK AROUND OUTER PERIMETER) (FOR 1ST DES SEE 12596088)
Any one running over 300hp on the later rods is playing with fire! (note this is only for the LE5)
I think Comp Cams will do this but never priced it out. May be something to consider IF I go head work.
This is the information I love to see. Data like this is invaluable! Great to see your experience and the diagnosis for the cause of the popped head gasket. Now to figure out what caused the boost spike!
By early, from what I've seen, it is 2006-7 LE5s. So 2006-7 Pontiac Solstices and 2007 Saturn Skys in the Kappa line.
Discussion Starter #13
That info about the rods is amazing! I'm very happy to hear that.
Well, come to find out the previous owner put on a cheap eBay China turbo. Not sure why? I'm going to be putting a new turbo on it now anyways so cleaning the oil feedlines etc. My guess is the cheap turbo waistgate maybe got stuck or something ?
Sent from my VS995 using Tapatalk
It very could have, those things are junk...
You have every right to avoid them and share your opinion of them if you had a bad dealing. I am a strong believer in boycotting companies who have taken advantage of me. I have had good luck with ZZP, I experienced some small imperfections (wrong exhaust clamp size, no screw for custom FMIC temp sensor bung). That stuff is not a big deal and I envision ZZP is a small company without a expensive inventory control system and full-time quality management...I would be much harder on a 50 million dollar company than I would with a 1 million dollar company.
1 - 15 of 15 Posts
