1 - 20 of 24 Posts
The title says it all. After research and troubleshooting here are the codes: B008-71; B135-03; B1370-06
I believe those codes indicate ignition switch problems. However, I cannot simply change out the ignition switch due to the security system and all that kind of stuff right? I mean, I don't know, so I am asking. Can I just change out the whole ignition switch keyhole and all without having to take it to the dealer, having them reset the computer and having them go to Hawaii on my dime? I am not a mechanic, so I would not change it out myself. I know a couple of reliable mechanics with shops. Would an independent shop be able to solve this problem?
Respectfully,
Omw41
Do you mean the letter "P"? Did you get these codes from a code reader because I'm confused where the -71, -03, & -06 numbers come from.
Do you mean the letter "P"? Did you get these codes from a code reader because I'm confused on to where the -71, -03, & -06 numbers come from.
Could be. I didn't pull the codes. My 20.00 Code reader showed nothing, but I had a mobile mechanic come over and look at it. I might have misunderstood him due to a language barrier.
P would make sense for Pontiac. As far as the dashes go, I am having someone who speaks his language call him back and see if he still has the codes.
2008 Pontiac Solstice GXP
Those are correct codes. they are module specific codes with their sub codes
Give me a few minutes to pull them up for you,
B008-71: missing a digit
B135-03: missing a digit
B1370-06: Device Ignition 1 Circuit is shorted to ground or open OR Device ON or START circuit shorted to ground or open. Need to know what the originating module is. This code is used by any module that has an ignition wire going to it. There are quite a few of them so without knowing what module set the DTC I am not able to help.
Here are all of the DTCs for a 2008 MY and newer Solstice all trims and all transmissions
DTC
Description
Module(s)
Procedure
B0012​
Driver Frontal Deployment Loop Stage 1​
SDM​
DTC B0012 or B0013​
B0013​
Driver Frontal Deployment Loop​
SDM​
DTC B0012 or B0013​
B0015​
Stage 2 Left Front Seat Belt Pretensioner​
SDM​
DTC B0014-B0045​
B0019​
Deployment Loop Passenger Frontal Deployment​
SDM​
DTC B0014-B0045​
B0020​
Loop Stage 1 Passenger Frontal Deployment Loop Stage 2​
SDM​
DTC B0014-B0045​
B0022​
Right Front Seat Belt Pretensioner Deployment Loop​
SDM​
DTC B0014-B0045​
B0052​
Deployment Commanded​
SDM​
DTC B0052 or B0053​
B0053​
Deployment Commanded with Loop DTCs Present​
SDM​
DTC B0052 or B0053​
B0081​
Passenger Presence System​
SDM​
DTC B0081​
B0083​
Front End Sensor 1​
SDM​
DTC B0083 or B0084​
B0084​
Front End Sensor 2​
SDM​
DTC B0083 or B0084​
B0283​
Electric Rear Defrost Circuit​
BCM​
DTC B0283​
B1000​
Electronic Control Unit (ECU) Performance​
BCM, DRR, IPC, Radio, RCDLR, SDM, TDM​
DTC B1000 DTC B1001​
B1001​
Option Configuration Error​
SDM​
DTC B1001 (SDM)​
B1004​
Keep Alive Memory (KAM) Reset​
BCM​
DTC B1004​
B1009​
EEPROM Checksum Mismatch​
BCM​
DTC B1009​
B1019​
System Configuration Error​
SDM​
DTC B1019​
B1025​
LF Audio Output Circuit​
Radio​
DTC B1025, B1035, B1045, or B1055​
B1035​
RF Audio Output Circuit​
Radio​
B1045​
LR Audio Output Circuit​
Radio​
B1055​
RR Audio Output Circuit​
Radio​
B1287​
External Amp Control​
Radio​
DTC B1287​
B1325​
Device Power 1 Circuit​
BCM, IPC, Radio, SDM​
DTC B1325 DTC B1370​
B1370​
Device Ignition 1 Circuit​
SDM​
DTC B1370​
B1380​
Device Ignition ACCESSORY Circuit​
BCM​
DTC B1380​
B1441​
Device Ignition OFF, RUN, and CRANK Circuit​
BCM​
DTC B1441​
B1480​
Battery Rundown Protection Circuit​
BCM​
DTC B1480​
B2455​
Cellular Phone Microphone Circuit​
VCIM​
DTC B2455​
B2470​
Cellular Phone Antenna Circuit​
VCIM​
DTC B2470​
B2476​
Cellular Phone Select Service Switch​
VCIM​
DTC B2476​
B2482​
Cellular Phone Select Service Switch Performance​
VCIM​
DTC B2482​
B2483​
Global Positioning System (GPS) Sensor Circuit Low​
VCIM​
DTC B2483 or B2484​
B2484​
Global Positioning System (GPS) Sensor Circuit Open​
VCIM​
DTC B2483 or B2484​
B2530​
Front Fog Lamps Control Circuit​
BCM​
DTC B2530​
B2555​
Passenger Compartment Lamp Control Circuit​
BCM​
DTC B2555​
B2580​
Headlamp High Beam Control Circuit​
BCM​
DTC B2580​
B2625​
Display Dimming Pulse Width Modulation (PWM) Output Circuit​
BCM​
DTC B2625​
B2645​
Ambient Light Sensor Circuit​
BCM​
DTC B2645​
B2705​
Gearshift Unlock Circuit​
BCM​
DTC B2705​
B2750​
Horn Relay Coil Circuit​
BCM​
DTC B2750​
B3031​
Security System Controller In Learn Mode​
VTD​
DTC B3031​
B3055​
No Transponder Modulation or No Transponder​
VTD​
DTC B3055​
B3060​
Unprogrammed Transponder Identification Code Received​
VTD​
DTC B3060​
B3105​
Keyless Entry System Key Fobs Not Programmed​
RCDLR​
DTC B3105​
B3109​
Keyless Entry Transmitter 1 Low Battery​
RCDLR​
DTC B3109, B3110, B3111, or B3112​
B3110​
Keyless Entry Transmitter 2 Low Battery​
RCDLR​
B3111​
Keyless Entry Transmitter 3 Low Battery​
RCDLR​
B3112​
Keyless Entry Transmitter 4 Low Battery​
RCDLR​
B3265​
Trunk Relay Output​
BCM​
DTC B3265​
B3715​
Front Wiper Relay Drive Circuit​
BCM​
DTC B3715​
B3794​
Cruise Control Function Request Circuit​
BCM​
DTC B3794​
B3903​
Stop Lamp Relay Circuit​
BCM​
DTC B3903​
B3935​
Transponder Authentication Error​
VTD​
DTC B3935​
B3948​
Left Front Turn Signal Circuit​
BCM​
DTC B3948 or B3949​
B3949​
Right Front Turn Signal Circuit​
BCM​
DTC B3948 or B3949​
B3950​
Left Rear Turn Signal Circuit​
BCM​
DTC B3950 or B3951​
B3951​
Right Rear Turn Signal Circuit​
BCM​
DTC B3950 or B3951​
B3976​
Unconfigured Transponder​
VTD​
DTC B3976​
C0035​
Left Front Wheel Speed Sensor Circuit​
EBCM​
DTC C0035-C0050​
C0040​
Right Front Wheel Speed Sensor Circuit​
EBCM​
DTC C0035-C0050​
C0045​
Left Rear Wheel Speed Sensor Circuit​
EBCM​
DTC C0035-C0050​
C0050​
Right Rear Wheel Speed Sensor Circuit​
EBCM​
DTC C0035-C0050​
C0110​
Pump Motor Circuit​
EBCM​
DTC C0110​
C0131​
Antilock Brake System (ABS) Pressure Circuit​
EBCM​
DTC C0131​
C0161​
Antilock Brake System (ABS)/Traction Control System (TCS) Brake Switch Circuit Signal Malfunction​
EBCM​
DTC C0161​
C0186​
Lateral Accelerometer Circuit​
EBCM​
DTC C0186​
C0196​
Yaw Rate Circuit​
EBCM​
DTC C0196​
C0201​
Antilock Brake System (ABS) Enable Relay Contact Circuit​
EBCM​
DTC C0201​
C0252​
Vehicle Stability Enhancement System (VSES) Sensors Uncorrelated​
EBCM​
DTC C0252​
C0267​
Low Brake Fluid Indicated​
EBCM​
DTC C0267​
C0277​
Brake Pedal Position Sensor Circuit​
BCM​
DTC C0277​
C0278​
Brake Pedal Position Sensor Not Calibrated​
BCM​
DTC C0278​
C0292​
VSES Combination Sensor Circuits​
EBCM​
DTC C0292​
C0460​
Steering Position Sensor​
EBCM​
DTC C0460​
C0550​
EBCM​
DTC C0550 or DTC C0550​
C0551​
EBCM​
DTC C0551​
C0561​
System Disabled Information Stored​
EBCM​
DTC C0561​
C0569​
EBCM​
DTC C0569​
C0870​
Device Voltage Reference Output 1​
BCM​
DTC C0870​
C0899​
Device Voltage Low​
EBCM​
DTC C0899​
C0900​
Device Voltage High​
EBCM​
DTC C0900 DTC P0010 or P0011 for the 2.0L engine​
P0010​
Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit​
ECM​
or DTC P0010 or P0013 for the 2.4L engine DTC P0010 or P0011 for the 2.0L engine​
P0011​
Intake Camshaft Position (CMP) System Performance​
ECM​
or DTC P0011 or P0014 for the 2.4L engine DTC P0013 or P0014 for the 2.0L engine​
P0013​
Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit​
ECM​
or DTC P0010 or P0013 for the 2.4L engine DTC P0013 or P0014 for the 2.0L engine​
P0014​
Exhaust Camshaft Position (CMP) System Performance​
ECM​
or DTC P0011 or P0014 for the 2.4L engine DTC P0016 or P0017 for the 2.0L engine​
P0016​
Camshaft Position (CMP)​
ECM​
or DTC P0016 or P0017 for the 2.4L engine DTC P0016 or P0017 for the 2.0L engine​
P0017​
Exhaust Camshaft Position (CMP)​
ECM​
or DTC P0016 or P0017 for the 2.4L engine DTC P0030, P0031, P0032, P0053, or P0135 for the 2.0L​
P0030​
ECM​
engine or DTC P0030, P0036, P0053, P0054, P0135, or P0141 for the 2.4L engine DTC P0030, P0031, P0032,​
P0031​
HO2S Heater Control Circuit Low​
ECM​
P0053, or P0135 for the 2.0L engine DTC P0030, P0031, P0032,​
P0032​
Voltage Sensor 1 HO2S Heater Control Circuit High​
ECM​
P0053, or P0135 for the 2.0L engine​
P0033​
Voltage Sensor 1 Turbocharger Bypass Valve Solenoid Control Circuit​
ECM​
DTC P0033, P0034, or P0035 for the 2.0L engine DTC P0033, P0034, or P0035​
P0034​
Turbocharger Bypass Valve Solenoid Control Circuit Low​
ECM​
P0035​
Voltage Turbocharger Bypass Valve Solenoid Control Circuit High​
ECM​
for the 2.0L engine DTC P0036, P0037, P0038, or P0141 for the 2.0L engine or​
P0036​
Voltage Sensor 2​
ECM​
DTC P0030, P0036, P0053, P0054, P0135, or P0141 for the 2.4L engine​
P0037​
HO2S Heater Control Circuit Low Voltage Sensor 2​
ECM​
DTC P0036, P0037, P0038, or P0141 for the 2.0L engine​
P0038​
HO2S Heater Control Circuit High Voltage Sensor 2​
ECM​
DTC P0036, P0037, P0038, or P0141 for the 2.0L engine DTC P0030, P0031, P0032, P0053, or P0135 for the 2.0L engine​
P0053​
HO2S Heater Resistance Sensor 1​
ECM​
or DTC P0030, P0036, P0053, P0054, P0135, or P0141 for the 2.4L engine​
P0054​
HO2S Heater Resistance Sensor 2​
ECM​
P0068​
Throttle Body Airflow Performance​
ECM​
DTC P0068 or P0121 for the 2.4L engine​
P0087​
Fuel Rail Pressure (FRP) Too Low​
ECM​
DTC P0087, P0088, or P0089 for the 2.0L engine​
P0088​
Fuel Rail Pressure (FRP) Too High​
ECM​
P0089​
Fuel Pressure Regulator Performance​
ECM​
P0090​
Fuel Pressure Regulator Control Circuit​
ECM​
DTC P0090, P0091, or P0092 for the 2.0L engine​
P0091​
Fuel Pressure Regulator Solenoid 1 Control Circuit Low Voltage​
ECM​
P0092​
Fuel Pressure Regulator Solenoid 1 Control Circuit High Voltage​
ECM​
P0096​
Intake Air Temperature (IAT) Sensor 2 Performance​
ECM​
DTC P0096, P0097, P0098, or P0099 for the 2.0L engine​
P0097​
Intake Air Temperature (IAT) Sensor 2 Circuit Low Voltage​
ECM​
P0098​
Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage​
ECM​
P0099​
Intake Air Temperature (IAT) Sensor 2 Circuit Intermittent​
ECM​
P0100​
Mass Air Flow (MAF) Sensor Circuit​
ECM​
DTC P0100, P0102, or P0103 for the 2.0L engine DTC P0101 for the 2.0L engine​
P0101​
Mass Air Flow (MAF) Sensor Performance​
ECM​
or DTC P0101 or P1101 for the 2.4L engine DTC P0100, P0102, or P0103 for the 2.0L engine​
P0102​
Mass Air Flow (MAF) Sensor Circuit Low Frequency​
ECM​
or DTC P0102 or P0103 for the 2.4L engine DTC P0100, P0102, or P0103 for the 2.0L engine​
P0103​
Mass Air Flow (MAF) Sensor Circuit High Frequency​
ECM​
or DTC P0102 or P0103 for the 2.4L engine DTC P0106 for the 2.0L engine​
P0106​
Manifold Absolute Pressure (MAP) Sensor Performance​
ECM​
or DTC P0106 for the 2.4L engine DTC P0107 or P0108 for the 2.0L engine​
P0107​
Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage​
ECM​
or DTC P0107 or P0108 for the 2.4L engine​
P0108​
Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage​
ECM​
DTC P0107 or P0108 for the 2.0L engine or DTC P0107 or P0108 for the 2.4L engine DTC P0112, P0113, or P0114 for the 2.0L engine​
P0112​
Intake Air Temperature (IAT) Sensor Circuit Low Voltage​
ECM​
or DTC P0112 or P0113 for the 2.4L engine DTC P0112, P0113, or P0114 for the 2.0L engine​
P0113​
Intake Air Temperature (IAT) Sensor Circuit High Voltage​
ECM​
or DTC P0112 or P0113 for the 2.4L engine​
P0114​
Intake Air Temperature (IAT) Sensor Circuit Intermittent​
ECM​
P0115​
Engine Coolant Temperature (ECT) Sensor Circuit​
TCM​
DTC P0115, P0120, P0826, P2544, or P2637 DTC P0116 for the 2.0L engine​
P0116​
Engine Coolant Temperature (ECT) Sensor Performance​
ECM​
or DTC P0116 for the 2.4L engine DTC P0117, P0118, or P0119 for the 2.0L engine​
P0117​
Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage​
ECM​
or DTC P0117 or P0118 for the 2.4L engine DTC P0117, P0118, or P0119 for the 2.0L engine​
P0118​
Engine Coolant Temperature (ECT) Sensor Circuit High Voltage​
ECM​
or DTC P0117 or P0118 for the 2.4L engine​
P0119​
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent​
ECM​
DTC P0117, P0118, or P0119 for the 2.0L engine DTC P0115, P0120, P0826, P2544, or P2637​
P0120​
Throttle Position (TP) Sensor 1 Circuit​
ECM​
DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135 for the 2.4L engine DTC P0121, P0122, or P0123 for the 2.0L engine​
P0121​
Throttle Position (TP) Sensor Performance​
ECM​
or DTC P0068 or P0121 for the 2.4L engine​
P0122​
Throttle Position (TP) Sensor 1 Circuit Low Voltage​
ECM​
DTC P0121, P0122, or P0123 for the 2.0L engine or DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135 for the 2.4L engine DTC P0121, P0122, or P0123 for the 2.0L engine or​
P0123​
ECM​
DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135 for the 2.4L engine DTC P0128 for the 2.0L engine​
P0128​
(ECT) Below Thermostat​
ECM​
or DTC P0128 for the 2.4L engine DTC P0130-P0133, P2195,​
P0130​
HO2S Circuit Closed Loop (CL)​
ECM​
P2196, or 2297 for the 2.0L engine DTC P0130-P0133, P2195, P2196, or 2297 for the 2.0L engine​
P0131​
Performance Sensor 1​
ECM​
or DTC P0131, P0132, P0137, or P0138 for the 2.4L engine DTC P0130-P0133, P2195, P2196, or 2297 for the 2.0L engine​
P0132​
ECM​
P0133​
HO2S Slow Response Sensor 1​
ECM​
or DTC P0133, P0134, P0140, P1133, P2A00, or P2A01 for the 2.4L engine​
P0134​
HO2S Circuit Insufficient Activity Sensor 1​
ECM​
DTC P0133, P0134, P0140, P1133, P2A00, or P2A01 for the 2.4L engine DTC P0030, P0031, P0032, P0053, or P0135 for the 2.0L engine​
P0135​
ECM​
or DTC P0030, P0036, P0053, P0054, P0135, or P0141 for the 2.4L engine DTC P0137, P0138, P013A, P013E, P0140, P2232, P2270, or P2271 for the 2.0L​
P0137​
HO2S Circuit Low Voltage Sensor​
ECM​
engine or DTC P0131, P0132, P0137, or P0138 for the 2.4L engine DTC P0137, P0138, P013A, P013E, P0140, P2232, P2270, or P2271 for the 2.0L​
P0138​
HO2S Circuit High Voltage Sensor​
ECM​
engine or DTC P0131, P0132, P0137, or P0138 for the 2.4L engine​
P013A​
HO2S Slow Response Rich to Lean Sensor 2​
ECM​
DTC P0137, P0138, P013A, P013E, P0140, P2232, P2270, or P2271 for the 2.0L engine​
P013E​
HO2S Delayed Response Rich to Lean Sensor 2​
ECM​
DTC P0137, P0138, P013A, P013E, P0140, P2232, P2270, or P2271 for the 2.0L engine DTC P0137, P0138, P013A, P013E, P0140, P2232, P2270, or P2271 for the 2.0L engine​
P0140​
Sensor 2​
ECM​
or DTC P0133, P0134, P0140, P1133, P2A00, or P2A01 for the 2.4L engine DTC P0036, P0037, P0038, or P0141 for the 2.0L engine or​
P0141​
2​
ECM​
P0171​
Fuel Trim System Lean​
ECM​
DTC P0171 or P0172 for the 2.4L engine​
P0172​
Fuel Trim System Rich​
ECM​
P0191​
Fuel Rail Pressure (FRP) Sensor Performance​
ECM​
DTC P0191, P0192, or P0193 for the 2.0L engine​
P0192​
Fuel Rail Pressure (FRP) Sensor Circuit Low Voltage​
ECM​
P0193​
Fuel Rail Pressure (FRP) Sensor Circuit High Voltage​
ECM​
DTC P0191, P0192, or P0193 for the 2.0L engine DTC P0201-P0204, P0261, P0262, P0264, P0265, P0267, P0268, P0270, P0271, P2146, P2149,​
P0201​
Injector 1 Control Circuit​
ECM​
P2152, or P2155 for the 2.0L engine or DTC P0201, P0202, P0203, or P0204 for the 2.4L engine DTC P0201-P0204, P0261, P0262, P0264, P0265, P0267, P0268, P0270, P0271, P2146, P2149,​
P0202​
Injector 2 Control Circuit​
ECM​
P0203​
Injector 3 Control Circuit​
ECM​
P0204​
Injector 4 Control Circuit​
ECM​
P2152, or P2155 for the 2.0L engine or DTC P0201, P0202, P0203, or P0204 for the 2.4L engine​
P0218​
Transmission Fluid Overtemperature​
TCM​
DTC P0218​
P0220​
Throttle Position (TP) Sensor 2 Circuit​
ECM​
DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135 for the 2.4L engine​
P0221​
Throttle Position (TP) Sensor 2 Performance​
ECM​
DTC P0221, P0222, or P0223 for the 2.0L engine DTC P0221, P0222, or P0223​
P0222​
Throttle Position (TP) Sensor 2​
ECM​
for the 2.0L engine or DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135 for the 2.4L engine DTC P0221, P0222, or P0223 for the 2.0L engine or​
P0223​
Circuit Low Voltage Circuit High Voltage​
ECM​
P0230​
Fuel Pump Relay Control Circuit​
ECM​
DTC P0230 for the 2.4L engine​
P0234​
Turbocharger Engine Overboost​
ECM​
DTC P0234 or P0299 for the 2.0L engine​
P0236​
Turbocharger Boost System Performance​
ECM​
DTC P0236, P0237, or P0238 for the 2.0L engine​
P0237​
Turbocharger Boost Sensor Circuit Low Voltage​
ECM​
P0238​
Turbocharger Boost Sensor Circuit High Voltage​
ECM​
P0243​
Turbocharger Wastegate Solenoid Control Circuit​
ECM​
DTC P0243, P0245, or P0246 for the 2.0L engine​
P0245​
Turbocharger Wastegate Solenoid Control Circuit Low Voltage​
ECM​
P0246​
Turbocharger Wastegate Solenoid Control Circuit High Voltage​
ECM​
DTC P0243, P0245, or P0246 for the 2.0L engine DTC P0201-P0204, P0261, P0262, P0264, P0265, P0267, P0268, P0270,​
P0261​
Voltage​
ECM​
P0271, P2146, P2149, P2152, or P2155 for the 2.0L engine DTC P0201-P0204, P0261, P0262, P0264, P0265, P0267, P0268, P0270,​
P0262​
Voltage​
ECM​
P0264​
Voltage​
ECM​
P0271, P2146, P2149, P2152, or P2155 for the 2.0L engine​
P0265​
Injector 2 Control Circuit High Voltage​
ECM​
DTC P0201-P0204, P0261, P0262, P0264, P0265, P0267, P0268, P0270, P0271, P2146, P2149, P2152, or P2155 for the 2.0L engine DTC P0201-P0204, P0261, P0262, P0264, P0265, P0267, P0268, P0270,​
P0267​
Voltage​
ECM​
P0268​
Voltage​
ECM​
P0270​
Voltage​
ECM​
P0271​
Voltage​
ECM​
P0299​
Turbocharger Engine Underboost​
ECM​
DTC P0234 or P0299 for the 2.0L engine DTC P0300-P0304 for the 2.0L engine​
P0300​
Engine Misfire Detected​
ECM​
or DTC P0300-P0304 for the 2.4L engine DTC P0300-P0304 for the 2.0L engine​
P0301​
Cylinder 1 Misfire Detected​
ECM​
P0302​
Cylinder 2 Misfire Detected​
ECM​
or DTC P0300-P0304 for the 2.4L engine​
P0303​
Cylinder 3 Misfire Detected​
ECM​
DTC P0300-P0304 for the 2.0L engine or DTC P0300-P0304 for the 2.4L engine DTC P0300-P0304 for the 2.0L engine​
P0304​
Cylinder 4 Misfire Detected​
ECM​
P0315​
Crankshaft Position (CKP) System Variation Not Learned​
ECM​
DTC P0315 for the 2.4L engine​
P0324​
Knock Sensor (KS) Module Performance​
ECM​
DTC P0324, P0326, P0327, P0328, P0331, P0332, or P0333 for the 2.0L engine​
P0325​
Knock Sensor (KS) Circuit​
ECM​
DTC P0325, P0326, P0327, or P0328 for the 2.4L engine​
P0326​
Knock Sensor (KS) 1 Performance​
ECM​
DTC P0324, P0326, P0327, P0328, P0331, P0332, or P0333 for the 2.0L engine DTC P0325, P0326, P0327, or P0328 for the 2.4L engine​
P0327​
Knock Sensor (KS) 1 Circuit Low Voltage​
ECM​
P0328​
Knock Sensor (KS) 1 Circuit High Voltage​
ECM​
P0331​
Knock Sensor (KS) 2 Performance​
ECM​
P0332​
Knock Sensor (KS) 2 Circuit Low Voltage​
ECM​
P0333​
Knock Sensor (KS) 2 Circuit High Voltage​
ECM​
DTC P0324, P0326, P0327, P0328, P0331, P0332, or P0333 for the 2.0L engine DTC P0335, P0336, or P0338for the 2.0L engine or DTC P0335 or P0336 for the 2.4L engine DTC P0335, P0336, or P0338 for the 2.0L engine​
P0336​
Crankshaft Position (CKP) Sensor Performance​
ECM​
or DTC P0335 or P0336 for the 2.4L engine​
P0338​
Crankshaft Position (CKP) Sensor Circuit High Duty Cycle​
ECM​
P0340​
Intake Camshaft Position (CMP) Sensor Circuit​
ECM​
DTC P0340 or P0365 for the 2.4L engine DTC P0341, P0342, or P0343 for the 2.0L engine​
P0341​
Intake Camshaft Position (CMP) Sensor Performance​
ECM​
or DTC P0341 or P0366 for the 2.4L engine​
P0342​
Intake Camshaft Position (CMP) Sensor Circuit low voltage​
ECM​
P0343​
ECM​
P0351​
Ignition Coil 1 Control Circuit​
ECM​
DTC P0351-P0354 for the 2.4L engine​
P0352​
Ignition Coil 2 Control Circuit​
ECM​
P0353​
Ignition Coil 3 Control Circuit​
ECM​
P0354​
Ignition Coil 4 Control Circuit​
ECM​
P0365​
Exhaust Camshaft Position (CMP) Sensor Circuit​
ECM​
DTC P0340 or P0365 for the 2.4L engine DTC P0366, P0367, or P0368 for the 2.0L engine​
P0366​
Exhaust Camshaft Position (CMP) Sensor Performance​
ECM​
P0367​
Exhaust Camshaft Position (CMP) Sensor Circuit Low Voltage​
ECM​
P0368​
Exhaust Camshaft Position (CMP) Sensor Circuit High Voltage​
ECM​
DTC P0366, P0367, or P0368 for the 2.0L engine DTC P0420 for the 2.0L engine​
P0420​
Catalyst System Low Efficiency​
ECM​
or DTC P0420 for the 2.4L engine​
P0442​
Evaporative Emissions (EVAP) System Small Leak Detected​
ECM​
DTC P0442 for the 2.0L engine or DTC P0442 for the 2.4L engine DTC P0443, P0449, P0458, P0459, P0498, or P0499 for the 2.0L engine​
P0443​
Purge Solenoid Control Circuit​
ECM​
or DTC P0443 or P0449 for the 2.4L engine DTC P0446 for the 2.0L engine​
P0446​
Evaporative Emissions (EVAP) Vent System Performance​
ECM​
or DTC P0446 for the 2.4L engine DTC P0443, P0449, P0458, P0459, P0498, or P0499 for the 2.0L engine​
P0449​
ECM​
or DTC P0443 or P0449 for the 2.4L engine DTC P0451, P0452, or P0453 for the 2.0L engine​
P0451​
Fuel Tank Pressure (FTP) Sensor Performance​
ECM​
or DTC P0451, P0452, P0453, or P0454 for the 2.4L engine DTC P0451, P0452, or P0453 for the 2.0L engine​
P0452​
Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage​
ECM​
P0453​
Fuel Tank Pressure (FTP) Sensor Circuit High Voltage​
ECM​
or DTC P0451, P0452, P0453, or P0454 for the 2.4L engine​
P0454​
Fuel Tank Pressure (FTP) Sensor Intermittent​
ECM​
DTC P0451, P0452, P0453, or P0454 for the 2.4L engine DTC P0455 for the 2.0L engine​
P0455​
Evaporative Emission (EVAP) System Large Leak​
ECM​
or DTC P0455 for the 2.4L engine​
P0458​
Evaporative Emission (EVAP) Purge Solenoid Control Circuit Low Voltage​
ECM​
P0459​
Evaporative Emission (EVAP) Purge Solenoid Control Circuit High Voltage​
ECM​
P0461​
Fuel Level Sensor Circuit Performance​
ECM​
DTC P0461​
P0462​
Fuel Level Sensor Circuit Low Voltage​
ECM​
DTC P0462​
P0463​
Fuel Level Sensor Circuit High Voltage​
ECM​
DTC P0463 DTC P0480, P0691, or P0692 (2.0) for the 2.0L engine​
P0480​
Cooling Fan Relay 1 Control​
ECM​
or DTC P0480 or P0481 (2.4) for the 2.4L engine​
P0481​
Cooling Fan Relay 2 Control Circuit​
ECM​
DTC P0480 or P0481 (2.4) for the 2.4L engine DTC P0496 for the 2.0L engine​
P0496​
Evaporative Emission System Flow During Non-Purge​
ECM​
or DTC P0496 for the 2.4L engine​
P0498​
Evaporative Emission (EVAP) Vent Solenoid Control Circuit Low Voltage​
ECM​
P0499​
Evaporative Emission (EVAP) Vent Solenoid Control Circuit High Voltage​
ECM​
P0502​
Vehicle Speed Sensor (VSS) Circuit Low Voltage​
ECM​
DTC P0502 or P0503​
P0503​
Vehicle Speed Sensor (VSS) Circuit Intermittent​
ECM​
DTC P0502 or P0503 DTC P0506 or P0507 for the 2.0L engine​
P0506​
Idle Speed Low​
ECM​
or DTC P0506 or P0507 for the 2.4L engine DTC P0506 or P0507 for the 2.0L engine​
P0507​
Idle Speed High​
ECM​
or DTC P0506 or P0507 for the 2.4L engine​
P050A​
Cold Start Idle Air Control System Performance​
ECM​
DTC P050A for the 2.0L engine​
P0520​
Engine Oil Pressure (EOP) Sensor Circuit​
ECM​
DTC P0520​
P0532​
Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage​
ECM​
DTC P0532 or P0533​
P0533​
Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage​
ECM​
DTC P0532 or P0533​
P0556​
Brake Booster Pressure Sensor Performance​
ECM​
DTC P0556​
P0557​
Brake Booster Pressure Sensor Circuit Low Voltage​
ECM​
DTC P0557​
P0558​
Brake Booster Pressure Sensor Circuit High Voltage​
ECM​
DTC P0558​
P0560​
System Voltage​
ECM​
DTC P0560 DTC P0562​
P0562​
System Voltage Low​
TCM​
DTC P0562 or P0563 DTC P0563​
P0563​
System Voltage High​
TCM​
DTC P0562 or P0563​
P0571​
Cruise Control Brake Switch Circuit​
ECM​
DTC P0571​
P0575​
Cruise Control Switch Signal Circuit​
ECM​
DTC P0575 DTC P0601-P0606, P062B, P167A, P167D, P2105, or P2610 for the 2.0L engine or DTC P0601, P0602, P0603,​
P0601​
P0604, P0606, P0607, P060D, P062F, or P2610 for the 2.4L engine DTC P0601, P0602, P0603, P0604, or P062F DTC P0601-P0606, P062B, P167A, P167D, P2105, or P2610 for the 2.0L engine or DTC P0601, P0602, P0603,​
P0602​
Control Module Not Programmed​
P0604, P0606, P0607, P060D, P062F, or P2610 for the 2.4L engine DTC P0601, P0602, P0603, P0604, or P062F​
P0603​
Control Module Long Term Memory Reset​
ECM​
DTC P0601-P0606, P062B, P167A, P167D, P2105, or P2610 for the 2.0L engine or DTC P0601, P0602, P0603, P0604, P0606, P0607, P060D, P062F, or P2610 for the 2.4L engine DTC P0601, P0602, P0603, P0604, or P062F DTC P0601-P0606, P062B, P167A, P167D, P2105, or P2610 for the 2.0L engine or DTC P0601, P0602, P0603,​
P0604​
P0604, P0606, P0607, P060D, P062F, or P2610 for the 2.4L engine DTC P0601, P0602, P0603, P0604, or P062F DTC P0601-P0606, P062B, P167A, P167D, P2105, or P2610 for the 2.0L engine​
P0606​
Control Module Internal Performance​
ECM​
or DTC P0601, P0602, P0603, P0604, P0606, P0607, P060D, P062F, or P2610 DTC P0601, P0602, P0603, P0604, P0606, P0607,​
P0607​
Control Module Performance​
ECM​
P060D, P062F, or P2610 for the 2.4L engine DTC P0601, P0602, P0603,​
P060D​
Control Module Accelerator Pedal Position (APP) System​
ECM​
P0604, P0606, P0607, P060D, P062F, or P2610 for the 2.4L engine​
P0615​
Starter Relay Control Circuit​
ECM​
DTC P0615​
P0616​
Starter Relay Control Circuit Low Voltage​
ECM​
DTC P0616​
P0617​
Starter Relay Control Circuit High Voltage​
ECM​
DTC P0617​
P0621​
Generator L-Terminal Circuit​
ECM​
DTC P0621​
P0622​
Generator F-Terminal Circuit​
ECM​
DTC P0622​
P0626​
Generator F-Terminal Circuit High Voltage​
ECM​
DTC P0626​
P0627​
ECM​
DTC P0627, P0628, or P0629 for the 2.0L engine​
P0628​
Fuel Pump Relay Control Circuit Low Voltage​
ECM​
P0629​
Fuel Pump Relay Control Circuit High Voltage​
ECM​
P062B​
Control Module Fuel Injector Control Performance​
ECM​
P062F​
Control Module Long Term Memory Performance​
ECM​
DTC P0601, P0602, P0603, P0604, P0606, P0607, P060D, P062F, or P2610 for the 2.4L engine DTC P0601, P0602, P0603, P0604, or P062F DTC P0638, P1551, P2100,​
P0638​
Throttle Actuator Control (TAC)​
ECM​
P2101, P2119, or P2176 for the 2.0L engine DTC P0641, P0642, P0643, P0651, P0652, P0653, P0697, P0698 or P0699 for​
P0641​
Command Performance 5-Volt Reference 1 Circuit​
ECM​
the 2.0L engine or DTC P0641 or P0651 for the 2.4L engine DTC P0641, P0642, P0643, P0651, P0652, P0653,​
P0642​
5-Volt Reference 1 Low Voltage​
ECM​
P0697, P0698 or P0699 for the 2.0L engine DTC P0641, P0642, P0643, P0651, P0652, P0653,​
P0643​
5-Volt Reference 1 High Voltage​
ECM​
P0697, P0698 or P0699 for the 2.0L engine​
P0645​
Air Conditioning (A/C) Clutch Relay Control Circuit​
ECM​
DTC P0645 DTC P0650 for the 2.0L engine​
P0650​
Malfunction Indicator Lamp (MIL) Control Circuit​
ECM​
or DTC P0650 for the 2.4L engine​
P0651​
5-Volt Reference 2 Circuit​
ECM​
DTC P0641, P0642, P0643, P0651, P0652, P0653,P0697, P0698 or P0699 for the 2.0L engine or DTC P0641 or P0651 for the 2.4L engine DTC P0641, P0642, P0643, P0651, P0652, P0653,​
P0652​
5-Volt Reference 2 Low Voltage​
ECM​
P0653​
5-Volt Reference 2 High Voltage​
ECM​
P0697, P0698 or P0699 for the 2.0L engine DTC P0685, P0686, P0687, P0689, or P0690 for the 2.0L engine​
P0685​
Control Circuit​
ECM​
or DTC P0685, P0689, or P0690 for the 2.4L engine DTC P0685, P0686, P0687,​
P0686​
Engine Controls Ignition Relay​
ECM​
P0689, or P0690 for the 2.0L engine DTC P0685, P0686, P0687,​
P0687​
Control Circuit Low Voltage Engine Controls Ignition Relay​
ECM​
P0689, or P0690 for the 2.0L engine DTC P0685, P0686, P0687, P0689, or P0690 for the 2.0L engine​
P0689​
Control Circuit High Voltage Feedback Circuit Low Voltage​
ECM​
or DTC P0685, P0689, or P0690 for the 2.4L engine DTC P0685, P0686, P0687, P0689, or P0690 for the 2.0L engine​
P0690​
Feedback Circuit High Voltage​
ECM​
or DTC P0685, P0689, or P0690 for the 2.4L engine​
P0691​
Cooling Fan Speed Output Circuit Low Voltage​
ECM​
DTC P0480, P0691, or P0692 (2.0)​
P0692​
Cooling Fan Speed Output Circuit High Voltage​
ECM​
DTC P0480, P0691, or P0692 (2.0) DTC P0641, P0642, P0643, P0651, P0652, P0653,​
P0697​
5-Volt Reference 3 Circuit​
ECM​
P0698​
5-Volt Reference 3 Low Voltage​
ECM​
DTC P0641, P0642, P0643, P0651, P0652, P0653,P0697, P0698 or P0699 for the 2.0L engine DTC P0641, P0642, P0643, P0651, P0652, P0653,​
P0699​
5-Volt Reference 3 High Voltage​
ECM​
P0697, P0698 or P0699 for the 2.0L engine DTC P0700 for the 2.0L engine​
P0700​
Transmission Control Module (TCM) Requested MIL Illumination​
ECM​
or DTC P0700 for the 2.4L engine​
P0703​
Brake Switch Circuit 2​
ECM​
DTC P0703​
P0711​
Transmission Fluid Temperature (TFT) Sensor Performance​
TCM​
DTC P0711​
P0712​
Transmission Fluid Temperature (TFT) Sensor Circuit Low Voltage​
TCM​
DTC P0712 or P0713​
P0713​
Transmission Fluid Temperature (TFT) Sensor Circuit High Voltage​
TCM​
DTC P0712 or P0713​
P0716​
Input Speed Sensor Performance​
TCM​
DTC P0716 or P0717​
P0717​
Input Speed Sensor Circuit Low Voltage​
TCM​
DTC P0716 or P0717​
P0722​
Output Speed Sensor Circuit Low Voltage​
TCM​
DTC P0722 or P0723​
P0723​
Output Speed Sensor Circuit Intermittent​
TCM​
DTC P0722 or P0723​
P0741​
Torque Converter Clutch (TCC) System - Stuck Off​
TCM​
DTC P0741, P0751, P0756, or P0761​
P0742​
Torque Converter Clutch (TCC) System - Stuck On​
TCM​
DTC P0742, P0752, P0757, or P0762​
P0748​
Pressure Control (PC) Solenoid Control Circuit​
TCM​
DTC P0748​
P0751​
1-2 Shift Solenoid (SS) Valve Performance - No First, Fourth or Fifth Gear​
TCM​
P0752​
1-2 Shift Solenoid (SS) Valve Performance - No Second or Third Gear​
TCM​
P0756​
2-3 Shift Solenoid (SS) Valve Performance - No First or Second Gear​
TCM​
P0757​
2-3 Shift Solenoid (SS) Valve Performance - No Third, Fourth or Fifth Gear​
TCM​
P0761​
4-5 Shift Solenoid (SS) Valve Performance - No Fourth Gear​
TCM​
P0762​
4-5 Shift Solenoid (SS) Valve Performance - No Fifth Gear​
TCM​
P0806​
Clutch Pedal Position (CPP) Sensor Circuit Performance​
ECM​
DTC P0806​
P0807​
Clutch Pedal Position (CPP) Sensor Circuit Low Voltage​
ECM​
DTC P0807 or P0808​
P0808​
Clutch Pedal Position (CPP) Sensor Circuit High Voltage​
ECM​
DTC P0807 or P0808​
P080A​
Clutch Pedal Position (CPP) Not Learned​
ECM​
DTC P080A​
P0815​
Upshift Switch Circuit​
ECM​
DTC P0815 or P816​
P0816​
Downshift Switch Circuit​
ECM​
DTC P0815 or P816​
P0826​
Up and Down Shift Switch Circuit​
TCM​
P0850​
Park/Neutral Position (PNP) Switch Circuit​
TCM​
DTC P0850​
P0897​
Transmission Fluid Life​
ECM​
DTC P0897​
P0973​
1-2 Shift Solenoid (SS) Control Circuit Low Voltage​
TCM​
DTC P0973, P0976, P0979, or P2764​
P0974​
1-2 Shift Solenoid (SS) Control Circuit High Voltage​
TCM​
DTC P0974, P0977, P0980, or P2763​
P0976​
2-3 Shift Solenoid (SS) Control Circuit Low Voltage​
TCM​
P0977​
2-3 Shift Solenoid (SS) Control Circuit High Voltage​
TCM​
P0979​
4-5 Shift Solenoid (SS) Control Circuit Low Voltage​
TCM​
P0980​
4-5 Shift Solenoid (SS) Control Circuit High Voltage​
TCM​
P1101​
Intake Air Flow System Performance​
ECM​
DTC P0101 or P1101 for the 2.4L engine​
P1133​
HO2S Insufficient Switching Sensor 1​
ECM​
P1174​
Fuel Trim Cylinder Balance​
ECM​
DTC P1174​
P1400​
Cold Start Emission Reduction Control System​
ECM​
DTC P1400​
P1516​
Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance​
ECM​
DTC P1516, P2101, P2119, or P2176 DTC P0638, P1551, P2100,​
P1551​
Throttle Valve Rest Position Not​
ECM​
P2101, P2119, or P2176 for the 2.0L engine​
P1631​
Reached During Learn Theft Deterrent Fuel Enable Signal Not Correct​
ECM​
DTC P1631​
P167A​
Control Module HO2S 1 System Performance​
ECM​
P167D​
Control Module Ignition Coil Internal Circuit​
ECM​
P1682​
Ignition 1 Switch Circuit 2​
ECM​
DTC P1682​
P1820​
Internal Mode Switch A Circuit Low Voltage​
TCM​
DTC P1820, P1822, P1823, P1825, P1826, or P1915​
P1822​
Internal Mode Switch B Circuit High Voltage​
TCM​
P1823​
Internal Mode Switch P Circuit Low Voltage​
TCM​
P1825​
Internal Mode Switch - Invalid Range​
TCM​
P1826​
Internal Mode Switch C Circuit High Voltage​
TCM​
P1831​
Pressure Control (PC)/Shift Lock Solenoid Control Circuit Low Voltage​
TCM​
DTC P1831 or P1832​
P1832​
Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage​
TCM​
DTC P1831 or P1832​
P1833​
Torque Converter Clutch (TCC)/Shift Solenoid (SS) Control Circuit Low Voltage​
TCM​
DTC P1833 or P1834​
P1834​
Torque Converter Clutch (TCC)/Shift Solenoid (SS) Control Circuit High Voltage​
TCM​
DTC P1833 or P1834​
P1915​
Internal Mode Switch Does Not Indicate Park/Neutral (P/N) During Start​
TCM​
P2088​
Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage​
ECM​
DTC P2088 or P2089 for the 2.0L engine​
P2089​
Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit High Voltage​
ECM​
P2090​
Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage​
ECM​
DTC P2090 or P2091 for the 2.0L engine​
P2091​
Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit High Voltage​
ECM​
P2096​
Post Catalyst Fuel Trim System Low Limit Bank 1​
ECM​
DTC P2096, P2177, or P2187 for the 2.0L engine​
P2097​
Post Catalyst Fuel Trim System High Limit Bank 1​
ECM​
DTC P2097, P2178, or P2188 for the 2.0L engine DTC P0638, P1551, P2100,​
P2100​
ECM​
P2101, P2119, or P2176 for the 2.0L engine DTC P0638, P1551, P2100, P2101, P2119, or P2176 for the 2.0L engine​
P2101​
Motor Control Circuit Position Performance​
ECM​
or DTC P1516, P2101, P2119, or P2176 for the 2.4L engine.​
P2105​
Throttle Actuator Control (TAC) System - Forced Engine Shut- down​
ECM​
DTC P0601-P0606, P062B, P167A, P167D, P2105, or P2610 for the 2.0L engine DTC P0638, P1551, P2100, P2101, P2119, or P2176 for the 2.0L engine​
P2119​
Performance​
ECM​
or DTC P1516, P2101, P2119, or P2176 for the 2.4L engine​
P2120​
Accelerator Pedal Position (APP) Sensor 1 Circuit​
ECM​
DTC P2120, P2122, P2123, P2125, P2127, P2128, or P2138 for the 2.4L engine DTC P2122 or P2123 for the 2.0L engine or​
P2122​
ECM​
P2123​
Sensor 1 Circuit High Voltage​
ECM​
DTC P2120, P2122, P2123, P2125, P2127, P2128, or P2138 for the 2.4L engine​
P2125​
Accelerator Pedal Position (APP) Sensor 2 Circuit​
ECM​
DTC P2120, P2122, P2123, P2125, P2127, P2128, or P2138 for the 2.4L engine DTC P2127 or P2128 for the 2.0L engine or​
P2127​
ECM​
P2128​
ECM​
P2135​
Throttle Position (TP) Sensor 1-2 Correlation​
ECM​
DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135 for the 2.4L engine DTC P2138 for the 2.0L engine or​
P2138​
ECM​
DTC P2120, P2122, P2123, P2125, P2127, P2128, or P2138 for the 2.4L engine DTC P0201-P0204, P0261, P0262, P0264, P0265, P0267, P0268, P0270,​
P2146​
Circuit Group 1​
ECM​
P2149​
Circuit Group 2​
ECM​
P2152​
Circuit Group 3​
ECM​
P2155​
Injector Positive Voltage Control Circuit Group 4​
ECM​
DTC P0201-P0204, P0261, P0262, P0264, P0265, P0267, P0268, P0270, P0271, P2146, P2149, P2152, or P2155 for the 2.0L engine DTC P0638, P1551, P2100, P2101, P2119, or P2176 for the 2.0L engine​
P2176​
Learned​
ECM​
P2177​
Fuel Trim System Lean at Cruise or Accel​
ECM​
P2178​
Fuel Trim System Rich at Cruise or Accel​
ECM​
DTC P2097, P2178, or P2188 for the 2.0L engine​
P2187​
Fuel Trim System Lean at Idle​
ECM​
P2188​
Fuel Trim System Rich at Idle​
ECM​
P2195​
HO2S Signal Biased Lean Sensor 1​
ECM​
P2196​
HO2S Signal Biased Rich Sensor 1​
ECM​
P2199​
Intake Air Temperature (IAT) Sensor 1-2 Correlation​
ECM​
DTC P2199 for the 2.0L engine​
P2227​
Barometric Pressure (BARO) Sensor Performance​
ECM​
DTC P2227, P2228, or P2229 for the 2.0L engine​
P2228​
Barometric Pressure (BARO) Sensor Circuit Low Voltage​
ECM​
P2229​
Barometric Pressure (BARO) Sensor Circuit High Voltage​
ECM​
P2232​
HO2S Signal Circuit Shorted to Heater Circuit Sensor 2​
ECM​
P2237​
HO2S Pumping Current Control Circuit Sensor 1​
ECM​
DTC P2237, P2243, P2251, or P2626 for the 2.0L engine​
P2243​
HO2S Reference Voltage Circuit Sensor 1​
ECM​
P2251​
HO2S Low Reference Circuit Sensor 1​
ECM​
P2261​
Turbocharger Bypass Valve Stuck​
ECM​
DTC P2261 for the 2.0L engine DTC P0137, P0138, P013A, P013E, P0140, P2232,​
P2270​
HO2S Signal Stuck Lean Sensor 2​
ECM​
P2270, or P2271 for the 2.0L engine DTC P0137, P0138, P013A, P013E, P0140, P2232,​
P2271​
HO2S Signal Stuck Rich Sensor 2​
ECM​
P2270, or P2271 for the 2.0L engine DTC P0130-P0133, P2195,​
P2297​
HO2S Performance During Decel​
ECM​
P2300​
Fuel Cut-Off (DFCO) Sensor 1 Ignition Coil 1 Control Circuit Low Voltage​
ECM​
DTC P2300, P2301, P2303, P2304, P2306, P2307, P2309, or P2310 for the 2.0L engine​
P2301​
Ignition Coil 1 Control Circuit High Voltage​
ECM​
P2303​
Ignition Coil 2 Control Circuit Low Voltage​
ECM​
P2304​
Ignition Coil 2 Control Circuit High Voltage​
ECM​
P2306​
Ignition Coil 3 Control Circuit Low Voltage​
ECM​
P2307​
Ignition Coil 3 Control Circuit High Voltage​
ECM​
P2309​
Ignition Coil 4 Control Circuit Low Voltage​
ECM​
P2310​
Ignition Coil 4 Control Circuit HighVoltage​
ECM​
DTC P2300, P2301, P2303,P2304, P2306, P2307, P2309, or P2310 for the 2.0L engine​
P2500​
Generator L-Terminal Circuit Low Voltage​
ECM​
DTC P2500​
P2501​
Generator L-Terminal Circuit High Voltage​
ECM​
DTC P2501​
P2535​
Ignition 1 Switch Circuit High Voltage​
ECM​
DTC P2535 • DTC P2544 for the 2.0L engine • DTC P2544 for the 2.4L engine​
P2544​
Circuit​
TCM​
• DTC P0115, P0120, P0826, P2544, or P2637 for automatic transmission DTC P0601-P0606, P062B, P167A, P167D, P2105, or P2610 for the 2.0L engine or​
P2610​
Performance​
ECM​
DTC P0601, P0602, P0603, P0604, P0606, P0607, P060D, P062F, or P2610 for the 2.4L engine​
P2626​
HO2S Pumping Current Trim Circuit Sensor 1​
ECM​
P2637​
Transmission Torque Delivered Circuit​
TCM​
P2763​
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit High Voltage​
TCM​
P2764​
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit Low Voltage​
TCM​
DTC P0973, P0976, P0979, or P2764 DTC P0133, P0134, P0140,​
P2A00​
ECM​
P2A01​
Performance Sensor 1 HO2S Circuit Sensor 2​
ECM​
U0001​
High Speed CAN Communication Bus​
ECM, RCDLR​
DTC U0001​
U0020​
Low Speed CAN Communication Bus Performance​
Radio,​
DTC U0020​
U0073​
Controller Area Network (CAN) Bus Communication​
ECM, Radio, RCDLR​
DTC U0073 or U2100​
U0100​
Lost Communication With Engine Control Module (ECM)​
TCM​
DTC U0100-U0299 or U2105- U2199​
U0101​
Lost Communication With Transmission Control Module (TCM)​
ECM​
U0121​
Lost Communication With Antilock Brake Module (ABS)​
ECM​
U0140​
Lost Communication With Body Control Module (BCM)​
ECM​
U2100​
Controller Area Network (CAN)​
RCDLR, SDM, TDM,​
DTC U0073 or U2100​
U2103​
Bus Communication Fewer Controllers On Bus Than Programmed​
BCM, DRR, IPC, SDM, VCIM​
DTC U2103​
U2105​
Lost Communications With Engine Control System​
BCM, EBCM, TDM​
U2106​
Lost Communications With Transmission Control System​
BCM, EBCM​
U2107​
Lost Communications With Body Control System​
EBCM, IPC, RCDLR, TDM​
U2108​
Lost Communications With ABS/TCS Control System​
BCM​
U2111​
Lost Communications With Steering Control System​
BCM​
U2113​
Lost Communications With Sensing Diagnostic Module (SDM)​
BCM​
U2116​
Lost Communications With Instrument Panel Cluster (IPC)​
BCM​
U2122​
Lost Communications With Radio​
BCM​
U2125​
Lost Communication With Mobile Communications Control Systems​
BCM​
U2137​
Lost Communications With Vehicle Theft Deterrent (VTD)​
BCM​
U2171​
Lost Communications With DVD Player​
BCM​
U2172​
Lost Communications With Digital Radio Receiver​
BCM​
Discussion Starter · #8 ·
Thanks for the response.
Here are the codes with all the digits: B0081-71; B1325-03; B1370-06
B0081Passenger Presence SystemSDMDTC B0081
B1325Device Power 1 CircuitBCM, IPC, Radio, SDMDTC B1325 DTC B1370
B1370Device Ignition 1 CircuitSDMDTC B1370
So I basically went down a few rabbit holes for this info.
1. B0081 Has the airbag sensor recall been performed?
2. To diagnose a B1325 DTC code, a technician would:
  1. Scan for codes in the ECM and look at the freeze frame data for failure.
  2. Visually inspect the Control Module Power harness for any damage.
  3. Check the voltage on the power circuit for the control module.
  4. Check the resistance on the power circuit for the control module
B1325 – What Does It Mean and How To Fix It - OBD2PROS (how to fix)
3. This B1370 bad ground video is right up kgschlosser alley, but for me is way over my head. Start around the 4:20 mark.
B0081-71: passenger presence sensor invalid serial data received
B1325-03: device power 1 circuit below threshold
the only thing that is going to produce the B0081-71 DTC is the SDM (Sensing and Diagnostic Module) which is the airbag module.
the B1325 can be produced by the following modules BCM, IPC, Radio, SDM
and the B1370 is produced by the SDM.
the common modules across all 3 is the SDM and there is a second module that is attached to the B0081 code and that is the PPS (Passenger Presence Sensor) which is located inside the passenger seat.
Here is the schematic for the SDM and the PPS modules.
Rectangle Font Parallel Slope Engineering
we can see the ignition 1 output from the BCM goes to both the PPS and the SDM. The invalid serial data is because the PPS mat is not turning on. The PPS mats source of power is from that ignition wire. So we need to locate what else is tied off that same circuit that would cause the car to die.
Reactions: ChopTop
Here is the schematic for that ignition circuit.
Rectangle Slope Parallel Font Engineering
If you look at the above schematic you can see the run/crank relay and that the output from it branches to a bunch of things. The ABS module and ECM being the 2 really important ones. If the vehicle is dying right after you let go of the key means that the run/crank relay is working during cranking.
I have a question,
How long after starting the car does it die?
The BCM is what sends a signal to that relay to latch and the BCM does this based on voltage that is received from the ignition switch. The ignition switch in the Solstice is not like a traditional ignition switch that is seen in 1990's and older vehicles.
There is a yellow wire at the BCM that is going to need to be tested for 12 volts with the key turned to ON. You are going to have to pull back the carpet on the passenger side at the firewall. That is where the BCM is located. There is going to be i believe 4 screws holding the BCM down. the screws have a 7mm hex head on them. The clip you need to access plugs into the back of the BCM. You can optionally locate the harness that runs behind the BCM to grab the wire if you like, it may be harder to do then just pulling the BCM out so you can see what you are doing. There is a lot of slack on the wires so you will be able to pull it out without having to unplug anything. There is a single yellow wire in that clip that plugs into the back of the BCM. There is only one clip that plugs into the back of the BCM so you cannot pick the wrong clip or the wrong wire.
Using a digital Volt Ohm Meter (NO TEST LIGHTS) set to DC volts take the black test lead and put it to a known good ground. The vehicle battery is right there so you can go right to the negative post on the battery. Turn the key to ON and test the Yellow wire. It should read 12V. If it does not then you need to replace your ignition switch. If you have a second person you can confirm the ignition switch is no good by having the second person crank the vehicle while you are testing the wire. When the person turns the key to start that yellow wire will become 12V and as soon as they let go of the key the 12V will go away. the Yellow wire is supposed to remain 12V in the ON and Start positions.
Discussion Starter · #12 ·
Okay. Wow. Thank you so much. Looks like I have some work to do, as much as a semi shade tree feels comfortable with doing.
Yes, the airbag recall was done, but it was done a long time ago. In fact, it was so long ago, I had to pay for it out of pocket because the class action suit had not been finished yet. Once the suit was finished, I was reimbursed by GM for the cost. Of course, I had to fight the dealer and actually call the 1-800 Pontiac number right in the dealer's office, but that's another story. I want to say the cost was up there. I think it was 800 or a grand or something in 2014 dollars.
So yes the Airbag recall was done.
The ignition recall was done as well.
In answer to your question about running, it doesn't. It cranks over, but to get anything further out of iot you would have to hold the key in Start and all you get is more "trying" to turn over out of it. It did run once for about 5 seconds, but the motor was sputtering and bucking.
Is the SDM Module a plug and play? I know you said it connects to other systems, which is why I am guessing you asked about the Airbag Replacement due to the seat module connecting with the SDM. BTW, I do not have nor have I ever had any Passenger Airbag Light warnings after the recall was done.
Thanks again brother. I will hunt around in my spare parts bin, see what I have, and maybe you can use something (for free), I have on hand. I know I have a footrest, some aluminum valve cover gaskets (I think ), and some other small stuff. I will look and let you know.
omw41, I don't know if you watched that video, but the whole point of it was that GM used a ground fastener that is known to cause ground failures over time. From the wires completely breaking off at the ground fastener point, to only some wires breaking off but concealed by the insulation wrap. Which causes intermittent starting issues.
If the car does NOT start and only cranks then the problem is more then likely either a fuse issue or a ground issue. I would check the run/crank replay by swapping it with one of the headlight relays and see if it will start when you do that. The run/crank relay gets it's 12V for the coil from the BCM and that relay should be active when the key is in the on and also in the start positions. The coil for the relay is grounded at the front corner of the engine. The power that feeds through the relay to the circuits is not fused. the circuits themselves are fused after the relay.... I am guessing that either the relay is no good or it's a bad ground at this point.
omw41, I don't know if you watched that video, but the whole point of it was that GM used a ground fastener that is known to fail over time. From the wires completely breaking off at the ground fastener point, to only some wires breaking off but concealed by the insulation wrap. Which causes intermittent starting issues.
No. Not yet, but l will watch the video.
Yes. I am guessing it is one or the other now too. The mobile mechanic said there was something drawing on the battery, so first l am going to watch the video and try to check the ground. Thank you for helping me.
Discussion Starter · #17 ·
Problem solved.
First, I want to shout out to Chop Top for the deep dive. It helped and I learned a lot. Next, I need to thank kgschlosser. Last and as usual I need to thank Rob the Elder. The problem turned out to be the ground that is found on the top of the block. The wire connector just fell apart due to age, and once I changed out the connector, the car started right up. I just came back from a run up on 75 and the car is back with a vengeance. I thank Rob because I looked at an older post and he pointed out four grounding points: two under the ebrake cover, two on the front towers, the one on the top of the head, and the one under the battery. When I got to the one on the top of the head, I gave it a light tug, and it was so worn, it just fell apart.
Last, there have been rumors out there that the Solstice Forum is dead. Let me state in the words of Mark Twain: "The reports of my [our] death are greatly exaggerated." Except for one night in port when I was in the Navy, the 40.00 dollars to become a premium member of the forum was the best 40 I ever spent.
1 - 20 of 24 Posts
