1 - 6 of 6 Posts
Would like a FSM mainly for electrical diagnosis and heavy mechanical repair such as rear end, axles, trans, driveshaft, engine repair / swap, engine performance, ball joints, etc.
Will a FSM for the 2007 Solstice work for the 2006 Solstice?
Example: 2007 Pontiac Solstice Service Repair Manual Set Brand New | eBay
Is there another source I should consider?
Some parts of the electrical componentry/wiring changed between 2006 and 2007, so you may want to get the correct year set for that reason.
The mechanicals stayed pretty much the same though AFAIK.
I believe the 2 and 3 gear ratios changed a bit in 2007.
1 - 6 of 6 Posts
