1 - 6 of 6 Posts
Does anyone have the pdf file that they could email to me. I have a CD with all the 2009 info (mis-represented on ebay as 2006-2009) but I think the 2007 had a clutch position switch and not a sensor. My switch has just 2 wires coming to it and the 2009 schematic shows a clutch pedal position sensor and 3 wires. Email is [email protected].
Can anyone confirm that 2007 was a switch and 2008-2009 was a sensor?
Thanks in advance.
Larry
I know that earlier years had the switch and later years the sensor. Just not sure which model year did the transition. I did have the 2006 schematics, but am away from home - I'll see if I have 'em on my laptop and email if so.
UPDATE: email sent. Reply back here if that works or not - if not, maybe someone else can help.
07 has switch. What schematic do you want? Can send
Actually, 07 has 2 switches, 08 has sensor.
Dave
Should be separate pdf schematic
glake, the CD I have has a subdirectry for schematics. There may be as many as one hundred different files that are pdf files and they are listed in alpha order. If you look down under the Ms you should see the one for the manual transmission. Maybe there is more than one?
Anyway, what ever you find for 2007 manual tranny schematic is what I need.
Thanks,
Larry
Sent e-mail
1 - 6 of 6 Posts
