1 - 14 of 14 Posts
So we just received a huge shipment of our popular aluminum charge tubes and wanted to pass along the savings to you.
DESCRIPTION
The intercooler charge tubes from the factory have areas where the tubing is crushed down flat which causes turbulence in the air flow. Our tubes are custom made from aluminum just like the factory tubes, but are CNC mandrel bent for the best fitment and nice smooth air flow. Our intercooler tubes are a direct factory replacement for the stock tubes with simple removal of the stock pieces and then installation of the new tubes.
All of our tubes come with the mounting brackets on them like stock, which helps to hold the tubes in the correct place, and prevents the movement of the tubes, which sometimes causes the tubes to hub under the hood. The tubes come standard in a highly polished finish, for great looks and long term durability.
Installation instructions are included along with a silicone hump hose connector to make the connection to the turbo and all other hardware required.
Click on the link below to see more details on the sale!
Had mine done in black chrome they look beautiful .
factory installed are bent very bad .
Thank You DDM works .
LLLFLY
Do these increase HP in a GMPP tuned GXP? dynos? or are these just for looks?
Doubt they do anything at all for a stock GXP and probably nothing for a GMPP tuned car, but they look great and the crimps in the stock tubes are so unacceptable aesthetically that I swapped mine out just because it bothered me having such poorly made factory items in there.
GM is known for going cheap - they had a manufacturing process that saved them a couple of bucks on the olf Fiero V6 exhaust manifolds so they went that way. An hour with a grinder and you can get an 8 BHP bump just from doing what GM could have done with one more damned machining operation that would have cost them a few bucks! Cheap bastards!
And in that case I understand it but in this case there is no difference between stock and these other than looks? If it was an improvement I was going to purchase them for sure for $180!
wspohn, can you explain what you mean by 1 hr with a grinder can get you 8 Bhp? If thats too specific, just tell me the subject to search so I avoid getting flamed for not searching.
Sent from my iPhone using AutoGuide.com App
A close reading of what I wrote will reveal that you probably wouldn't find it here anyway as I was referring to the headers on a Fiero V6 engine. If that engine is what you want to know about, by all means let me know and I can send some info.
Dave quite reasonably stated in this thread: http://www.solsticeforum.com/forum/f101/2-0l-lnf-turbo-charge-tubes-available-61641/index2.html
that they (at that time) made no power claims as they hadn't seen any before and after dyno runs - don't know if that has changed.
Might want to look at that thread anyway as it has some fitting discussion as well as some very nice pictures of the installed tubes.
Copy that. Thought maybe you were referring to something on the SOL. Subject had switched to the Fiero but thought maybe I missed something and heck I'm up for 1hr. grind for 8 Bhp. Thanks for the kind response.
Solo Dio
GODROD
This convo is now irrelevant at this point in time as the sale has ended. I am kinda disappointed that there was no official response from DDM before the sale ended though. This is about the third time I have asked DDM a question and got no response at all, as a customer who has previously purchased multiple times from DDM I would like to see better support.
I think that you have to understand that a lot of the vendors who sell here are relatively small concerns (DDM sales are, I believe, handled by Dave and Ivy alone) so if they happen to be out of the office, or away for the weekend, you can't expect a swift answer. I'll say that they are quite responsive normally.
I understand that if the only way you were interested in buying the tubes was if they gave a power increase, you would want confirmation. Given that I do not believe that there would be any increase unless you tune beyond the GMPP stage, you aren't out anything anyway as you presumably wouldn't have bought them on that basis.
1 - 14 of 14 Posts
